nsr125 question carb???
jimpuntoy
PostPosted: 19:47 - 28 Jan 2006    Post subject: nsr125 question carb??? Reply with quote
i have just taken the carb out and cleaned it and put the slide pin 2nd notch from the end, now i have put it back together and cant remember if it made a tap noise when you close the throttle and when u open it al the way? also it is smoking a lot more now what might i have done Shocked ???
PostPosted: 20:32 - 28 Jan 2006    Post subject: Reply with quote
If you put the needle clip in one of the grooves further from the point of the needle then that makes it run leaner. Closer to the point and it makes it richer.
jimpuntoy
PostPosted: 20:38 - 28 Jan 2006    Post subject: Reply with quote
oops would that make it smoke more makin it leaner? what notch do u think it should be on and whats the proper setting for the big screw on the side of the carb? thnx Shocked Thumbs Up
puremagic72
PostPosted: 23:08 - 28 Jan 2006    Post subject: Reply with quote
if the bikes de restricted( exhaust,airbox), it should be set on 2nd notch from top.
The big screw is the idle(if i remember right), adjust this when the bike is warm, should be 1400. Maybe higher in cold weather(1800)
Small screw to the left of that is screw in as far as can go(not tight) then 2 and half times out
Baz. Thumbs Up
Make; cbr929cc blade Year; 2001
Gsxr 750 2000, alstare Corona, Current bike 1999 R6
(1) Kids in the back seat cause accidents; accidents in the back seat cause kids.
PostPosted: 00:14 - 29 Jan 2006    Post subject: Reply with quote
According to the workshop manual, it should be the 3rd groove, 1400rpm +/-100 rpm idle, mixture screw 2.5 turns out.
jimpuntoy
PostPosted: 11:23 - 29 Jan 2006    Post subject: Reply with quote
hi, im confused as to which is the top of the slide pin? i will take it the pointed end is, i will try this and adjust the other screw and let u know what happens,, thanks,jim Smile Thumbs Up
PostPosted: 11:41 - 29 Jan 2006    Post subject: Reply with quote
They are normally quote from the top.
jimpuntoy
PostPosted: 11:43 - 29 Jan 2006    Post subject: Reply with quote
aha i think i know how the slide pin works now as it is tapered it blocks the big jet when you are not turning the throttle and the more you open the throtttle the smaller taper iis exposed allowin more fuel through, and adjusting the set height of the needle allows more or less fuel depending which way you move the clip, so moving the clip towards the point wiill raise it an let more fuel, am i sort of right? Shocked Thumbs Up
The last post was made 20 years, 238 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.52 - MySQL Queries: 14 - Page Size: 58.54 Kb
