*urgent* (sort of) indicator relay box
Essex_Mike
PostPosted: 18:56 - 13 Aug 2006    Post subject: *urgent* (sort of) indicator relay box Reply with quote
hi, i think i may have found the problem with my indicators that i spoke about on a different post.
i was looking for the indicator realy box. looking in my haynes manual to locate it. found it on the bike. well, the problem is - ITS NOT THERE. the clips where it is spose to be are there.
so is there a possibility, even if its a slim one. thats the indicator relay box could fall off? sounds stupid as from my haynes manual it looks like the clips are sturdy enough to hold it there. but could anyone get back to me on this quickly.
cheers, Mike
CBT - Passed - 14/07/2006 Theory - Passed - 19/08/2006 A2 test - Passed -19/07/2007
Previous Bike - Suzuki EN125
Current Bike - Suzuki GS500F
Gradog
PostPosted: 19:12 - 13 Aug 2006    Post subject: Reply with quote
I think it very unlikely. You would have three wires dangling if it did.
Grey haired bikers don't get that way from pure luck. Only a biker knows why a dog sticks his head out of the car window.
Essex_Mike
PostPosted: 19:31 - 13 Aug 2006    Post subject: Reply with quote
ok, i have just checked again, and can't see it anywhere Confused
carsounds_dan
PostPosted: 21:31 - 13 Aug 2006    Post subject: Reply with quote
is there any wires there? because if there is, one will be a perminant live which u do not want shorting out, there should also be an earth, an input (from the switch) and an output.
dan
add me on msn for info on CAT 2 immobalisers, and cheap fitting in the crawley area
Jebus
PostPosted: 21:39 - 13 Aug 2006    Post subject: Reply with quote
dont think it could of fallen off since it would have just hung on the wires, its pretty odd may have to get down to a breakers yard to get a new one.
2nd time around Smile CBT: 8/9/11
125 Varadero
Essex_Mike
PostPosted: 21:40 - 13 Aug 2006    Post subject: Reply with quote
the only loose wires around under the seat are like little plugs, but none of em are right shape to connect into each other. and i think they were disconnected by past owners.
carsounds_dan
PostPosted: 21:42 - 13 Aug 2006    Post subject: Reply with quote
those plugs will go onto the relay box, go to the breakers in the morning. check all your fuses aswell coz it could have knocked one of them out if its "fallen out"
Essex_Mike
PostPosted: 21:46 - 13 Aug 2006    Post subject: Reply with quote
ok, well i can't see it being the fuse. as the tzr of mine only has one. and would mean all my lights getting knocked out wouldn't it?
edit: to make it easier to describe these plugs i'll take a pic of them tomorrow and post it on here. easier than explaining tbh and giving you the rong details.
carsounds_dan
PostPosted: 21:48 - 13 Aug 2006    Post subject: Reply with quote
yes, sorry maybe i wasnt clear..
the indicators not working will most probably be due to the relay box, but when it came out it maybe have blown a fuse on its way out so that when u put a new one in it wont work... but due to ur bike i doubt that is the case
Essex_Mike
PostPosted: 21:50 - 13 Aug 2006    Post subject: Reply with quote
yeh i'll just post a pic of these plugs tomorrow. is alot easier than explaining what they look like etc.
Essex_Mike
PostPosted: 16:53 - 14 Aug 2006    Post subject: Reply with quote
right, unfortunatly my digital camera has decided to fuck up. so below is a rough drawing tot he shape of the disconnect plug i found.
cheers, mike
finpos
PostPosted: 16:56 - 14 Aug 2006    Post subject: Reply with quote
"Could be"
Have you got a multimeter or a wiring diagram? it's really hard to know without having access to one or the other.
There is another way, but it might involve sparks and things melting.
finpos.
Essex_Mike
PostPosted: 17:02 - 14 Aug 2006    Post subject: Reply with quote
i do, but not on my computer, in the haynes manual it says the relay is under the seat between the oil and the coolant. which is where i found that "L" shaped plug.
but there was another 2 plugs, but they were disconnected when i got the bike a few weeks back when it was running fine.
finpos
PostPosted: 17:05 - 14 Aug 2006    Post subject: Reply with quote
Well, check the wiring diagram, it will be able to tell you the colour of the wires (and how many wires) go to the indicator relay. Then check the connector you found, see if it matches.
Simple enough!
finpos.
Essex_Mike
PostPosted: 17:10 - 14 Aug 2006    Post subject: Reply with quote
didn't think of that, and yeh, color of wires do match up.
cheers. i have managed to find a used relay. tho not realy sure how much it will cost me to get it done at garage as they said they were unable to quote me a price? Confused
PostPosted: 17:13 - 14 Aug 2006    Post subject: Reply with quote
That could be it, you do get two terminal flasher relays and the terminals are at right angles to one another.
Does your terminal block look like it would fit on this? (which is a universal 6 volt flasher relay, you would want a 12v one but they look identical)
https://cat.cip1.com/gfx/VWC-111-953-185-B.jpg
EDIT. What colour are the wires attached to the terminal block you have? If one is blue and the other grey, it is definately for the flasher relay. If not, it still might be.
Essex_Mike
PostPosted: 17:16 - 14 Aug 2006    Post subject: Reply with quote
yes, the plug part does have identical placed slots. i have found someone on ebay selling one. i hoping to get it there and fit it myself, as i don't fancy spendin mor money at a garage when i might be able to do it meself.
is there any tips when fitting the relay? as i read somewhere, that by fitting it, i could blow the fuse. not totaly sure if this was for the relay though.
cheers, Mike
finpos
PostPosted: 17:17 - 14 Aug 2006    Post subject: Reply with quote
Flasher units tend to be pretty standard things and the two pin ones cost buttons, e.g. this page:
https://www.vehicle-wiring-products.co.uk/VWPweb2000/relays/relays.html#gen443
You might be able to get one from a local electrical motor factors.
Genuine dealer part will cost you more.
Lets face it, if it's missing, that's what is probably causeing the problem!
Expect a garage to charge you 10 mins labour (15 quid) to plug it in for you.
finpos.
PostPosted: 17:18 - 14 Aug 2006    Post subject: Reply with quote
The terminals just push-on. 2-second job, do it yourself. They even made it easy for you by having a plastic terminal block so you can't get it the wrong way round.
Essex_Mike
PostPosted: 17:34 - 14 Aug 2006    Post subject: Reply with quote
cheers Smile you've been great help.
is that a reliable site to buy from?
cheers, mike
finpos
PostPosted: 17:44 - 14 Aug 2006    Post subject: Reply with quote
I've bought tons of stuff off them - never a problem.
I think what you will want is Ref. WRE02. The "2 x 8-10W" refers to the type of bulb it will drive, so to confirm it's the right one take a look at one of your indicator bulbs, I'm pretty sure it will be a 5W or 10W bulb. (5W may not be a problem cos you need to add in the wattage of the repeater bulb on the dash as well)
You'll need to ring the guy up as well to confirm that it is a 2 pin flasher - I can't tell from his crappy picture!
finpos.
Essex_Mike
PostPosted: 17:51 - 14 Aug 2006    Post subject: Reply with quote
Laughing sorry bout that shit picture of mine.
in the haynes manual it says my bulbs are 12V 21W.
finpos
PostPosted: 17:53 - 14 Aug 2006    Post subject: Reply with quote
In that case, WRE04 is what you're after.
(I was refering to the crappy picture on the website Smile)
finpos
Essex_Mike
PostPosted: 18:00 - 14 Aug 2006    Post subject: Reply with quote
to finpos, stinkwheel
cheers for ya help.
very appreciated. Thumbs Up
The last post was made 20 years, 6 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 123.83 Kb
