Servicing? what type of place
Ric
PostPosted: 00:52 - 30 Jun 2005    Post subject: Servicing? what type of place Reply with quote
My bikes really in need of a few £££'s spend on it so im looking for a place to do it
i usually have it done by bournemouth kawasaki but being back in london i have a choice
Independant : A small shop run by about 3 guys down my road
Francise : Some one like collin collins
Dealer : My nearest Kawasaki Dealer
Im not looking to spend a fortune but i want it done, none of this we changed the oil nonsense when they havn't etc
What You lot Do/Rekon
numark1
Scared of girls
PostPosted: 01:04 - 30 Jun 2005    Post subject: Reply with quote
Do as much of the simple stuff as you can do and then get the garage to do the rest. Check your service manual to see. Thumbs Up
gsxrboy
If you want a job done properly do it yourself. It knobs me right off the amount you have to pay for a service.
www.predatorsport.co.uk Paintball arena located between Northampton and Milton Keynes
Ric
PostPosted: 01:05 - 30 Jun 2005    Post subject: Reply with quote
im gunna do the sparks, and balnce the carbs
i want them to clean the carbs maybe, valves ne thing else maybe clutch and 2 new tyres
Kram
PostPosted: 01:11 - 30 Jun 2005    Post subject: Reply with quote
how hard is it to sync carbs?
cos i need a service on my bike, but unsure about carb sync and valve timings. (sorry if i thread steal).
i normally pay £70 + parts for a service
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
Kram
PostPosted: 01:12 - 30 Jun 2005    Post subject: Reply with quote
Ric
PostPosted: 01:36 - 30 Jun 2005    Post subject: Reply with quote
i have a carb balancer thingy so not too hard
i just want it runnin mint so wanna do some of it at a dealer
ill do all the 1hour type jobs myself jsu the tricky ones at the shop
mr.z
PostPosted: 02:40 - 30 Jun 2005    Post subject: Reply with quote
Don't imagine that haveing a dealer/shop do the job it will be done propperly... they dont have to ride it, they are ALLWAYS trying to get stuff out of the way and will often cut corners/bodge stuff into place, loose bits e.t.c.
Theres good ones but not many, only time i get the mechanic down the road to do anything is if it requires a tool i dont have or cant afford at the time.
Most stuff should be fairly easy on a zxr, the clutch should be easy enough too, i helped a mate do an engine swap and a few engine innards and its not so bad if you have all the propper gear..
Drummer - You mean valve clearences, on some its easy to do (locknut adjustments) on shims they can be fiddle (from what i have been told) and you need to order them or have them handy to change (if it needs it) easy to do really but also easy to mess up and its not somthing you want to bugger up, try and get help from a knowlageble friend.. Carb balancer i payed £50, takes 5 minutes to check and 30minutes or so to adjust, easy to do that one...
The last post was made 21 years, 91 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.39 - MySQL Queries: 14 - Page Size: 55.83 Kb
