Oil light coming on when stopped
proximity
PostPosted: 03:31 - 12 May 2006    Post subject: Oil light coming on when stopped Reply with quote
Lately my oil light has been coming on whenever i stop for a short period of time, even a few seconds sometimes.
It did it when i was stopped in traffic for a few minutes on a rainey day so it cant be the heat.
As soon as i ride off it goes out, what could be causing this?
Im going to change the oil tomorrow see if that helps.
2004 Aprilia Tuono
White Noise
Mr Dudwee
PostPosted: 08:39 - 12 May 2006    Post subject: Reply with quote
is it a oil pressure or an oil level light?
but as siggi says check your oil level in the sight glass and fill iy up if needs be
WN
Jamie.
PostPosted: 10:56 - 12 May 2006    Post subject: Reply with quote
When in neutral your oil light usually comes on, on most 2 strokes
PostPosted: 11:09 - 12 May 2006    Post subject: Reply with quote
If the oil is particularly knackered then it might do it, but I would suspect it is a touch more serious. You could do with getting a proper oil pressure gauge on there to check what it really is (could just be the switch rather than a serious engine problem).
Had a similar problem with a GPZ500 years ago. O ring between the sump plate and the engine had gone resulting in low oil pressure. Killed the crank.
Barry_M2
PostPosted: 11:12 - 12 May 2006    Post subject: Reply with quote
It will be low oil pressure, usually down to either low oil or a clogged filter.
I'd recomend replacing the filter and an oil change.
The last post was made 20 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.62 - MySQL Queries: 14 - Page Size: 43.73 Kb
