| Author |
| Chiz |
 Chiz Trackday Trickster
 Posted: 20:47 - 24 Oct 2006 Post subject: Wiring in a 12v cigarette lighter |
I'm planning on wiring in a 12v cigarette lighter as i don't have one at the mo (it's actually on a car but sshhh )
I wondered whether i had to wire it through a fuse or just straight onto the battery, i'm not too hot on electrics, please explain in stupid talk.
Thanks, |
| Back to top |
| Davo |
 Davo Davo To The Rescue!
| Back to top |
| stinkwheel |
| Back to top |
| Chiz |
| Back to top |
| Davo |
| Back to top |
| Chiz |
| Back to top |
| Davo |
| Back to top |
| stinkwheel |
| Back to top |
| Chiz |
 Posted: 21:56 - 24 Oct 2006 Post subject: |
Thanks, i'll get a 12v socket and report back with pictures etc if that's ok.
| Back to top |
| finpos |
 finpos World Chat Champion
| Back to top |
| syl |
 syl World Chat Champion
| Back to top |
| BFG |
 BFG Brolly Dolly
| Back to top |
| Phil_G |
 Phil_G Traffic Copper
 Posted: 00:09 - 25 Oct 2006 Post subject: |
is there a specific problem that can be encountered by just using a heavier gauge of cable than is strictly needed? ____________________ 1997 Kawasaki ER 500 A1:- Once again, Its merely crap  |
| Back to top |
| Davo |
| Back to top |
| Phil_G |
| Back to top |
| stinkwheel |
| Back to top |
| krebsy |
 krebsy World Chat Champion
 Posted: 09:18 - 25 Oct 2006 Post subject: |
When the wiring went on the Divvy due to water damage I just used a a spool of heavy ignition wire to re-connect everything up again. Let's see the water corrode that.. .
K. ____________________ What's my New Year's resolution?
1280 x 1024. |
| Back to top |
| stinkwheel |
| Back to top |
| krebsy |
 Posted: 09:35 - 26 Oct 2006 Post subject: |
Oh it was all well crimped, tightened, inserted, sealed in watertight casing with Sillicone and Duct Taped..., all with a dash of WD40 beforehande to keep the moisture out... ..
1280 x 1024. |
| Back to top |
| R1stu |
 R1stu Shrek!
 Posted: 12:12 - 26 Oct 2006 Post subject: |
Ive just fitted one to the R1
Got an extension from Halfords, remove from the connector and soldierd on an inline fuse from a car stereo system. at the end of this I soliderd on some 8mm ring connections from halfords/motorworld to connect to the battery.
Its a coil wire i threaded it under the subframe out through the gear selector shaft and behind the fairing.
Ran it though the stay and behind the clocks, then used some velcro to stick it to the dash.
This way I can move it and cover it easy when washing the bike.
The only thing im thinking of now is a switch along it, as it seems to drain the batt some. (maybe damp causing it to short?)
its the same for a car, just use 10mm ringconnectors if your going to the batt. ____________________ Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished) |
| Back to top |
| stinkwheel |
| Back to top |
The last post was made 19 years, 153 days ago. Instead of replying here, would creating a new thread be more useful? |
