Steering damper problem, p*ssed off
lllN30lll
PostPosted: 21:59 - 12 Jul 2006    Post subject: Steering damper problem, p*ssed off Reply with quote
finally got my Sprint steering damper today, fitted it no problem,
got the the part where it says in on the instructions to set the bars to full lock to the left, then push the steering damper body all the way to the right until it meets the mounting point.
did it, clamped the body into place........................ and the f*cking thing won;t give me full lock to the right!!! it seems that the shaft of the damper is too short!
pain in the f*cking arse
pics, full lock to the left, as much lock to the right as i can get.
https://img.photobucket.com/albums/v707/lllN30lll/piccy-0050.jpg
https://img.photobucket.com/albums/v707/lllN30lll/piccy-0049.jpg
any idea's?
on the box that the damper came in one of the box's is ticked 50mm, other ones are 70, 100, 120, 140, 160mm whats this mean?
cheers
Turbo R1
CRF450R
lllN30lll
PostPosted: 22:06 - 12 Jul 2006    Post subject: Reply with quote
sure? instructions told me to push the body all the way to the right, then clamp it into place
Turbo R1
CRF450R
NSR Mick
PostPosted: 22:11 - 12 Jul 2006    Post subject: Reply with quote
You need a longer damper, if thats a 50mm you need the 70mm or maybe even the 100mm
Finglonga
PostPosted: 22:37 - 12 Jul 2006    Post subject: Reply with quote
That mattress is a fire hazzard! Wink
Andy Sez....
F.Y.Y.F.F.
craigs23
Mr Muscle
PostPosted: 10:11 - 13 Jul 2006    Post subject: Reply with quote
Siggi's right, you may get more span from the damper clamp - just slacken it off slightly so it can move relatively freely and then nip it up - see if you get the same span from the opposite lock.
Shaun
Likes 'em bent
PostPosted: 12:06 - 13 Jul 2006    Post subject: Reply with quote
Look on the bright side, at least your bars won't be able to go from lock to lock at 160 any more.
lllN30lll
PostPosted: 18:50 - 13 Jul 2006    Post subject: Reply with quote
ive set it up so i get equal amount of lock both sides of the bar now.
had an email from the seller stating that a 70mm is required and i've been sent a 50mm soooo i'll have to post it off now.
best money ive ever spent though, had a quick go today and it's transformed the SRAD's handling Cool
Turbo R1
CRF450R
lllN30lll
PostPosted: 19:44 - 13 Jul 2006    Post subject: Reply with quote
nope, even set with equal lock it aint in the middle of the damper Razz
nearly is though
Turbo R1
CRF450R
lllN30lll
PostPosted: 21:13 - 13 Jul 2006    Post subject: Reply with quote
yup they did, lock the steering to the left, slide the body all the way to the right and leave a 1mm gap Very Happy, tighten clamps, job done
*edit*
Siggi you might be gettin it a bit wrong here. not all steering damper bodies are clamped bang in the middle.
//awaits pwnage
https://i14.ebayimg.com/02/i/07/9f/66/df_1.JPG
https://i4.ebayimg.com/02/i/07/aa/3c/41_1.JPG
https://i20.ebayimg.com/05/i/07/97/d8/4e_1.JPG
https://i17.ebayimg.com/01/i/07/a6/65/5e_1.JPG
https://i24.ebayimg.com/01/i/07/a3/ae/eb_1.JPG
Turbo R1
CRF450R
lllN30lll
PostPosted: 22:31 - 13 Jul 2006    Post subject: Reply with quote
PMSL
https://fattyvt.tripod.com/funny_crap/thumbnails/400x300/owned.jpg
In the workds of Siggi:- Thangyuverymuch.
Turbo R1
CRF450R
True Blue
PostPosted: 22:55 - 13 Jul 2006    Post subject: Reply with quote
I take it that's an SRAD Gixxer? Don't they come with a steering damper as standard? Or was it just from the K series?
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
sickpup
Old Timer
PostPosted: 01:45 - 14 Jul 2006    Post subject: Reply with quote
Siggi wrote:
Man, those look fucked-up to me. Are they working around having out-of-whack geometry or something? Or are they "How Not To Do" pictures? Assuming all the mounting-points are central, how can it be that the body & clamp need to be off-center to each other? It makes absolutely no sense at all. Confused
Oh yes it does my non-mechanically mind friend.
The yoke brace will only be central on the damper body if the offset frame bracket sticks out to the side exactly half the length of the damper rod and rose joint centre.
Suzuki
Roger
PostPosted: 10:52 - 14 Jul 2006    Post subject: Reply with quote
Siggi, the location of the main body is irrelevant providing that you have full range of movement for the handlebars.
The instructions of mounting it at full lock are correct, in that they give you full range of movement in the direction of the lock you start with, and providing the slide rod is long enough, will also give you maximum movement to the opposite lock.
Prividing the slide bar is the correct length, mounting things in a central location *should* work, but it's not guaranteed.
<Simple> no I'm shaven Jon Razz
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map
dainesefreak
PostPosted: 11:16 - 14 Jul 2006    Post subject: Reply with quote
Thank you Honda for HESD. Wink
Suzuki
Roger
PostPosted: 11:27 - 14 Jul 2006    Post subject: Reply with quote
Siggi wrote:
Why's it not garaunteed? If the rod is the correct length, and all mounting points are central to the bike's longitudinal axis, the damper's body should be perfectly able to be centrally clamped.
The body should be clamped at the exact centre of the slide rod.
However, the slide rod is not necessarily central to the bike. It all depends on the mount point for the damper. Haven't you seen a damper that fits down the side of the frame and bolts onto one of the forks?
If the damper is fitted off centre, then it'll still work just the same. The body will be clamped off centre with respect to the bike, but the body will still be central on the slide rod when the front wheel is also central.
Make sense now?
Suzuki
Roger
PostPosted: 11:46 - 14 Jul 2006    Post subject: Reply with quote
Just cos the damper clamps at the front of the tank, and the mount point is central, doesn't mean that the slide rod is exactly central.
If the slide rod isn't central, then the body will have to be clamped off-centre to the bike too, so that it is central on the slide rod.
Nothing more to say on the matter.
sickpup
Old Timer
PostPosted: 11:55 - 14 Jul 2006    Post subject: Reply with quote
Siggi wrote:
Excuse me, I once stripped an entire GT550 motor down to every last nut & bolt, put it all back together again and it ran. I was only 20, and all I had was a Haynes manual. And I'd chucked the main crank out of a 3rd-story window into the lawn (just to make the job a bit more of a challenge). Middle Finger Razz
The main crank?
You mean theres more than one? Shocked
Suzuki
Roger
PostPosted: 12:09 - 14 Jul 2006    Post subject: Reply with quote
Siggi wrote:
If the arm's the 'correct' length the rod will be central. Rolling Eyes
Not true.
The arm doesn't have to position the slide rod so that it is central on the bike for the damper to work correctly. The only benefit of a central rod is asthetics.
Suzuki
Roger
PostPosted: 15:36 - 14 Jul 2006    Post subject: Reply with quote
Siggi wrote:
Or Sprint decided to be tight-arses and try to get as few sizes as possible to fit as many types of bike as possible.
That is exactly the situation I'm talking about.
Going back to the start of the argument you said "You've done something wrong if it's not clamped central"
We said "There's nothing wrong with an off-centre clamping, if that is what's required for correct functionality"
Just because YOUR damper fits exactly central and is symmetrical, doesn't mean that they all do.
I was simply explaining that mechanically it doesn't have to be central, it's just for asthetics.
And yes, companies are tight arses, and will manufacture the least things they have to to make the most money.
If the mount for a GSXR600 fits a GSXR1000, but needs a different length rod, then dispach with a different rod and have the user mount it off-centre. Works perfectly, user is happy, company make more money, what's the problem?
Suzuki
Roger
PostPosted: 15:50 - 14 Jul 2006    Post subject: Reply with quote
Mount the body centrally on the slide rod and you'll always be onto a winner.
As for the clamp on the body, is down to the fitting mechanism for each particular bike.
Some have to be mounted offcentre due to the shape of the tank. Some tanks are too high, so would get in the way of a solid mount. These have a jointed mount which makes the clam sit way off centre on the body of the damper.
Loads of pictures in THIS POST above which show your theory to be wrong.
Not that it really matters.
lllN30lll
PostPosted: 16:10 - 14 Jul 2006    Post subject: Reply with quote
PMSL
siggi cheers for the Poem in PM Laughing
Turbo R1
CRF450R
Suzuki
Roger
PostPosted: 17:23 - 14 Jul 2006    Post subject: Reply with quote
Siggi wrote:
Ideally there would be a perfect environment on all bikes for the damper units to be optimally mounted.
And why shouldn't this optimal mounting be off-centre? Laughing
Bogging off home now. Will post a picture of my steering damper later. Not sure if it's mounted centrally or not. Smile
Suzuki
Roger
PostPosted: 23:12 - 14 Jul 2006    Post subject: Reply with quote
Waddaya know, the body is clamped off centre on my gixer, yet it all works perfectly well!
Maybe the fact that the body is central on the slide rod, yet offcentre to the rest of the bike really doesn't matter after all! Wink
Laughing Razz
*cue some inane comment from siggi about why my bike/damper is shit and his is superior Rolling Eyes*
sickpup
Old Timer
PostPosted: 23:15 - 14 Jul 2006    Post subject: Reply with quote
Siggi wrote:
I suspect most of the units mount/clamp centrally, and there are a very small minority of penny-pinching units that require off-center clamping. Which means they're abortions and shouldn't be included by any sane, reasonable or rational man. Yeah. Laughing
You mean the incredibly expensive and very high quality WP damper on my blade is an abortion? Shocked
sickpup
Old Timer
PostPosted: 23:22 - 14 Jul 2006    Post subject: Reply with quote
Siggi wrote:
Well look how fucking short the arm is! Of course it's off-center, the arm is bastardized short. Why? Is there some physical reason why it couldn't be longer? Fairing in the way? Shite bike design? Laughing
Yes theres a very very good reason why the rod is that short. So when you crash the rod doesn't spear your knee which can be a problem with dampers mounted there. Laughing
The last post was made 20 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 135.58 Kb
