Rs 125 wont start.. Typical
stevieh
PostPosted: 17:21 - 19 Jan 2006    Post subject: Rs 125 wont start.. Typical Reply with quote
Wont start, even when bumping! There is enough oil / petrol in, and the spark-plug is fine. Battery keep's depleting its power, but the bike still wont turn over when connected to a charger. I wouldnt mind, but theres a bloke coming to view the bike in 2 hours and it was running fine before! Any idea's?
Steve
firefox
PostPosted: 17:25 - 19 Jan 2006    Post subject: Reply with quote
cold weather ?. kick it over until it starts could take a while and leave it running for a while ?
stevieh
PostPosted: 17:28 - 19 Jan 2006    Post subject: sda Reply with quote
Thats just the thing, it wont start.
Harold_Shand
PostPosted: 17:36 - 19 Jan 2006    Post subject: Reply with quote
I can't help you geezer but the same thing happened when I was selling a car. Had a few problems with it, so wanted to get rid. A feller and his daughter cames to look at it, turned the key and it wouldn't start. It was horrible, like a nightmare, he came back the next day, it wouldn't start again first off but eventually got it started. His daughter loved it though and he grudgingly gave me the money for it...
I may have said it before on here, but I am not alone in wanting to tell the world to AVOID Fiats. This one looked great but was fucked by 53k.
mchaggis
PostPosted: 17:50 - 19 Jan 2006    Post subject: Reply with quote
Sometimes a little injection of carb cleaner down the plug holes can do wonders for an engine which doesn't want to start, or at least it will narrow down the problem to the fueling . Have you had the tank up lately or anything? If you had trapped or kinked a fuel line it would have problems starting.
If it isn't turning over at all, a freshly charged battery might be what it needs. If it isn't turning over even with a freshly charged battery, it's entirely possible that said battery is gubbed. Do you hear the relay clicking or making funny whining noises? If not, try a different battery that you know is good. If that still doesn't work, try shorting across the relay to effectively connect the battery to the starter directly.
The engine ran for long enough to suck more fuel into empty carburettors last time I used carb cleaner on my VT spark plug holes. Anyway, my bet would be on the battery or fuel line/ filter.
I must not be a troll...
Mmmm, Guinness
stevieh
PostPosted: 17:56 - 19 Jan 2006    Post subject: - Reply with quote
Hmm, I will have to give the battery a charge. My immediate thought was the spark-plug, but evidently it has to be the battery.
I get like a whirring noise when pressing the starter button, oh I dont know.. Today of all day's.
palmer
Fiddled Kiddy
PostPosted: 18:16 - 19 Jan 2006    Post subject: Reply with quote
you dont need a charged battery to bump start a bike...
stevieh
PostPosted: 18:18 - 19 Jan 2006    Post subject: dsf Reply with quote
true, but it wont bump...
palmer
Fiddled Kiddy
PostPosted: 18:19 - 19 Jan 2006    Post subject: Reply with quote
killswitch?
does it sound like it floods?
is there a spark?
riichy
like this fella says, all you need to do is put it in 2nd and roll it let clutch out and a bit off gas and it should bump it Thumbs Up
.......... PLOD ............ zx636 2004
Kirmit
PostPosted: 18:21 - 19 Jan 2006    Post subject: Reply with quote
I experienced a similar situation when I tried to sell my Bandit. Turned out to be the master fuse had corroded.
When riding fast, think fast. When riding slow.. speed up.
Grey Honda Cityfly 125 || Red Suzuki Bandit 600 & Blue Suzuki SV650SK5|| Red Honda VTR 1000-F2
stevieh
PostPosted: 18:22 - 19 Jan 2006    Post subject: d Reply with quote
I shall say again.. it doesnt bump. I have no idea as to why it wont, but it wont. Im stumped, I think I may need to take it to a mechanic.
stevieh
PostPosted: 18:30 - 19 Jan 2006    Post subject: ds Reply with quote
Wont that damage it? Okay, I'll give it a go!
PostPosted: 18:43 - 19 Jan 2006    Post subject: Re: ds Reply with quote
I always bump start bikes by just knocking them into gear whilst moving. Has the advantage that it is far easier to push the bike and build up some speed with the bike in neutral that in gear with the clutch pulled.
Is the engine turning over when you use the starter motor? It can happen with some starter motors that the starter spins away happily and very quickly on its own but does not engage with the engine. Are you getting a spark?
I have also seen an RS which would not start on the starter motor (would crank over fine) but could be bump started if you built up enough speed. Cause was the gap from the ignition pickup to the flywheel was too large and so only managed to trigger the ignition at a greater speed than the start (or a normal attempt at bumping) would generate.
stevieh
PostPosted: 18:57 - 19 Jan 2006    Post subject: fds Reply with quote
So you reckon if I use nuetral build up enough speed and then drop into 1st it may work? Its just about breaching the ignition gap?
palmer
Fiddled Kiddy
PostPosted: 19:01 - 19 Jan 2006    Post subject: Reply with quote
or just put it in first and keep pushing it until it starts?
stevieh
PostPosted: 19:03 - 19 Jan 2006    Post subject: ada Reply with quote
Aye, its pretty hard. theres lots of resistance in 1st gear.
PostPosted: 19:07 - 19 Jan 2006    Post subject: Re: fds Reply with quote
Might well work. Worth a try. But lift the tank up, whip the plug out and check it is sparking first (and check if the engine is actually turning over rather than just the starter motor).
From memory the gap is meant to be around 0.5mm, and on the bike that was misbehaving it was well over double that.
palmer
Fiddled Kiddy
PostPosted: 19:12 - 19 Jan 2006    Post subject: Reply with quote
lots of resistance in 1st?
its a 2t 125... should be ok to push in gear.
ive done it to a 4t 250 crosser a few times.
stevieh
PostPosted: 19:14 - 19 Jan 2006    Post subject: .. Reply with quote
Different set up entirely then. thats like saying..
"omg I pushed my car once, it was hard but it shouldnt have been because I pushed my mates scooter the other day and it was easy!!"
PostPosted: 19:14 - 19 Jan 2006    Post subject: Reply with quote
Any resistance is bad and slow you down in getting some speed up.
There is a gap of 185 days between these two posts...
jaguar65uk
PostPosted: 11:26 - 24 Jul 2006    Post subject: Reply with quote
I am having similar trouble with my RS. The starter motor would spin up but the cog wouldn't engage the flywheel properly. The starter cog would spin but not lock into place and just chip itself. Eventually, the motor gave up and rotated very slowly just before the electrics packed in. When I removed the tank to observe the damage, it turned out the positive terminal had melted Confused (anyone tell me why?)
At this point I unplugged the starter motor and tried to bump start a little but to no avail. I'll try knocking her into first and try using a different spark plug. I think the problem lies with the battery not having enough charge to supply the motor with a large enough voltage to overcome compression. As the positive terminal is half melted anyway, I have bought a new one that has not yet arrived but I think it would be worthwhile to take a look at the starter motor as well.
Does your problem resemble mine?
Past: Aprilia SR 50, Aprilia RS 125
Current: Aprilia RS 125, Yamaha Teos 125
KyleH
PostPosted: 23:13 - 24 Jul 2006    Post subject: Reply with quote
the problem is
1. its an aprilla
2. it a 2 stroke
3. its itallian
You shouldnt have to bump start it at all, get your self a battery optimiser
The terminal would only melt if a fuse failed or faulty wiring
unless youve replaced it with the wrong terminal (i doubt that)
Check for spark if there no spark 1st battery (as said) then you ant to check your HT lead using an Ammeter its should read i for infinite
Either that or just take it too a mechanic Smile
The last post was made 20 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.26 - MySQL Queries: 15 - Page Size: 119.12 Kb
