Cannondale Project
PostPosted: 19:27 - 05 Oct 2026    Post subject: Cannondale Project Reply with quote
Whoops! Posted this in the wrong section...
As if I didn't have enough going on, I'm converting this old Cannondale F500 to rigid forks:
https://i.ibb.co/TBbpd8rt/20261001-165833.jpg
The head tube is an outlandish 2 inches in diameter so I'm dropping in some conversion bearings to reduce it down to a reasonable 1 1/8". The original Headshok fork had seized up long ago so I'm converting it to a rigid fork.
I'm thinking I might treat and respray the corrosion deliberately badly to maintain the "rat bike" aesthetic it seems to have spent it's life evolving into Smile
PostPosted: 19:36 - 05 Oct 2026    Post subject: Reply with quote
Most of the parts turned up, and it was a lovely afternoon..
https://i.ibb.co/60q74NNJ/20261005-162302.jpg
Slight snag though:
https://i.ibb.co/20bWMpBx/20261005-162308.jpg
I had a word with the eBay seller of the fork and they gave me some money back to buy some adapters to drop the V-brake pegs down a bit, which was nice of them.
Still has a rear brake so err... perfectly safe to ride Smile Even so, I only went up and down the road to test it out but wow, it's certainly agile! My old bike feels like a barge in comparison.
PostPosted: 22:59 - 05 Oct 2026    Post subject: Reply with quote
I have the Surly version of those forks on my MTB. Surprising how much they soak up the bumps. Steel is real and all that.
I think they're designed for 29" rims, which will be why the brake pivots don't line up
You going to go fat tyres on it?
EDIT: Or go 29" front, 26" rear just to annoy people?
PostPosted: 13:17 - 06 Oct 2026    Post subject: Reply with quote
Yes, Gemini pointed it out to me that steel has a bit of spring to it, makes sense - spoked wheels vs. cast and all that. The reason for using a 29" fork was to compensate for the loss of the Headshok suspension. I think it's something like 390mm for a normal fork between axle and crown and this is more like 420mm so the geometry is maintained.
29 on the front sounds a bit extreme but thinking about it, a 27.5" wheel would be enough to be disconcerting without people being immediately sure of what's going on. I think you'd call it a "mini-Mullet" Laughing
For now I'm going to fit the V-brake adapters but I was thinking of a disk brake front at some point so maybe 27.5" Thinking
PostPosted: 18:14 - 06 Oct 2026    Post subject: Reply with quote
The little brackets don't fit Sad I think they're meant for raising up the posts rather than downward, my f*ck up Doh! Disk brake wheel sounding even more appealing.
PostPosted: 15:23 - 10 Oct 2026    Post subject: Reply with quote
All done bar the painting:
https://i.ibb.co/0VnQM5rr/20261010-145222.jpg
End result: 27.5" wheel upfront (NOS Cannondale), generic hydraulic front brake with 160mm disc and Schawlbe "Marathon" tyre.
Riding around town, bumping up and down curbs, etc. it's definitely my sort of bike. A very satisfying project Smile
sickpup
Old Timer
PostPosted: 16:07 - 10 Oct 2026    Post subject: Reply with quote
Do you still have the headshok fork?
PostPosted: 18:11 - 12 Oct 2026    Post subject: Reply with quote
It's in the shed. Completely seized up so effectively it's a very heavy fixed fork. Do you think it's worth rebuilding?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Cycling Forum All times are GMT + 1 Hour
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.2 - MySQL Queries: 13 - Page Size: 57.75 Kb
