Seized swingarm bolt removal
Richard1987
PostPosted: 23:31 - 11 Aug 2006    Post subject: Seized swingarm bolt removal Reply with quote
Hi, Whilst my bike is off the road, i have decided to clean the whole bike up a bit as it was looking a bit manky in those "hard to reach" places
This is the bolt which is causing me some grief now
https://i4.photobucket.com/albums/y114/parsons2005/54ab10d1.jpg
The nut on the other side (also helps to hold the exhaust) comes off nice and easy.
https://i4.photobucket.com/albums/y114/parsons2005/c244c6dd.jpg
Tried hitting it but not that hard as to damage the threads
Any ideas?
Thanks, Richard
"sorry for the crappy pics. think i got a little bit too close"
add me to your msn messenger contacts : [email protected]
Jebus
PostPosted: 23:57 - 11 Aug 2006    Post subject: Reply with quote
bit of heat mabye that can help or loads of penertration fluid, tried putting a decent socket on it and jumping on the ratcheted one swift kick or hit can help disloge it more than pulling hard
2nd time around Smile CBT: 8/9/11
125 Varadero
syl
PostPosted: 00:04 - 12 Aug 2006    Post subject: Reply with quote
Heat, penetration fluid (there's far better stuff than WD40) or impact driver.
Current bike: Kawasaki Z750S
Richard1987
PostPosted: 00:10 - 12 Aug 2006    Post subject: Reply with quote
Dont have access to heat till monday, cant wait that long Smile
Dont like the idea of jumping on a rachet, sounds like the ideal way to round off a head by doing that Rolling Eyes
Might just leave it stuck and leave swingarm attached.
Jebus
PostPosted: 00:13 - 12 Aug 2006    Post subject: Reply with quote
jump the wrong word, a quick stamp is all that needed.
125 Varadero
Bezzer
PostPosted: 00:24 - 12 Aug 2006    Post subject: Reply with quote
Don't hit the bare spindle, put the nut back on as far as you can but leaving a bit of space behind it so it can move, put a piece of hardwood or soft alloy, if you've got it, over the nut and hit that. If the nut is nearly full on you can give it a fair clout without damaging the threads.
finpos
PostPosted: 00:26 - 12 Aug 2006    Post subject: Reply with quote
There's a couple of old threads about getting those bloody things out. When they get stuck, they get proper stuck because they rust into the bushes or bearings burried pretty deep inside the swingarm. That means "gentle" methods won't work on it and you have to resort to a sledgehammer and accept you're going to end up breaking something.
Although I did once get one out by soaking it diesel for 2 weeks Smile
Unless you are really comitted, just leave it as is and work around it.
finpos.
crazymotorbik...
PostPosted: 01:49 - 12 Aug 2006    Post subject: Reply with quote
Hey,
I had the exact same problem a few months ago. The only way i got mine out was using a Hydraulic Pusher/Puller.
If you can borrow one of these u'll have it out in under 10 minutes.
Cheers,
Shaun.
T1z3R
PostPosted: 04:07 - 12 Aug 2006    Post subject: Reply with quote
had the same problem on my CRM. simon (babykat250) took the frame to college and removed it with their gear.
it'll likely need replacing anyway if its that stuck so try a 3/8th extension against the end of the bolt and hammer it out.
duck my sick!
Whosthedaddy
PostPosted: 16:23 - 12 Aug 2006    Post subject: Reply with quote
Sorry, I'm confused.
Is the bolt seized and wont turn, or is the spindle seized and cant be hammered out?
Richard1987
PostPosted: 18:04 - 12 Aug 2006    Post subject: Reply with quote
Its the actual spindle that goes through the swingarm and through the frame, The nut is free
Ive got it to move about 1 - 2 mm by hitting it hard with a hammer on the thread side, but its still Very stuck
Whosthedaddy
PostPosted: 18:09 - 12 Aug 2006    Post subject: Reply with quote
I did'nt have any problems with removing my rear spindle, just some good hard taps with a hammer. Hit it, dont just tickle it Laughing
You could always place a piece of wood against the metal so as not to damage the threads too much. I found that using something like a socket head or extension was handly for hammering it out once its 'enetered' the frame, then just wiggle and pull with clamps from the other side.
Good luck
finpos
Fill the gaps on both sides of the spindle with penetrating fluid, knock it back in, wait a few hours, try again.
If you get another mm out of it, repeat until it comes out/you get bored Smile
finpos.
Whosthedaddy
PostPosted: 18:10 - 12 Aug 2006    Post subject: Reply with quote
finpos.
Hammer one way then the other and repeat Thumbs Up
Its the same as if you have a tight seized nut or screw. If you tighten a 1/4 turn it may actually loosen it enough to be removed Eh?
Richard1987
PostPosted: 18:16 - 12 Aug 2006    Post subject: Reply with quote
my other H100 was never this bad, small tap and it was free. It is moving a little more with wd40 and more hitting, so ill carry on with that for now Smile
I guess ill be back later to ask about re-threading Wink
Whosthedaddy
PostPosted: 18:17 - 12 Aug 2006    Post subject: Reply with quote
Just give a damn good greasing before refitting and it'll be fine next time.
Gradog
PostPosted: 19:09 - 13 Aug 2006    Post subject: Reply with quote
finpos.
Its just as whoesthedaddy says, but are you trying to do it with the rear wheel in place (going by picture)? If so your gonna really struggle.
Grey haired bikers don't get that way from pure luck. Only a biker knows why a dog sticks his head out of the car window.
Richard1987
PostPosted: 20:18 - 13 Aug 2006    Post subject: Reply with quote
The wheel was out when i tried it, but put it back in after i had 1/2 given up with it Smile
Then taken some snaps / cried for help Embarassed
Well its moved about 2 inches, but its still stupidly tight, ive just put it back and will leave it for now, Thanks for the help and advice
Richard
ram_doom
PostPosted: 20:31 - 13 Aug 2006    Post subject: Reply with quote
Good luck
"you see, removing a seized spindle, is very much like making love to a beautiful woman..."
Can you lay it on its side and pour some suitable penetrating substance down the length of the spindle and leave it for a couple of hours Thumbs Up
TL1000s, KDX200
Whosthedaddy
PostPosted: 04:53 - 14 Aug 2006    Post subject: Reply with quote
ram_doom wrote:
Good luck
Ram_Doom A.K.A Swiss Tony Laughing Thumbs Up
Jubal
PostPosted: 08:52 - 14 Aug 2006    Post subject: Reply with quote
If you've moved it 2" you have no problems, it's when they don't move at all is the time to worry.
The last post was made 20 years, 5 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 112.54 Kb
