| Haakon |
 Haakon L Plate Warrior
 Posted: 23:24 - 16 Jul 2021 Post subject: Peugeot Speedfight - some questions from an old newbie |
Hello everyone!
I am a 49y old amateur that have a Peugeot Speedfight 2 50cc, AC, 2004 model.
I have some questions i hope that you guys can help me with
Variator
1. If I am going to change rollers in the variator, what weight should I use? I'm looking for decent acceleration, but it should also be strong when going uphill. And it may be appropriate to mention that I am 115kg
2. I have heard that you can use rollers with different weights to get more properties. Is this right?
3. Is there anyone who uses sliders instead of, or combined with, rollers? Anyone have any views on this?
4. If I am able to hold the scooter with both feet on the ground when going full throttle, is it a sign that something is worn out? If so, what? Clutch / variator / variator weights / variator belt?
Or is it completely normal that one should be able to do that?
Carburetor and air filter
1. I was so damn tired of the original air filter; it would get loose from the intake on the carb and the scooter would stop.
That's why I bought a new one (https://imma.gr/103955x483eb). I've heard that you have to change carb nozzle if you use such air filters. Is this right? And if so, which nozzles? My carburetor has a 54 nozzle.
2. My carburetor has a set screw for both air/fuel mix and idle adjustment. Anyone know from experience how to adjust it in order for the scooter to run well?
And can one possibly avoid changing nozzles by adjusting the mixture instead, or is it not enough?
Appreciate if you have the time and effort to answer all my questions.
Thanks in advance, hehe  ____________________ --------------- Haakon ------------
Peugeot Speedfight 2, AC, (2004 mod) |
| WD Forte |
 WD Forte World Chat Champion
 Posted: 00:31 - 17 Jul 2021 Post subject: |
If you can stop the scoot moving off with your feet on full revs summats wrong
so I'd guess either the rollers, drive belt or clutch is worn, maybe all, so get the spanners out
and have a look.
Heavier rollers will possibly take off quicker but will not give an ounce of extra power.
If you must throw money at it keep it standard is my advice
115KG or 18st+ in real money eh? I doubt any old 50cc scoot will ever feel lively carrying that load.
A 70KG 16 year old would probably think it was rocket powered for the first week then want 'moar powah'
Not being judgemental,its physics
power to weight ratio and all that
low power high weight doesn't suggest rapid
Personally I'd burn it, send to hell and at least get a 125 which even then will not
burn rubber but it wont screaming its ass off as you trundle down the street
This thread from way back discusses tune up options
https://www.bikechatforums.com/viewtopic.php?t=219654 ____________________ bikers smell of wee |
| Haakon |
 Posted: 00:48 - 17 Jul 2021 Post subject: |
| WD Forte |
| Easy-X |
 Easy-X Super Spammer
The last post was made 4 years, 250 days ago. Instead of replying here, would creating a new thread be more useful? |
