| Author |
| CHR15 |
 CHR15 Turbo nutter bastard
| Back to top |
| N cee thirty |
 N cee thirty Banned
| Back to top |
| chris-red |
| Back to top |
| ukash |
 ukash Derestricted Danger
| Back to top |
| nightshaddow |
 nightshaddow Nearly there...
 Posted: 09:44 - 27 Jan 2012 Post subject: |
these are reasonable lil engines, i believe the engine number prefix is 163 fml and are quite nippy geared up right, i have had an indicated gps speed of 79mph out of these engines with a jtf259.17 on the engine
more info here
https://www.alibaba.com/product-gs/208335444/162FMJ_162FMK_163FML_Engine.html
Engine Mode 162FMJ/162FMK/163FML
Engine Name CG150/CG175/CG163
Engine Type ,
Singlecylinder,4-stroke,air-cooling,camshaft downward
Displacement(ml) 149.5/173/196
Dimension(mm×mm×mm) 358×324×460
Net Weight(kg) 31.5
Max.Power(kw/r/min) 9.3/8500±5%,11.5/6500±5%,12/(8000±5%
Max.Torque (N.m/r/min) 10.0/7500±5%,11.5/6500±5%,14.5/(6500±5%
Compression Ratio 9.01/9.21/9.21
Bore and Stroke(mm×mm) 62×49.5/62×57.5/63.5×62.2
Ignition method CDI
Lubrication method Pressure and Splash
≤354
Min.Fuel Consumption(g/Kw.h)
Starting method /Electric/kick
Clutch method Manual Wet Multi-Plate
Gearshift Method Constant mesh, two stage transmission ,5-speed Gearshift
| chris-red wrote: | Needs more Turbo. |
and seeing as its you chris dont laugh up the turbo maybe you can make the efi for it to
https://www.chinese-parts-canada.com/turbocharger_fuel_injection.html
if anyone can...... should...... tis you
(edit) ps.
if you need a starter motor give me a shout i have one or 2 kicking about
(edit 2) p.p.s.
if you need carbs etc at a reasonable price i recomend
https://www.mypurerush.co.uk/product-info.php?proID=123 coupled up with a 110 main jet seems to be the optimum i could achive ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
| Back to top |
| garth |
 garth World Chat Champion
| Back to top |
| Reid |
 Reid Nitrous Nuisance
 Posted: 10:56 - 27 Jan 2012 Post subject: |
Bookmarked already I'll probably chip in again at the 83 page mark  |
| Back to top |
| CHR15 |
| Back to top |
| Welshd1k |
 Welshd1k World Chat Champion
 Posted: 18:00 - 27 Jan 2012 Post subject: |
bored of the bandit??? want something more manageable? lol
i want a go when its done PLEASEEEEEEEEEEEEEEe ____________________ Current >Cb600fx hornet, ns125rk90 21.7bhp@wheel<
Sold >,zxr400 h2 (33bhp kit) rd350 n1 rd350 lc2< |
| Back to top |
| The Artist |
 The Artist Super Spammer
 Posted: 18:03 - 27 Jan 2012 Post subject: |
| Back to top |
| Damon |
 Damon World Chat Champion
 Posted: 18:57 - 27 Jan 2012 Post subject: |
This can only go well...  |
| Back to top |
| Damon |
| Back to top |
| CHR15 |
 Posted: 21:06 - 27 Jan 2012 Post subject: |
https://i939.photobucket.com/albums/ad233/chris-bracey/cg/IMG_5862Medium.jpg
removed all wiring, it fires up but needs an oil leak sorting. need to do some cutting and adding on the frame to make a battery tray ect..
going to keep the new loom to an absolute minimum, no indis, idiot lights ect.
the exhaust on this is 35mm od. handily all the tubing ive ordered for the external wg on the bandit is also 35mm, should have enough left to do the piping on this.
if anyones got a gear lever for a cg or one of these chinky things, it would be useful. ____________________ Turbocharged drag thing / project death weapon / GK73A
Ste: I'm not entirely sure how you'd go about verbally abusing someone with a potato but I'm sure it's possible. |
| Back to top |
| Mikey3 |
 Mikey3 World Chat Champion
 Posted: 22:37 - 27 Jan 2012 Post subject: |
That is the awesomest CG ever! very Mad Max
Mike ____________________ '04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it' |
| Back to top |
| RePT |
 RePT Nitrous Nuisance
| Back to top |
| Tim.. |
 Tim.. World Chat Champion
| Back to top |
| CHR15 |
| Back to top |
| pepperami |
 pepperami Super Spammer
| Back to top |
| ukash |
| Back to top |
| CHR15 |
| Back to top |
| Sam_Y_93 |
 Sam_Y_93 World Chat Champion
| Back to top |
| CHR15 |
| Back to top |
| Teflon-Mike |
 Teflon-Mike tl;dr
| Back to top |
| KLR600 |
 KLR600 World Chat Champion
 Posted: 17:10 - 28 Jan 2012 Post subject: |
Looks like a pretty good base for a cafe racer type effort. Jamie Stokes used to have a really nice CG cafe racer, I almost bought it off him but I couldn't scrape the £200 or whatever tiny amount it was he was asking for together at the time  ____________________ Now: '00 Kawasaki ZRX1100R - Past: '84 Yamaha DT125, '89 Kawasaki KLR600, '97 Yamaha XJ600N
<Take Cool Photos!> |
| Back to top |
| CHR15 |
 Posted: 18:29 - 28 Jan 2012 Post subject: |
Also made a battery / electrics tray today, most stuff will be hidden under the seat hump, need to find the smallest battery i can that will crank the starter.
Tomorrow will be finish flatting off all tins and make a new loom. ____________________ Turbocharged drag thing / project death weapon / GK73A
| Back to top |
The last post was made 13 years, 326 days ago. Instead of replying here, would creating a new thread be more useful? |
