Best chain cleaning method?
cc123
Geez a joab?
PostPosted: 11:25 - 11 Feb 2005    Post subject: Best chain cleaning method? Reply with quote
Just wondering whats the best way to keep your chain in good shape?
I usually get a rag with WD40 on it, rub it down, get an old tooth brush into it also, then give it some chain lube to keep it fresh...
I destroyed my last chain (was in some state) and want this one to stay fresh. Is this an ok way to do it?
And another thing (I thought it was Renthal but it's a D.I.D.) It's a 525 chain. Is that more for track or road use....I seen something about chains somewhere else but unsure what it means?? Confused
Old bikes >>> https://www.bikepics.com/members/cc123/
Git
PostPosted: 11:36 - 11 Feb 2005    Post subject: Reply with quote
I use the same method for my chains but it would be worth mentioning that you do not want to soak the chain with wd40, it may just hurt the o rings over time, a light drizzle on a rag to clean the side plates is ok in my eyes but I really would avoid getting the o rings wet with wd.
headlamp
PostPosted: 11:47 - 11 Feb 2005    Post subject: Reply with quote
I find the best way to clean the chain is soak a rag in white spirit - clean the chain, wait for it all to evaporate then reapply the lube.
Using a mobile phone while driving a car should be made a capital offence!
Valver
PostPosted: 11:51 - 11 Feb 2005    Post subject: Reply with quote
WD40 is for your tyres and brake disks only!
Don't use it on your chain as it makes it slippery! Douh!
Sparks!
Sir Tart-a-lot
I've never ever cleaned a chain, I just replace it when it gets worn Laughing but if I was going to do it then it'd be take the chain off and soak it in a bucket/tray of paraffin over night then scrub it a bit in the morning (in fresh paraffin!) then soak it in engine oil for ages, then apply some lubbbbbbbbbeeeee when it's fitted back on the bike.
cagiva gezzer
PostPosted: 12:03 - 11 Feb 2005    Post subject: Reply with quote
I find that fresh lube has enough solvent in it to shift all the gunk off the chain. Spray lube on, wipe it all off and re lube.
Mr.Everready
PostPosted: 12:05 - 11 Feb 2005    Post subject: Reply with quote
Paraffin and a tooth brush. Thumbs Up
PostPosted: 12:07 - 11 Feb 2005    Post subject: Reply with quote
I rarely clean chains, but then I tend to use oil to lube them, plenty of which flings off taking the grit with it.
I would not use WD40 to clean a chain. Personally I would use a toothbrush and a light oil (last time I used ATF).
EuropeanNC30R...
Gay Hairdresser
PostPosted: 12:10 - 11 Feb 2005    Post subject: Reply with quote
One well-known chain manufacturer (can't remember which one) recommend using WD40 as a chain lube.
I believe 525 relates to the width of the chain. I'd expect that to fine, and probably OE, on a 600. As a comparison a lot of litre bikes have 530 pitch chains, and some 250's have 520. It's a popular mod for racers to go to a smaller size like 520 as there's marginally less weight and less transmission loss. Probably not a good idea for the road though.
cc123
Geez a joab?
PostPosted: 12:13 - 11 Feb 2005    Post subject: Reply with quote
Why not WD40?
Where do I get ATF (dunno what that is) or parafin from. I only use the rag to get the crap off first then wipe most of the WD40 off before putting the lube on..
Is there anywhere else on the bike I should use WD40 to keep it from rotting? The bike is still pretty spotless even tho I've been out alot over the winter..
Git
PostPosted: 12:21 - 11 Feb 2005    Post subject: Reply with quote
A very debateable subject to use wd or not.
Some will happily use and report no problems, others will never use it as they have had problems, a bit like anything really, we all have our own personal thoughts and experiences with it.
cc123
Geez a joab?
PostPosted: 12:28 - 11 Feb 2005    Post subject: Reply with quote
I think the old chain I took off must have been the OE judging by the state it was in, on of the things I didn't notice when I bought the bike but its a Gold DID chain on it now. Not sure if it's an X or O ring chain, does that matter either?
Just when I seen the bike last night before I went out. It was a tad dirty and I usually have it sparkling. Just cleaned it down.
timmya
PostPosted: 12:55 - 11 Feb 2005    Post subject: Reply with quote
cc123 wrote:
Why not WD40?
i think ATF stand for automatic transmission fluid.
i think Question
Gilera Dna 180cc - first bike and i luv it..
Mr.Everready
PostPosted: 14:12 - 11 Feb 2005    Post subject: Reply with quote
You'll get paraffin from any hardware shop.
Zx6man
PostPosted: 14:21 - 11 Feb 2005    Post subject: Reply with quote
for your brake discs???? are you mad?
Zx6man
PostPosted: 14:22 - 11 Feb 2005    Post subject: Reply with quote
Me too. Best results and cheapest option
Zoffo
PostPosted: 15:08 - 11 Feb 2005    Post subject: Re: Best chain cleaning method? Reply with quote
If you've put a new chain on old/worn sprockets you'll damage the chain in no time. The chain has to sit tight between the sprocket prongs. If they are worn it can move on the sprocket and will pretty soon be shagged. I would always change chain and sprocket when the time comes, not just one or the other.
Surprised to hear that some people never clean their chain. Chain and sprockets is one of the first places a prospective buyer would look and if it hasn't been looked after then they aren't going to be confident that the rest of the bike has either.
cc123
Geez a joab?
PostPosted: 15:17 - 11 Feb 2005    Post subject: Reply with quote
Tis ok, I changed the spockets along with the chain. Thumbs Up
It's one area of the bike I take care and pride in keeping it tip top. I'm guessing it was the original chain on it, but how long do chains last normally. It had 16k miles so I'm guessing it was changed at some point before....
It also gets adjusted every 500 miles as per the owners manual.
The front sprocket was wasted when it came off. Made a HUGE difference when changed. Felt like I'd gained 10bhp!! Laughing
Mantzy
PostPosted: 16:04 - 11 Feb 2005    Post subject: Reply with quote
I'm all for fresh parrafin and then chain wax.
Or say bugger it and get a scottoiler
R
Current Bikes: 2010 Triumph Sprint ST 1050
Previous Bikes: 2002 Sachs XTC, 1999 Kawasaki ZX6R, 2004 GSX-R 600 K4, 2006 Yamaha XT660X
Bendy
Mrs Sensible
PostPosted: 16:12 - 11 Feb 2005    Post subject: Reply with quote
I used old engine oil to clean/relube mine when it was looking a bit sorry for itself.
Rip up some binbags so you don't get it all over the floor and then liberally slather the chain with used GPS using the washing up brush from the kitchen to get it right in between those links. Leave to soak while having lunch.
Wipe the worst off with kitchen roll, then run the bike (on the stand) and watch oil fling off everywhere.
Wipe oil off fairings and swingarm. Fetch bucket of hot soapy water and wash oil off rear tyre. Sweep sand over oil puddles on garage floor. Apply chain wax and purchase new washing up brush.
For all the mess, it worked a treat and I have refined the system since then. Wink
ian_s
PostPosted: 21:11 - 11 Feb 2005    Post subject: Reply with quote
I always have some gunk lying around for use on the cage. Will degrease with that and then apply some silkolene chain lube. It's only about £7 a can and lasts for ages.
hugo-a-gogo
PostPosted: 21:23 - 11 Feb 2005    Post subject: Reply with quote
Zx6man wrote:
valver wrote:
WD40 is for your tyres and brake disks only!Don't use it on your chain as it makes it slippery! Douh!
i thought the same thing, you don't want a slippery chain, but slippery brakes are ok?
"There are some things nobody needs in this world, and a bright-red, hunch-back, warp-speed 900cc cafe racer is one of them - but I want one anyway, and on some days I actually believe I need one. That is why they are dangerous."
Hunter S Thompson
clicky 4 bikey
instigator
PostPosted: 21:29 - 11 Feb 2005    Post subject: Reply with quote
Erm, I DO think it was a joke guys Laughing Laughing Laughing Laughing
kasandrich
PostPosted: 21:37 - 11 Feb 2005    Post subject: Reply with quote
Yep its a great idea, saves on brake pad wear by reducing friction Laughing Laughing
Richard
CBR1000FM
mattsmith95
PostPosted: 22:04 - 11 Feb 2005    Post subject: Reply with quote
I never clean the chain, I just wear the bugger out, I don't really think cleaning the chain is worth it. Chains on my bikes last quite a long time which is why I don't bother cleaning them.
But I have been told this from many bikers, parrafin is the best way to clean a chain. Remove chain from bike and soak overnight, wipe it with an rag, let it dry and fit back on the bike, then lube up.
The last post was made 21 years, 236 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.52 - MySQL Queries: 13 - Page Size: 128.23 Kb
