non powered heated grips?
phatstorage
PostPosted: 14:08 - 25 Aug 2006    Post subject: non powered heated grips? Reply with quote
just a thought and shoot me down if this has been thought of before but, with the usual winter chill coming on soon heated grips are in the back of my mind.
Ever the economist or tight arse whichever way you want to look at it i was wondering if you could have heated grips without the use of the battery.
i.e the exhaust gets plenty hot and all of that energy is wasted, so why not route some of it to the handlebars using a simple pipe and valve system to control the tapped flow of hot gasses from the exhaust.
I can't believe no-one else has thought of this which is why i'm curious as to if it will work or not,
Also little pipes under the seat for even more comfort? Shocked
PLUS it would look cool to have 10 % of your exhaust smoke coming from your handle bars wouldn't it? Twisted Evil
Let me know what you tinks.
Itchy
PostPosted: 14:25 - 25 Aug 2006    Post subject: Reply with quote
Er no , energy cannot be created it can only be converted, if you divert your exhaust it just causes more back pressure and takes power from the engine,
which would be v bad on a 2 stroke bike cus they heavily rely on exhaust waves to draw in fresh fuel and air,
while the alternator probably converts well more electricity than is needed , and is probably much more efficient at it also to boot.
100s of thermocouples attached to your radiator / engine or pipes might work , but thermo couples covert microscopic amounts of energy and you'd need lots of them and also engines work best at a certain temp such that when starting up it might be a bit rough,
heat pipes might work ie conduct the heat directly but then there is no way of regulating it, a simple method would probably to link the water cooling of the engine to a secondary radiator (ie your grips) ,
but this means more energy is required by the water pump , probably more than normal oxford heated grips would take.
phatstorage
PostPosted: 14:30 - 25 Aug 2006    Post subject: Reply with quote
fair enough, just thought i'd ask,
i'm now hooked on the idea of smoke coming from the handle bars though Rolling Eyes
phantomtek
Lil Joe Tek
PostPosted: 14:31 - 25 Aug 2006    Post subject: Reply with quote
What about that coffee invention that warms itself up, by combining two chemicals that heat rapidly. That substance could be put into a wrap around container sort of thing and the substances combined for temporary warmth.
Though I bet in the long run it would be cheaper to just buy muffs and heated grips. Confused
Link to coffee invention.
mr.z
PostPosted: 15:23 - 25 Aug 2006    Post subject: Reply with quote
I'd thought similar before, and but as mentioned via the cooling system.. if i'm not mistaken some carbs are heated in this ay, i.e. a feed from the cooling system, to prevent carb iceing..
Some sort of pump like a washer jet maybe? runs from a pipe out of the resivoir and returns to the same place after runing up to the bars... perhaps a thermostat somewhere inside..
It would still be a very expensive complex way arround it.. could also make some sort of plug in vest that has coolant going arround thin guage tubes, seat maybe, and gloves even.. that mnight make it worth it.. it coudl work, but i'd imagein it woudl have its fair share of technical issues! (compared to the extreemly simple, non messy electircal route)
phatstorage
PostPosted: 15:51 - 25 Aug 2006    Post subject: Reply with quote
yeah i was just thinking of a simple way to use the bi product of the bike when running, i got inspired after fitting a scottoiler a few days ago (carb vacuum opens valve, oil comes out, genius!!) and then heard folks talking about heated grips.
Maybe a rubber water pipe already filled with water so no pump needed but just heated from the water in the rad, the heat can flow through the water perhaps?
No smoke from the handlebars though Crying or Very sad
extreme3d
PostPosted: 19:06 - 25 Aug 2006    Post subject: Reply with quote
Thing is though, it's not wasted energy. When the engine is running it's alternator provides the power not the battery (well it replaces the energy in the battery as you take it away). The power is there whether you use it or not.
APNess
PostPosted: 19:29 - 25 Aug 2006    Post subject: Reply with quote
I suppose you could block the handlebars off inside, run a thin hot water feed pipe through them and out of the bar ends, somehow and back through the fairing into the radiator, using a tap to shut the pipe off for summer riding.
Maybe someone from Honda is reading this and I can expect a letter from a patent lawyer about nicking their idea for the next Goldwing/Pan :S
Or maybe not Wink
APNess
PostPosted: 19:30 - 25 Aug 2006    Post subject: Reply with quote
Heh, oops, sorta the same idea (well, sorta exactly the same idea a few posts up).
Ah well, great minds think alike Razz
carvell
Scuttler
PostPosted: 20:59 - 25 Aug 2006    Post subject: Reply with quote
I can't see anything wrong with routing the cooling system via capillary tubes in the grips. Sounds like a damn good idea to be honest!
Thing is, it simply boils down to the fact that there's nothing wrong with electric grips and they're a thousand times better than a capillary system would be.
Yamaha TDM 850
phatstorage
PostPosted: 21:48 - 25 Aug 2006    Post subject: Reply with quote
Sorry maybe i didn't explain properly, the "wasted" energy i speak of is the heat from the exhaust system that you can fry an egg on just disappearing into the fresh air, i don't think i mentioned electric power wastage at all.
But hey at least i've worked out that you can fry an egg on the exhaust maybe you could brew a cuppa from the engine coolant, antifreeze adding that vital tang for the winter Mr. Green
I am not disagreeing that electric heated grips are the best thing but isn't it just because no one has put any other system into practice?
By using potentially wasted energy and recycling it for another job it will definitely be more efficient than using the electric system.:end save the planet mode:
Although, (just had another) what about using the heat from the head light bulb using a heat sink attached to the bars, hmmmm? Confused
Valentino Mossy
PostPosted: 22:39 - 25 Aug 2006    Post subject: Reply with quote
How about those gel packs which you click a little disk inside and it warms up nice and toasty ! Make one to fit inside the grips,press the bar end button and instant heat !
Well thats my brainwave idea done for the year ! Thumbs Up Wink
Finglonga
PostPosted: 22:43 - 25 Aug 2006    Post subject: Reply with quote
Have you ever tried one of those? They only get warm at best and taste vile. Had one a couple of years ago, thought they would be good but Thumbs Down Thumbs Down
Andy Sez....
F.Y.Y.F.F.
kawakid
PostPosted: 22:48 - 25 Aug 2006    Post subject: Reply with quote
Why not put your bike in the garage for 3 months and go in the car. Shoot me down but that's what i'll be doing. Not being able to feel my fingers is not fun, nor is bottle ice.
I've a twin and a 4.
Itchy
PostPosted: 23:09 - 25 Aug 2006    Post subject: Reply with quote
true the glass does get hot at the front , but the question is how to harvest the heat , since shiny metalic surfaces ie the egg shell of the light reflect much of the energy away and blocking up the headlight makes it useless.
Itchy
PostPosted: 23:12 - 25 Aug 2006    Post subject: Reply with quote
cars cost more money , petrol tax and insurance , insurance for cars is still about £1000 /pa on a grp 5 car , on a grp 10 bike I can get insured for less than 40p a day. added to that parking costs.
Finglonga
PostPosted: 23:20 - 25 Aug 2006    Post subject: Reply with quote
Cars have 4 wheels in Ice and Snowy conditions, a roof a good heater and you don't have to drive them dressed as the Michelin man. Wink
Andy Sez....
F.Y.Y.F.F.
kawakid
PostPosted: 00:12 - 26 Aug 2006    Post subject: Reply with quote
I've both car and bike and I ride daily (commute), but come ice time, I don't. Where I live is very hilly and the roads are not always treated. Seriously i've done it and I hate it. Would do it on a motorcross style bike nothing else.
My car insurance is only £320 a year for a 1.8mondeo, fully comp, with protected no claims.
But then I am probably much older than you. Laughing Laughing Laughing
extreme3d
PostPosted: 14:07 - 26 Aug 2006    Post subject: Reply with quote
Yes but bikes still get you home quicker, stick the kettle on the moment you get in, it will have boiled in the time it takes you to remove your gear - you could be back home with your feet up enjoying a nice hot mug of tea whilst car man is still a good 1/2 hour away.
The only time i will use my car over my bike is if i'm coming back from watching a horror film at night. In a car you feel protected with all the metal and glass around you - you also get that satisfying 'clunk' as your elbow reaches up and pushes down the locking lever....
On a bike though anything could jump out of that dark swirling mist....... and grab you Shocked
https://www.mur.at/nmdirndln/pict/alien.jpg
The last post was made 20 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 108.29 Kb
