GEARBOX RATIOS
 Topic moved: from General Bike Chat to The Workshop by G (14 Jun 2006 - 18:51)
V4
PostPosted: 16:56 - 12 Jun 2006    Post subject: GEARBOX RATIOS Reply with quote
I have my gsxr 750 srad and now have a gsxr 600 bottom end of the same year to put on my top end (I fucked mine up)
I know both bottom ends are identical apart from the ratios in the gearbox, anbody know if I'm looking at much of a diference? I'm guessing they'll be shorter gears, It's got all the ratios in the haynes but it means nothing to me
Any advice appreciated, cheers
Leon
V4
PostPosted: 20:16 - 12 Jun 2006    Post subject: Reply with quote
On closer inspection I reckon this should be in workshop, someone move it for me? Thumbs Up ta
Leon
0ddball
PostPosted: 20:52 - 12 Jun 2006    Post subject: Reply with quote
This is a pretty good caluculator. Just plug the numbers in and it will work everything out for you.
https://www.xs4all.nl/~ator0437/gc/gc_main.htm
V4
PostPosted: 21:09 - 12 Jun 2006    Post subject: Reply with quote
Was about to, but there's no option for my bike or year Evil or Very Mad how queer Thumbs Down
Leon
sickpup
Old Timer
PostPosted: 21:17 - 12 Jun 2006    Post subject: Reply with quote
Swop the gears over then no problem.
0ddball
PostPosted: 21:19 - 12 Jun 2006    Post subject: Reply with quote
Leon
That's why you have to put the numbers from your manual in Rolling Eyes Surely you can do that!
sickpup
Old Timer
PostPosted: 21:22 - 12 Jun 2006    Post subject: Reply with quote
Put in numbers, put in oil. Nope can't do that. Twisted Evil
V4
PostPosted: 21:35 - 12 Jun 2006    Post subject: Reply with quote
No I meant it doesnt list my model or year, do i just ignore that bit then?
Leon
DUCMANs
PostPosted: 18:10 - 14 Jun 2006    Post subject: Reply with quote
Leon
Now it does... (Both the '98 600 and the '98 750).
I did not have time to compare the combination of the 600 gearbox and the 750 bike to an all stock 750 but I will tomorrow and post the results here.
Regards, Jean
Sephiroth
PostPosted: 19:07 - 14 Jun 2006    Post subject: Reply with quote
I can't get that gear link thing to work.
Apparently my bike will do 1080 mph in 6th gear...
veeeffarr
PostPosted: 19:09 - 14 Jun 2006    Post subject: Reply with quote
Use this link instead
Will give you a help bar on the side.
T
Sephiroth
PostPosted: 19:18 - 14 Jun 2006    Post subject: Reply with quote
Does this seem right? Rolling Eyes
Suzuki Bandit 400
veeeffarr
PostPosted: 19:20 - 14 Jun 2006    Post subject: Reply with quote
Suzuki Bandit 400
I think primary drive ratio needs to be "1.95"
Sephiroth
PostPosted: 19:23 - 14 Jun 2006    Post subject: Reply with quote
Top speed ends up as 5xxxmph Shocked
0ddball
PostPosted: 19:48 - 14 Jun 2006    Post subject: Reply with quote
The gear ratio's should be in the form
2.51 / 1
2.03 / 1
1.85 / 1
ect
The primary drive ratio needs to be looked up on the net or in the manual. For e.g, my gpz was 2.662
Tyre size, max revs and sprocket sizes are self explainatery.
Chain pitch :
420 = 0.5"
425 = 0.5"
428 = 0.5"
520 = 0.625"
525 = 0.625"
530 = 0.625"
630 = 0.75"
And the chain links, it should say in your manual.
Pretty simple once you get the hang of it and pretty much spot on according to my sat nav.
DUCMANs
PostPosted: 21:01 - 14 Jun 2006    Post subject: Reply with quote
Suzuki Bandit 400
Well actually it doesn't....
The gears are ok, you can either enter "37 & 11" or "3.363 and 1" because 37 divided by 11 is the same as 3.363 divided by 1.
The primary drive ratio can only be entered as a number so in your case 87/44 = 1.954.
Also you swaped the front and rear tooth count. You should enter "14 / 47" and not "47 / 14".
The tire size should be entered as 180 / 55 / 17, meaning:
Tire width = 180 mm, Tire height = 55% of width, Rim diameter = 17 inch. I know this is confusing but that is what manufacturers put on their tires now.
Doing all that with the numbers you supplied, results in:
https://www.xs4all.nl/~ator0437/Images/Bandit400.jpg
If you mail me all data (see Helpfiles) I'll add your bike to the presets.
Regards, Jean
V4
PostPosted: 21:15 - 14 Jun 2006    Post subject: Reply with quote
Hmmm, my gsxr 750 with a 600 gearbox results in 185mph top end Question
Leon
V4
PostPosted: 21:33 - 14 Jun 2006    Post subject: Reply with quote
No it doesn't, I fucked it up Smile
Looks about right now
Leon
DUCMANs
PostPosted: 11:01 - 15 Jun 2006    Post subject: Reply with quote
Leon
It does if it looks like these screen shots:
First = Gear ration 600 gear box
Second = '98 GSX-R750 with 600 gearbox
Third = Stock '98 GSX-R750
When comparing your current (stock ?) 750 to the one withe the 600 gearbox, you will lose about 9 mile topspeed. Also there are minor differences in speed at certain RPM and gears. If the 600 gearbox can handle the power of a 750, I would not worry to much about it.
Regards, Jean
V4
PostPosted: 17:56 - 15 Jun 2006    Post subject: Reply with quote
Quality! Cheers for that, Just gotta wait & see how it feels now.
Just out of interest, are these top speeds taking wind resistance into account?
Leon
0ddball
PostPosted: 18:41 - 15 Jun 2006    Post subject: Reply with quote
No, they are theoretical. If you're bike would rev to the limiter in top, that is the speed you'd be doing. But of course it won't with standard gearing.
DUCMANs
PostPosted: 14:08 - 16 Jun 2006    Post subject: Reply with quote
Leon
Like SpannerMonkey said, they are theoretical.
BTW, you could get your topspeed back by changing the rear sprocket to 42 teeth. This would result in the following speed/RPM/Gear matrix:
When you compare this to stock 750 matrix (see 2 messages up), there is barely a difference at all Razz
Regards, Jean
V4
PostPosted: 22:19 - 16 Jun 2006    Post subject: Reply with quote
Ah smashing Smile
I take it I'd be ok chain length wise? Taking 2 teeth off the rear?
Can't bloody wait to get my bike sorted Very Happy
Leon
DUCMANs
PostPosted: 17:22 - 17 Jun 2006    Post subject: Reply with quote
V4 wrote:
Ah smashing Smile
Leon
2 teeth off means moving the rear wheel 0.34 inch (8.55 mm) away from the front sprocket. I don't know if you have that range right now, you will have to check that.
Regards, DUCMANs
V4
PostPosted: 19:16 - 17 Jun 2006    Post subject: Reply with quote
Ah should be fine, I was about half way with a fucked chain and a 44t rear Thumbs Up Cheers
Leon
The last post was made 20 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.16 - MySQL Queries: 16 - Page Size: 124.09 Kb
