nsr AGAIN!
lee125
PostPosted: 10:25 - 14 Aug 2006    Post subject: nsr AGAIN! Reply with quote
hi my nsr is playing up again samething happened pissing out coolent out of the expansion tank i put the gasket on yesterday without liquid gasket how you said tighten bolts up opposites but i dont have a torque wrench could doing them too tight casue this?also is the cap on the expansion tank meant to have a hole in the middle cause isnt the cooling system emant to be sealed? the plan is fix it get it running perfect tidy it up and sell it and get a better bike if anyone has any ideas what could be causing this problem all the time that would would be great cheers
cbt passed Smile 01/07/2006 bike:92 dt 125 and 96 honda cr 250
theory:PASSED! A2 test:PASSED 08/11/2006 restricted to 33bhp for 2 years
finpos
PostPosted: 10:54 - 14 Aug 2006    Post subject: Reply with quote
could be worth getting hold of a torque wrench - you may be really lucky and not done them up enough!
Most expansion tanks are vented, so don't worry about the hole in the cap (I can only think of a couple of models of cars which have pressurised tanks, no bikes.)
finpos.
lee125
PostPosted: 13:29 - 14 Aug 2006    Post subject: Reply with quote
im not lucky at all with this bike Sad just checked them and tehre all tight what could keep causing this to happen? cheers
finpos
PostPosted: 13:33 - 14 Aug 2006    Post subject: Reply with quote
Suspect your various bouts of overheating have warped the head again Sad
finpos.
lee125
PostPosted: 13:53 - 14 Aug 2006    Post subject: Reply with quote
hi Sad im going to have to take the head and barrel off again skim it order ANOUTHER head gasket and the one that was on i had just fitted on saturday:( i got told that i should heat the head gasket up before fitting it then put the bolts on go for about a 20 min ride then tighten them again if they are looser is this correct? thanks for the help cheers
finpos
PostPosted: 13:59 - 14 Aug 2006    Post subject: Reply with quote
Never heard that advice about heating up a head gasket before.
finpos.
lee125
PostPosted: 14:00 - 14 Aug 2006    Post subject: Reply with quote
what would be best then? i just want to know that i have done it properly cheers
finpos
PostPosted: 14:06 - 14 Aug 2006    Post subject: Reply with quote
Skim it (get the top of the barrel checked as well), new gasket, torque wrench, re-check nuts frequently in first few miles.
finpos.
lee125
PostPosted: 17:26 - 14 Aug 2006    Post subject: Reply with quote
ok thanks il do all that and hopefully it will work and im going to buy a torque wrench off ebay tonight and it should be here buy thursday thanks for the help Thumbs Up
The last post was made 20 years, 5 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 58.58 Kb
