RXS1OO Indicators
RXS katie
PostPosted: 10:10 - 30 Mar 2005    Post subject: RXS1OO Indicators Reply with quote
Hi, does anybody out there have any ideas how to make the indicators on my RXS brighter? They are hardly visible in daylight Confused
Josh|RD125LC
PostPosted: 11:10 - 30 Mar 2005    Post subject: Reply with quote
Are they much dimmer when you have your headlights on? Because if they are, this happened to me a while back, and its most probably meaning that you need to charge your battery. Others may have something else to say though.
Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures
PostPosted: 12:33 - 30 Mar 2005    Post subject: Reply with quote
Think the RXS has a 12V system. Probably worth giving the battery a good charge off the bike and checking that it is healthy.
Not sure whether the RXS has an electrical system all working off DC from the battery. If it does then try using some LED bulbs. Also worth replacing the relay with a new one (as it will be at least a decade old and probably a bit worn and corroded inside). Also clean up all the connectors. Also worth checking the reflectors in the indicators. Likely that these have dulled with age.
ashhot84
PostPosted: 17:05 - 30 Mar 2005    Post subject: indicators rxs 100 Reply with quote
my last bike i had was a rxs 100 and i had your problem. the bike has only got a 6v system which is a problem! i found dirty connections and dirty lenses where the main cause. i went to my local bike shop and bought brighter bulbs as well. this helped a great deal. my bike was a 1994 model, but i dont recall them changing anything after this! best of luck ash!!
gamma funboy 84
RXS katie
PostPosted: 17:07 - 30 Mar 2005    Post subject: Indicators Reply with quote
It has a 6V system and only the indicators work direct from the battery! The problem is that there is only one wire to the indicators and so I can't change for a different type cos most have two wires!!! Confused
Patto
PostPosted: 19:44 - 30 Mar 2005    Post subject: Reply with quote
They may only have one wire but they still work on the same electrical principle as other bikes 6v or 12v , you will probably find they earth through the indicator housing direct to the mounting point , the single wire is then your supply. fitting twin wire indicators should just be a matter of finding a suitable earth point for the wire that leads to the bulb holder and connecting the other ( the one leading from the insulated contact plate ) to the supply.
And then follow Kickstarts advice and you should be in business
Hope this helps
good luck
Patto
PostPosted: 19:51 - 30 Mar 2005    Post subject: Reply with quote
The indicators on your bike probably earth directly to the frame where they bolt on. As such the chances are that you can buy new indicators with 2 wires and just run one of the wires straight to earth.
Cheap replacement ones in the same style as the original ones would be around £10 each.
I would take the lenses off and clean up the reflectors first, and also clean the inside of the lenses thoroughly.
PostPosted: 19:53 - 30 Mar 2005    Post subject: Reply with quote
Ooops, someone is quicker at typing than me!
RXS katie
PostPosted: 20:55 - 30 Mar 2005    Post subject: Reply with quote
Thank you for all the advice!! I'll let you know how it goes. Very Happy
RXS katie
PostPosted: 20:56 - 30 Mar 2005    Post subject: Reply with quote
RXS katie
PostPosted: 20:57 - 30 Mar 2005    Post subject: Reply with quote
The last post was made 21 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.27 - MySQL Queries: 14 - Page Size: 67.61 Kb
