| Yoshi |
 Yoshi Traffic Copper
| Barry_M2 |
 Barry_M2 World Chat Champion
 Posted: 17:22 - 31 Jul 2006 Post subject: |
I done this years ago on a L model ZXR400. It's all really tight around that area. From what I remember, its tank off, carbs and airbox off, plug caps out then rocker cover off.
But, when you come to take the rocker cover off I remember it being a real pain to get it over the cam wheels as its so tight against the frame. But I did manage it. ____________________ ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
https://www.bikechatforums.com/profile.php?mode=viewprofile&u=4332 |
| Yoshi |
| Barry_M2 |
 Posted: 19:48 - 31 Jul 2006 Post subject: |
I think you must mean the coils?
Yeah, unbolt and move them. You'll find that the cam cover is a real pain to get off, it just seems to hit everthing just as you think your getting somewhere! ____________________ ZXR750R (M2) - For the road.
| Yoshi |
| Yoshi |
| Barry_M2 |
| Yoshi |
 Posted: 22:28 - 31 Jul 2006 Post subject: |
OK got the rocker cover off now, my dad's friend is gonna help me he is a bit more mechanical. Also he got a torque wrench to lend me.
I'm going to study the manual, see how much work it looks like to get the head off.
How much effort is it to drop the engine out?
I don't know if its a dropped valve but basically when I took the carbs off (to put restrictors in) there was a bolt sitting on an inlet valve (gave me a surprise) so I removed it, put it back together and it made a horrible noise when i tried starting it, took restrictors out, same thing, so I'm thinking if that bolt was in there what else was in there etc it could have damaged cylinder/piston/valve?
Plus I want to learn this kind of thing, after this I am going to buy a cheap bike to strip down/mess around with which I don't have to worry about messing up. ____________________ Present: GS650 Katana - Getting ready for summer touring!
Past: TS50, RS50, ZXR400, LT80, TS250 |
| Finglonga |
 Finglonga World Chat Champion
| Barry_M2 |
| edd |
 edd Nearly there...
 Posted: 00:57 - 01 Aug 2006 Post subject: |
defo fix it yourself, you might need a few tools and bent valves can sometimes be a real bitch to sort out but you will learn from it. Taking the head off your bike will mean you need a new head gasket which arent cheap, and you will want to be replacing your base gasket if it is held on with the same studs (or infact if a zxr 400 has a seperate block from the cases im unfamiliar with them) ____________________ Bluespark Automotive - Diesel Tuning for Performance and Economy |
| Yoshi |
 Posted: 01:34 - 01 Aug 2006 Post subject: |
| Finglonga wrote: | I can see this ending in tears. |
Me too nearly already come to it coz i need the bike to see a girl now I can't go and see her, haven't got a car or anything! oh well plenty more fish in the sea I guess!
The bolt was just sitting in the hole which leads to the valves, at the bottom it splits into 2, for the 2 inlet valves of each cylinder. It was in there, Pics tomorrow.
I'm not going to do anything I don' t think I'll be able to undo, I'm ok at this kind of thing, learnt how to build/fix computer hardware quickly which is a bit similar (alot easier though). I'll save time and cost of taking to a garage and worst case I'll have to take it to the garage which I would have to do now anyway.
Is it required to buy a gasket everytime you remove the head? Where can I get one, looked on most of the parts websites but none seem to have them for the ZXR400.
Thanks for all the advice,
Matt ____________________ Present: GS650 Katana - Getting ready for summer touring!
 Posted: 01:51 - 01 Aug 2006 Post subject: |
I would be a bit worried about where the bolt came from and how many others had followed it. Only ones I can think of are for holding the airbox onto the carbs on a ZXR400, and if one of those was loose you would need to be exceptionally lucky for it to get that far without dropping into the engine properly.
If you remove the cylinder head then you will definatly have to replace the head gasket.
The rocker cover gasket is probably a rubber one and can be reused as long as it is not damaged.
| veeeffarr |
 veeeffarr Super Spammer
| Yoshi |
 Posted: 12:54 - 01 Aug 2006 Post subject: |
| Kickstart wrote: | I would be a bit worried about where the bolt came from and how many others had followed it. Only ones I can think of are for holding the airbox onto the carbs on a ZXR400, and if one of those was loose you would need to be exceptionally lucky for it to get that far without dropping into the engine properly. |
I was worried, it gave me a shock it must have been in there when I got the bike, I'm 99% sure I didn't get it in there.
It wasn't one of those bolts although I did think of it but I have them all, plus it shouldn't get through the carb? I'm talking about this time taking it off though, could have been when someone did it in the past. The bike's been messed about with, can tell from how its been put together it's been in parts before and it's also been down the road (noticed signs since buying, bought it unseen off ebay ) ____________________ Present: GS650 Katana - Getting ready for summer touring!
| Yoshi |
| ram_doom |
 ram_doom World Chat Champion
 Posted: 22:41 - 01 Aug 2006 Post subject: |
| Paddy Blake |
 Posted: 00:06 - 02 Aug 2006 Post subject: Zxr400 |
Remember to losen and tighten the head bolts a little at a time and
losen from outside to inside in a x. Just check the manual for this
or you could warp the head.  |
| Yoshi |
 Posted: 01:45 - 02 Aug 2006 Post subject: |
It says in the manual "Before removing the cam chain tensioner, position the crankshaft at #1, 4 piston TDC"
I kind of understand, but what does TDC mean? It wants me to move the crankshaft so the TDC mark in inline with the Timing mark?
Also does the cam chain need to come off or just the tensioner??
And what does the manual mean by damper rubber, says I need to remove it?
Thanks for all advice, also will put up a pic of where that bolt was tomorrow been busy today
also my dads friend said about loosening/tightening in the X shape etc but still thanks. ____________________ Present: GS650 Katana - Getting ready for summer touring!
| ram_doom |
 Posted: 01:52 - 02 Aug 2006 Post subject: |
TDC - Top Dead Center
When a piston is at its highest point, furthest away from the crankshaft  ____________________ TL1000s, KDX200 |
 Posted: 09:55 - 02 Aug 2006 Post subject: |
TDC as above.
The cam chain will need to be unhooked from the cams, and to do that you will need to remove the tensioner.
To be honest from your comments so far you are displaying a lack of knowledge that could get expensive when taking the head off. I would suggest doing some reading up of generic engine books before going any further (eg, might not tell you anything about the ZXR engine but reading a copy of "How To Modify Your Mini" by David Vizard will teach you a lot about the basics of an engine).
| Yoshi |
| Yoshi |
The last post was made 20 years, 36 days ago. Instead of replying here, would creating a new thread be more useful? |
