600 wheelies
steveh
PostPosted: 22:09 - 06 Aug 2006    Post subject: 600 wheelies Reply with quote
okay, yes its another one of those "how do i wheelie" threads, what im basicly after is some tips on doing "safe" wheelies i.e not flipping the bike ect, starting off a total noob with big bike wheelies, were should i start?
Power wheelies? or clutching it in 1st?
what sort of rpm and speed should i be starting at to work myself up?
Im on a thundercat 600.
any advice that will stop me killing myself, others and the bike would be great.
Id like to get some of you sparks if you would be so kind.
Steve.
Rookie
PostPosted: 22:57 - 06 Aug 2006    Post subject: Reply with quote
Mr. Green Thundercat wheelies are great.
Pull off in 1st gear. Make sure you're warmed up properly, or you'll put some undue strain on the engine.
Now 8k is the powerband kick in, but I find it easier to accelerate to 7k and then wrench the throttle back. There's not a great need to go all the way back, especially when you're just starting. About 3/4 throttle should see the front wheel lift slightly. At 7k you'll have a much slower, controlled lift. I find if I pull at 8k the front just rockets up and I brick it, and it slams back down. If I go at 7k I can get some decent, sustained wheelies going before I run out of power, because it doesn't ever reach the balance point. You can feel it struggling to gain height, so there's no 'Poo! Better stop!' thought. You just keep it there until it runs out of steam.
Basically just pull the throttle back at 7k or so, don't be a pussy about it. You'll definitely feel the front wheel lift and you'll snap it shut. The art is mastering that snap impulse and keeping it on a bit, to sustain the wheelie a bit. I'm still working on that, and I do maybe 20 or so wheelie attempts a week, for the last 4 months.
Gazdaman
I did a trackday!!!
PostPosted: 23:03 - 06 Aug 2006    Post subject: Reply with quote
20 wheelies a week x 4 months = new head bearings.
Cool
Gaz
Sparks!
Sir Tart-a-lot
PostPosted: 23:06 - 06 Aug 2006    Post subject: Reply with quote
Cool
Gaz
I do 20 x 4 wheelies per hour and I still haven't needed to replace head bearings or fork seals! be smooooooth Cool
steveh
PostPosted: 23:30 - 06 Aug 2006    Post subject: Reply with quote
cheers for the replys just starting to get used to it, but im clutching it all the time, not sure why i feel better doing it, altho it does feel very unpredictable.
Im just really worried about fliping it Sad
Steve.
camcam
PostPosted: 23:49 - 06 Aug 2006    Post subject: Reply with quote
Sparks! wrote:
Cool
Gaz
ive witnessed your wheelies the landind aint always smooth Very Happy
do we need to remind one about the can doing a flip in the vid you made.
could you post it again (the whole video) its a good vid with good music
laugh now cry later
SUZUKI GSXR600 98 SRAD RED/BLACK ***sold gonna miss you***
SUZUKI GSXR750 '00 K1 SHAPE BLUE/WHITE
Sparks!
Sir Tart-a-lot
PostPosted: 23:52 - 06 Aug 2006    Post subject: Reply with quote
Yer back when I was learning I wasn't /always/ perfectly smooth Wink but I still haven't had to replace the seals or bearings so can't be too bad Mr. Green
The can fell off cos the bolt clamp had snapped! Laughing video is Here although it's kinda old now Laughing
p.s do the police still patrol that ind. estate?
PostPosted: 23:57 - 06 Aug 2006    Post subject: Reply with quote
[off topic]
Were you at ace cafe yams?
Thought we saw your bike, but didn't notice you Confused.
Sparks!
Sir Tart-a-lot
PostPosted: 00:02 - 07 Aug 2006    Post subject: Reply with quote
G wrote:
[off topic]
Nope wasn't there, bikes still in pieces altho almost finished now.. knew there would be a big police presence anyway so didn't bother going on that part.. last time I went to the ace I wheelied past a undercover cop car and nearly got nicked for it Laughing
If it was another red 600 f sport with a crash cage it was probably my mate called Exo. similar looking bike to mine but without the yellow stripes, although I've changed the bars on mine now.
GearboxGeezer
PostPosted: 00:49 - 07 Aug 2006    Post subject: Reply with quote
Whys your bike in bits, did you crash?
Sparks!
Sir Tart-a-lot
PostPosted: 00:52 - 07 Aug 2006    Post subject: Reply with quote
no I've been changing the bars over as per the pic, not finished yet, still needs headlight, grips and something done with the indicators.
mad4it028
PostPosted: 01:30 - 07 Aug 2006    Post subject: Reply with quote
this is how i wheelie(you will find your own way)
1..roll the throttle hard
2... as soon as the wheel lifts knock it in to 2nd with out useing the clutch
3.. now very light adjustments on the throttle ((roll dont snatch)
to keep your balance point
4... always cover the rear brake if you get to high press brake
5... if 2nd gears not fast enough 4 ya repeat step 2 in to 3rd gear
most importantly take your time it wont all come at once ive been wheelieing for years and still fucked up the other week on a 250cc crosser n broke my shoulder
DEN MONKEY
PostPosted: 08:03 - 07 Aug 2006    Post subject: Reply with quote
Yeah so let's follow your advice then Thumbs Up seems to be working well for you Very Happy
meh
Misc
PostPosted: 09:44 - 07 Aug 2006    Post subject: Reply with quote
When shuld you pull/get on the throttle on a R6, i think the powerband is 10k?
PostPosted: 09:48 - 07 Aug 2006    Post subject: Reply with quote
Play and see what feels right.
10k should definitely get it up - should be able to start lower.
For power wheelies it's often best to start high (where it's easier) and bring it down lower as you get used to it to give you more revs to play with.
Misc
PostPosted: 10:04 - 07 Aug 2006    Post subject: Reply with quote
Hopfully i'll try & won't brick it. Smile
jonboy22
PostPosted: 11:33 - 07 Aug 2006    Post subject: Reply with quote
I've not intentionally wheelied yet but a couple of times have filled my kecks when over taking in second cracking the throttle open, going up for third but only finding second again, oh and the nose hoiking up off the tarmac.
I'm on a Gixxer 600 so assume that if I want to I can just twist it fully open in first at around 6k-7k??
To be honest though I think I would much prefer the clutch method but at the moment I'm just getting jolted forward and there's not alot else going on Sad .
Zanith
PostPosted: 12:20 - 07 Aug 2006    Post subject: Reply with quote
Does this sort of stuff work on all 600's or would it only apply to super sport's?
I.E would it work on a 1999 Fazer 600.
I've been interested to try sometime in the near future but wanted to find a safe location to learn first.
Gazdaman
I did a trackday!!!
PostPosted: 12:47 - 07 Aug 2006    Post subject: Reply with quote
The 'lesser' 600s i.e bandits fazers etc can wheelie for sure.
It'll just need a bit of clutch abuse to get it up to the balance point. I've only ever had the front up off power on the bandit once.
And that was in first and only skipped along the ground.
Gaz
phk6
PostPosted: 13:12 - 07 Aug 2006    Post subject: Reply with quote
i wheelied my cb with a little bit of cluth off the lights which i dint expect it to do as it was a copmplete accident, and i dint think a 33bhp cb would wheelie that easy, i shat my kegs lol
Current .. 2008 BMW R 1200 GS Adventure ..
Before .. 2003 Yamaha Fazer 1000 .. 2004 Kawazaki Z1000 .. 2003 Suzuki Sv1000s .. 1999 zx6r Track Bike .. 1999 CB 500 Cup ..
/Phil
steveh
PostPosted: 01:09 - 08 Aug 2006    Post subject: Reply with quote
getting frustrated, as im only popping the front clutching in first, its not the bike its me, perhaps the ste isnt ment to wheelie Razz
Steve.
hazza
PostPosted: 01:37 - 08 Aug 2006    Post subject: Reply with quote
so when you sell your bikes sparks do you say 'one careful owner'?
lol watched the video id cry if i dropped my bike like that Laughing
The last post was made 20 years, 71 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 117.1 Kb
