| lllN30lll |
 lllN30lll World Chat Champion
 Posted: 21:59 - 12 Jul 2006 Post subject: Steering damper problem, p*ssed off |
finally got my Sprint steering damper today, fitted it no problem,
got the the part where it says in on the instructions to set the bars to full lock to the left, then push the steering damper body all the way to the right until it meets the mounting point.
did it, clamped the body into place........................ and the f*cking thing won;t give me full lock to the right!!! it seems that the shaft of the damper is too short!
pain in the f*cking arse
pics, full lock to the left, as much lock to the right as i can get.
https://img.photobucket.com/albums/v707/lllN30lll/piccy-0050.jpg
https://img.photobucket.com/albums/v707/lllN30lll/piccy-0049.jpg
any idea's?
on the box that the damper came in one of the box's is ticked 50mm, other ones are 70, 100, 120, 140, 160mm whats this mean?
cheers ____________________ Turbo R1
CRF450R |
| lllN30lll |
| NSR Mick |
 NSR Mick World Chat Champion
| Finglonga |
 Finglonga World Chat Champion
 Posted: 22:37 - 12 Jul 2006 Post subject: |
That mattress is a fire hazzard!  ____________________ Andy Sez....
F.Y.Y.F.F. |
| craigs23 |
 craigs23 Mr Muscle
| Shaun |
 Shaun Likes 'em bent
| lllN30lll |
 Posted: 18:50 - 13 Jul 2006 Post subject: |
ive set it up so i get equal amount of lock both sides of the bar now.
had an email from the seller stating that a 70mm is required and i've been sent a 50mm soooo i'll have to post it off now.
best money ive ever spent though, had a quick go today and it's transformed the SRAD's handling  ____________________ Turbo R1
CRF450R |
| lllN30lll |
 Posted: 19:44 - 13 Jul 2006 Post subject: |
nope, even set with equal lock it aint in the middle of the damper
nearly is though ____________________ Turbo R1
CRF450R |
| lllN30lll |
| lllN30lll |
| True Blue |
 True Blue World Chat Champion
 Posted: 22:55 - 13 Jul 2006 Post subject: |
I take it that's an SRAD Gixxer? Don't they come with a steering damper as standard? Or was it just from the K series? ____________________ Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>> |
| sickpup |
 sickpup Old Timer
| Suzuki |
 Suzuki Roger
 Posted: 10:52 - 14 Jul 2006 Post subject: |
Siggi, the location of the main body is irrelevant providing that you have full range of movement for the handlebars.
The instructions of mounting it at full lock are correct, in that they give you full range of movement in the direction of the lock you start with, and providing the slide rod is long enough, will also give you maximum movement to the opposite lock.
Prividing the slide bar is the correct length, mounting things in a central location *should* work, but it's not guaranteed. ____________________ <Simple> no I'm shaven Jon
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map |
| dainesefreak |
 dainesefreak World Chat Champion
 Posted: 11:16 - 14 Jul 2006 Post subject: |
Thank you Honda for HESD.  |
| Suzuki |
 Suzuki Roger
| Suzuki |
 Suzuki Roger
 Posted: 11:46 - 14 Jul 2006 Post subject: |
Just cos the damper clamps at the front of the tank, and the mount point is central, doesn't mean that the slide rod is exactly central.
If the slide rod isn't central, then the body will have to be clamped off-centre to the bike too, so that it is central on the slide rod.
Nothing more to say on the matter. ____________________ <Simple> no I'm shaven Jon
| sickpup |
 sickpup Old Timer
 Posted: 11:55 - 14 Jul 2006 Post subject: |
| Suzuki |
 Suzuki Roger
| Suzuki |
 Suzuki Roger
 Posted: 15:36 - 14 Jul 2006 Post subject: |
| Siggi wrote: | Or Sprint decided to be tight-arses and try to get as few sizes as possible to fit as many types of bike as possible. |
That is exactly the situation I'm talking about.
Going back to the start of the argument you said "You've done something wrong if it's not clamped central"
We said "There's nothing wrong with an off-centre clamping, if that is what's required for correct functionality"
Just because YOUR damper fits exactly central and is symmetrical, doesn't mean that they all do.
I was simply explaining that mechanically it doesn't have to be central, it's just for asthetics.
And yes, companies are tight arses, and will manufacture the least things they have to to make the most money.
If the mount for a GSXR600 fits a GSXR1000, but needs a different length rod, then dispach with a different rod and have the user mount it off-centre. Works perfectly, user is happy, company make more money, what's the problem? ____________________ <Simple> no I'm shaven Jon
| Suzuki |
 Suzuki Roger
 Posted: 15:50 - 14 Jul 2006 Post subject: |
Mount the body centrally on the slide rod and you'll always be onto a winner.
As for the clamp on the body, is down to the fitting mechanism for each particular bike.
Some have to be mounted offcentre due to the shape of the tank. Some tanks are too high, so would get in the way of a solid mount. These have a jointed mount which makes the clam sit way off centre on the body of the damper.
Loads of pictures in THIS POST above which show your theory to be wrong.
Not that it really matters. ____________________ <Simple> no I'm shaven Jon
| lllN30lll |
 Posted: 16:10 - 14 Jul 2006 Post subject: |
PMSL
siggi cheers for the Poem in PM  ____________________ Turbo R1
CRF450R |
| Suzuki |
 Suzuki Roger
 Posted: 17:23 - 14 Jul 2006 Post subject: |
| Suzuki |
 Suzuki Roger
 Posted: 23:12 - 14 Jul 2006 Post subject: |
Waddaya know, the body is clamped off centre on my gixer, yet it all works perfectly well!
Maybe the fact that the body is central on the slide rod, yet offcentre to the rest of the bike really doesn't matter after all!
*cue some inane comment from siggi about why my bike/damper is shit and his is superior * ____________________ <Simple> no I'm shaven Jon
| sickpup |
 sickpup Old Timer
| sickpup |
 sickpup Old Timer
The last post was made 20 years, 108 days ago. Instead of replying here, would creating a new thread be more useful? |
