Can you jumpstart a bike battery from a car?
Fallen Angel
Franny the Nanny
PostPosted: 19:32 - 08 Dec 2004    Post subject: Can you jumpstart a bike battery from a car? Reply with quote
As long as the voltage is the same?
I have an asshole tolerance level of -10 Twisted Evil
Mr. Green Dance! Mr. Green www.cliqueyclanmcc.co.uk Mr. Green Dance! Mr. Green
www.bebo.com/fallenangelfran
PostPosted: 19:46 - 08 Dec 2004    Post subject: Reply with quote
Short answer is yes.
Long answer is:-
https://www.bikechatforums.com/viewtopic.php?t=35904
Guest
PostPosted: 19:51 - 08 Dec 2004    Post subject: Reply with quote
Yes, but there are some important things to remember.
If you accidentally 'short' a battery (connect the neg side to the pos side) you will generate a very large electric current. This can cause a fire or even explode the battery. It will certainly melt the jump leads. You need to keep the un-insulated clips on both leads well apart.
So...
Lift bike seat (assuming the battery is under there) and car bonnet.
Connect the red jump lead to the red (+) terminal on the bike battery 1st. Then connect the other end to the red (+) terminal on the car battery.
Make sure this lead cannot come into contact with any metal on the bike or the car while you're connecting them or while you're trying to start the bike.
Now connect the black jump lead to something metal on the bike - I use the rear wheel nut (this is to keep the two leads apart on the bike as there's not much clearance around a bike battery). Connect the other end of the lead to the Neg (-) terminal on the car battery.
Now try and start the bike. If it won't go and starts to drain the car battery you can start the car but let it just tick over, do not rev it.
When the bike's running (or you've given up Wink ) disconnect the black lead from the car battery and then from the bike. Then disconn the red lead from the car and then from the bike. Do not let this lead touch anything metal while you're disconnecting either end.
PostPosted: 19:56 - 08 Dec 2004    Post subject: Reply with quote
Worth mentioning that the reason for this is that until you have connected the black lead / -ve lead / earth lead then the bike frame is not earthed to the car, so should the red / +ve lead touch the frame you should avoid having a load of sparks.
Same reason why when fitting a battery you should fit the +ve terminal first, and when disconnecting one you should remove the -ve terminal first.
Silver 0wl
PostPosted: 21:19 - 08 Dec 2004    Post subject: Reply with quote
cheers guys Thumbs Up Thumbs Up Thumbs Up
www.cliqueycuntsmcc.co.uk
Smoke them if you got them, if you ain't got them, then go get them! Surprised
hawkeye
PostPosted: 23:13 - 08 Dec 2004    Post subject: Reply with quote
Ever seen a spanner across a battery? Turns it into a light bulb Cool
'89 R/W/B NC30
'The car in front is... in my way'
Fortuna
PostPosted: 23:31 - 08 Dec 2004    Post subject: Reply with quote
Done it loads of times. I keep a spare car battery in the shed for winter or when my bike battery is low Thumbs Up
BLOFLY 636
PostPosted: 08:46 - 09 Dec 2004    Post subject: Reply with quote
howerver even though the bike frame is not earthed to the car and with the +ve lead connected between the car +ve terminal and the bikes +ve terminal the frame of the bike will still short the battery out if it comes into contact with the +ve lead Idea
Those bloody footpegs......they ought to do away with em!
Fortuna
PostPosted: 18:33 - 09 Dec 2004    Post subject: Reply with quote
Because they are effectively the same earth as they are joined by the negative Thumbs Up
PostPosted: 19:22 - 09 Dec 2004    Post subject: Reply with quote
As above, but the main thing you are shorting out is the battery on the bike. Would have much the same effect if you shorted the +ve bike terminal to the frame.
Valentino Mossy
PostPosted: 22:14 - 09 Dec 2004    Post subject: Reply with quote
Dropped my ratchet rench on the renault 5 battery once, fried the socket, the rench, melted the live and earth leads, and shat my kegs ! Shocked
LOADS OF SPARKS !!!!! Very Happy
mchaggis
PostPosted: 01:24 - 10 Dec 2004    Post subject: Reply with quote
My dad once connected the battery of an old Volvo estate backwards. It melted half of the electrics. Good riddance I say.
I must not be a troll...
Mmmm, Guinness
mr.z
PostPosted: 12:19 - 10 Dec 2004    Post subject: Reply with quote
How does anyone with electronicly controlled fueling go about it? i've heared of people frying ecu's changeing baterys over, or just clearing them out...
Just wondered is all...
Big Pete
PostPosted: 12:50 - 10 Dec 2004    Post subject: Reply with quote
There are small power supplies that you connect across the battery terminals before dissconnecting the leads, they do about 1 amp at 12v, which keeps ecu and radio memories alive. They are usually called "ecu saver" or similar.
Trust me, I`m an engineer
GarageOfPower.co.uk
PostPosted: 13:15 - 10 Dec 2004    Post subject: Reply with quote
There can be occasional problems swapping batteries. BMW 3 series can apparently fry the clocks when you change the battery. More worrying is that it is not unknown for it to trigger the airbag occasionally on some cars when you reconnect a battery.
Biggest problem with the ECU is likely to be that most modern ones use the feedback from the lambda probe to adjust the fueling themselves for future use, so when you disconnect the battery the system defaults back to its standard (rather poor) mapping.
There are plus point to this. Apparently the old Volvo 850 T5 would land up mapping itself quite poorly if they were used slowly. Quick fix was to disconnect the battery for a short while, connect it back up and then go and thrash the knackers off it.
freestyler_onli
PostPosted: 23:42 - 10 Dec 2004    Post subject: Reply with quote
Can you jump start if it's cold.
Git
PostPosted: 23:56 - 10 Dec 2004    Post subject: Reply with quote
One small point I would like to say is you can only jump start a 12v bike from a car, jump start a 6v bike from a 12v system and you will fry stuff.
clemsta
PostPosted: 15:20 - 12 Dec 2004    Post subject: Reply with quote
Fallen Angel, why do you want to know this, the NS125R doesn't have a electric start so you shoudn't need to charge the battery unless it is totally goosed and won't even bump start, try testing the alternator to see if it is chargeing properly, you do this by having the bike running, connect a volt meter between +ive and -ive terminals, it should read about 14V if it's charging correctly. If it's ok then you need to test the battery, it's probably knackeered unless the bike has not been started for a long time.
Hope this helps
Adam
SOMEONE CALL THE DOCTOR! I've got 2 stroke fever!!!
OGRI - Stuff everything, i've always got my bike!
DAS Passed - 7/6/06
Minky_monkey
PostPosted: 15:28 - 12 Dec 2004    Post subject: Reply with quote
I went out to a guy that jump started a Jaguar with a BMW, he stuffed both ECU's. The Jaguar one was £2000. Ouch!
The only way I jump cars these days is with a Boost pack, I'd never do it off a running vehicle now.
I had a peugeot 406 diesel that had been jump started and then you couldn't turn it off! I think he'd shorted the alternator.
Big Pete
PostPosted: 13:20 - 13 Dec 2004    Post subject: Reply with quote
Thats likely a stuck shut off solenoid on the injector pump, happened on one of mine. Theres a manual shut off lever on top of the pump body.
GarageOfPower.co.uk
Fallen Angel
Franny the Nanny
PostPosted: 14:02 - 13 Dec 2004    Post subject: Reply with quote
I have a new bike - a GPZ500 - which isn't starting at all at the moment!! Crying or Very sad
PostPosted: 17:28 - 13 Dec 2004    Post subject: Reply with quote
Have you tried the earlier suggestions (eg, draining the carbs, ensure the fuel is on "ON" not reserve, etc)?
The last post was made 21 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 123.42 Kb
