How to remove the top of the engine on a ZXR400? PICS NOW!
Bike Chat Forums Index -> The Workshop Goto page 1, 2, 3, 4  Next
Yoshi
PostPosted: 16:33 - 31 Jul 2006    Post subject: How to remove the top of the engine on a ZXR400? PICS NOW! Reply with quote
Hi I need to look at the valves and cylinders, how hard is it to get it all off so I can see them. Think there is something in there or it's dropped a valve, long story but how to get it off, the manuals a bit crap...
Present: GS650 Katana - Getting ready for summer touring!
Past: TS50, RS50, ZXR400, LT80, TS250
Barry_M2
PostPosted: 17:22 - 31 Jul 2006    Post subject: Reply with quote
I done this years ago on a L model ZXR400. It's all really tight around that area. From what I remember, its tank off, carbs and airbox off, plug caps out then rocker cover off.
But, when you come to take the rocker cover off I remember it being a real pain to get it over the cam wheels as its so tight against the frame. But I did manage it.
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
Yoshi
PostPosted: 18:52 - 31 Jul 2006    Post subject: Reply with quote
Yeah I am as far as the rocker cover, now theres two things attached to the frame which are something to do with the electrics.
Did you take them off or unbolt it with them on, cause they are in the way.
Barry_M2
PostPosted: 19:48 - 31 Jul 2006    Post subject: Reply with quote
I think you must mean the coils?
Yeah, unbolt and move them. You'll find that the cam cover is a real pain to get off, it just seems to hit everthing just as you think your getting somewhere!
Yoshi
PostPosted: 20:47 - 31 Jul 2006    Post subject: Reply with quote
OK for the 4 bolts on the rocker cover, will they need to be bolted back in with a torque wrench, dad says they might have to be?
At the moment I can undo them without much effort using a spanner. But this bike been messed about with in the past
(previous owner) so that could be wrong.
Yoshi
PostPosted: 21:25 - 31 Jul 2006    Post subject: Reply with quote
Ok he meant the bolts holding down the cams which need to be torque wrenched, I see the torques in the manual.
Can I use any silicon sealant or does it have to be Kawasaki branded? any I guess?
Anyone got any tips for getting this rocker cover off, it's a pain!
This my first time messing around with engines sorry for all the questions!
PostPosted: 21:27 - 31 Jul 2006    Post subject: Reply with quote
I have takent the rocker cover off with the engine in the frame, but if you suspect a dropped valve and are intending to take the head off I would be tempted to drop the engine out.
You should not need a torque wrench to undo the rocker cover bolts.
Barry_M2
PostPosted: 22:03 - 31 Jul 2006    Post subject: Reply with quote
Yoshi - What makes you suspect its a dropped valve?
Yoshi
PostPosted: 22:28 - 31 Jul 2006    Post subject: Reply with quote
OK got the rocker cover off now, my dad's friend is gonna help me he is a bit more mechanical. Also he got a torque wrench to lend me.
I'm going to study the manual, see how much work it looks like to get the head off.
How much effort is it to drop the engine out?
I don't know if its a dropped valve but basically when I took the carbs off (to put restrictors in) there was a bolt sitting on an inlet valve (gave me a surprise) so I removed it, put it back together and it made a horrible noise when i tried starting it, took restrictors out, same thing, so I'm thinking if that bolt was in there what else was in there etc Confused it could have damaged cylinder/piston/valve?
Plus I want to learn this kind of thing, after this I am going to buy a cheap bike to strip down/mess around with which I don't have to worry about messing up.
Finglonga
PostPosted: 22:41 - 31 Jul 2006    Post subject: Reply with quote
I can see this ending in tears, are you sure you are capable of a stripdown like this? If not don't do it, bite the bullet and get it into a garage or it could cost alot to put things right.
Andy Sez....
F.Y.Y.F.F.
Barry_M2
PostPosted: 23:06 - 31 Jul 2006    Post subject: Reply with quote
Yoshi wrote:
there was a bolt sitting on an inlet valve (gave me a surprise) so I removed it, put it back together and it made a horrible noise.....
You wouldn't have seen the bolt on an inlet valve just with the carbs off. Can you take a pic of where you saw the bolt / removed it from. Thumbs Up
Good on you for wanting to learn. Very good idea getting a knackered motor to play with. You'll soon realise its not really all that complicated. Thumbs Up
edd
PostPosted: 00:57 - 01 Aug 2006    Post subject: Reply with quote
defo fix it yourself, you might need a few tools and bent valves can sometimes be a real bitch to sort out but you will learn from it. Thumbs Up Taking the head off your bike will mean you need a new head gasket which arent cheap, and you will want to be replacing your base gasket if it is held on with the same studs (or infact if a zxr 400 has a seperate block from the cases im unfamiliar with them)
Bluespark Automotive - Diesel Tuning for Performance and Economy
Yoshi
PostPosted: 01:34 - 01 Aug 2006    Post subject: Reply with quote
Finglonga wrote:
I can see this ending in tears.
Me too Laughing nearly already come to it coz i need the bike to see a girl now I can't go and see her, haven't got a car or anything! Crying or Very sad oh well plenty more fish in the sea I guess!
The bolt was just sitting in the hole which leads to the valves, at the bottom it splits into 2, for the 2 inlet valves of each cylinder. It was in there, Pics tomorrow.
I'm not going to do anything I don' t think I'll be able to undo, I'm ok at this kind of thing, learnt how to build/fix computer hardware quickly which is a bit similar (alot easier though). I'll save time and cost of taking to a garage and worst case I'll have to take it to the garage which I would have to do now anyway.
Is it required to buy a gasket everytime you remove the head? Where can I get one, looked on most of the parts websites but none seem to have them for the ZXR400.
Thanks for all the advice,
Matt
PostPosted: 01:51 - 01 Aug 2006    Post subject: Reply with quote
I would be a bit worried about where the bolt came from and how many others had followed it. Only ones I can think of are for holding the airbox onto the carbs on a ZXR400, and if one of those was loose you would need to be exceptionally lucky for it to get that far without dropping into the engine properly.
If you remove the cylinder head then you will definatly have to replace the head gasket.
The rocker cover gasket is probably a rubber one and can be reused as long as it is not damaged.
veeeffarr
PostPosted: 02:13 - 01 Aug 2006    Post subject: Reply with quote
Ride it, it'll blow off eventually Razz
Yoshi
PostPosted: 12:54 - 01 Aug 2006    Post subject: Reply with quote
I was worried, it gave me a shock Laughing it must have been in there when I got the bike, I'm 99% sure I didn't get it in there.
It wasn't one of those bolts although I did think of it but I have them all, plus it shouldn't get through the carb? I'm talking about this time taking it off though, could have been when someone did it in the past. The bike's been messed about with, can tell from how its been put together it's been in parts before and it's also been down the road (noticed signs since buying, bought it unseen off ebay Mad )
Yoshi
PostPosted: 12:56 - 01 Aug 2006    Post subject: Reply with quote
Oooh at least it will do speeds to cause it to blow off Laughing OK well it doesn't go at all but it will when it works!
PostPosted: 22:02 - 01 Aug 2006    Post subject: Reply with quote
Can you post a pic of the bolt? Pretty much any M6 or smaller bolt would likely get through the carb and trash the engine within a very short space of time with the engine running.
ram_doom
PostPosted: 22:41 - 01 Aug 2006    Post subject: Reply with quote
Mine blew its bottom off Cool good luck! These old zxr motors are semi complicated, made worse with the teeny dimensions of the thing...
TL1000s, KDX200
Paddy Blake
PostPosted: 00:06 - 02 Aug 2006    Post subject: Zxr400 Reply with quote
Remember to losen and tighten the head bolts a little at a time and
losen from outside to inside in a x. Just check the manual for this
or you could warp the head. Thumbs Up
Yoshi
PostPosted: 01:45 - 02 Aug 2006    Post subject: Reply with quote
It says in the manual "Before removing the cam chain tensioner, position the crankshaft at #1, 4 piston TDC"
I kind of understand, but what does TDC mean? It wants me to move the crankshaft so the TDC mark in inline with the Timing mark?
Also does the cam chain need to come off or just the tensioner??
And what does the manual mean by damper rubber, says I need to remove it?
Thanks for all advice, also will put up a pic of where that bolt was tomorrow been busy today Laughing
also my dads friend said about loosening/tightening in the X shape etc but still thanks.
ram_doom
PostPosted: 01:52 - 02 Aug 2006    Post subject: Reply with quote
TDC - Top Dead Center
When a piston is at its highest point, furthest away from the crankshaft Thumbs Up
TL1000s, KDX200
PostPosted: 09:55 - 02 Aug 2006    Post subject: Reply with quote
TDC as above.
The cam chain will need to be unhooked from the cams, and to do that you will need to remove the tensioner.
To be honest from your comments so far you are displaying a lack of knowledge that could get expensive when taking the head off. I would suggest doing some reading up of generic engine books before going any further (eg, might not tell you anything about the ZXR engine but reading a copy of "How To Modify Your Mini" by David Vizard will teach you a lot about the basics of an engine).
Yoshi
PostPosted: 10:26 - 02 Aug 2006    Post subject: Reply with quote
OK thanks.
I am inexperienced with engines, but it'll remain that way unless I get stuck in and have a go. I won't do anything that I don't think I can undo plus I have someone helping me. Worst case I just take it to the garage and let them fix it, might cost a bit though.
Thanks,
Matt
Yoshi
PostPosted: 13:58 - 02 Aug 2006    Post subject: Reply with quote
To get it to TDC 1,4 Do I use a spanner to line them up or an allen key in the middle? Also does it go clockwise or anti clockwise, I'm assuming clockwise??
Oh yes and in the manual the F is above the T but on mine the F is below the T, is this a problem or should I still just line up the T???
I attached an image from the manual to show what I mean.
Thanks
The last post was made 20 years, 35 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 132.24 Kb
