External Hard Drive Problem.
headlamp
PostPosted: 15:31 - 17 Jul 2006    Post subject: External Hard Drive Problem. Reply with quote
Being a sensible sort of fellow, I decided to invest in an external hard drive for back up.
Yesterday went to back up some music and pictures - by switching it on and whilst my PC recognises a Hard Drive in 'G' is fails to recognise it as a Seagate EHD and I get a message saying would I like to format the drive now? As I have already transferred loads of data across I guess that isn't a good idea.
It does the same in other USB hubs and I've tried disconnecting other devices potentially using the same hub.
Any ideas anyone? Thumbs Up
Using a mobile phone while driving a car should be made a capital offence!
map
Mr Calendar
PostPosted: 15:35 - 17 Jul 2006    Post subject: Reply with quote
Check if it exists under Device Manager. If it does then remove it. Make sure unplugged then reboot. When started plug it in again.
HTH Thumbs Up
headlamp
PostPosted: 15:53 - 17 Jul 2006    Post subject: Reply with quote
Hi Map,
It exists as 'Drive G' not as a Seagate External Hard Drive.
Mister James
I want to believe!
PostPosted: 16:13 - 17 Jul 2006    Post subject: Reply with quote
As map says, remove it from the DM, whatever it's called, and reboot the system. When you plug it back in, with any luck it will install the driver properly.
headlamp
PostPosted: 16:32 - 17 Jul 2006    Post subject: Reply with quote
Thanks! I'll try it when I get home!
headlamp
PostPosted: 20:12 - 17 Jul 2006    Post subject: Reply with quote
Right I tried that - it still doesn't work - it recognised it for a moment - then in 'My Computer' it came up Disc Drive G & still won't open! Crying or Very sad Shocked
Are there any repair kits for a Seagate EHD (250gb) - it's less than 4 weeks old!!
T1z3R
PostPosted: 20:18 - 17 Jul 2006    Post subject: Reply with quote
do what they said above but when you plug it b ack in put it straight into a USB port and not a hub.
duck my sick!
headlamp
PostPosted: 20:32 - 17 Jul 2006    Post subject: Reply with quote
Hi, it went straight into a port.. Confused
T1z3R
PostPosted: 20:35 - 17 Jul 2006    Post subject: Reply with quote
sorry, you mentioned hubs twice in the so assumed thats what you were using.
duck my sick!
Mister James
I want to believe!
PostPosted: 20:54 - 17 Jul 2006    Post subject: Reply with quote
This might be a dump question, but you haven't formatted the external drive in a format that the PC can't read have you? I'm not sure how you could, but I guess it's possible?
What's the Drive showing up as in Device Manager in the system tab of the Control Panel now?
PostPosted: 20:57 - 17 Jul 2006    Post subject: Re: External Hard Drive Problem. Reply with quote
Right click my computer > click 'disk management'
Find 'disk G', read what else it says there.
headlamp
PostPosted: 23:19 - 17 Jul 2006    Post subject: Reply with quote
This is a bit disconcerting it says - capacity 232gb free 232gb....I've already tranferred a load of stuff onto it - probably 18gb of music and pictures...I think the drive has got corrupted, but theres no way of doing a virus check.
T1z3R
PostPosted: 23:35 - 17 Jul 2006    Post subject: Reply with quote
sounds like its all gone.
bite the bullet and reformat it.
duck my sick!
headlamp
PostPosted: 23:40 - 17 Jul 2006    Post subject: Reply with quote
Shocked Shocked Shocked Crying or Very sad I'll think I'll ring up the place I got it from and get a new one! If this PC crashes between now and then I'm a divorced man!
Thanks for everyones help!!
AcIdBuRnZ
PostPosted: 01:07 - 19 Jul 2006    Post subject: Reply with quote
You did COPY the data across?
In that case just format the damn thing and copy the data again.
What's the problem? Confused
Finglonga
PostPosted: 19:16 - 19 Jul 2006    Post subject: Reply with quote
Is it one you can HOT SWAP? as in you can plug it in when the pc is on?
Some don't like that, my Maxtor external drive was plugged in to USB2 when I started using the Firewire lead instead I hot swapped it and it read that the disc was empty.
Turned everything off, re connected all the leads (making sure the hard drive was turned on) then started the pc. Everything was back as it was before I unpluged the USB lead. Thumbs Up
Andy Sez....
F.Y.Y.F.F.
The last post was made 20 years, 71 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 90.45 Kb
