Bandit Gone MENTAL!!!!
dumpsta
PostPosted: 19:18 - 27 Aug 2006    Post subject: Bandit Gone MENTAL!!!! Reply with quote
Hi everyone.
looking for a bit of wisdom. I have had my k series bandit for about 2 months now and have done 1000 miles. Every now and again it goes MENTAL and revs it self right up even if i let go of the throttle. Its happened about 5 times now and am a bit worried. Its not the throttle cable sticking just wondering if anyone knows what else it could be?
cheers fellas
Watch Rae Rip up worlds this year!!
Jebus
PostPosted: 20:18 - 27 Aug 2006    Post subject: Reply with quote
you got a idle problem, try giving the carbs a flush!
2nd time around Smile CBT: 8/9/11
125 Varadero
Gradog
PostPosted: 22:14 - 27 Aug 2006    Post subject: Reply with quote
I am struggling to understand that. Surely if the carbs were sticking it could only be the main needle jet. Otherwise you would have fuel starvation, ie it would die.
I was thinking more likely a blocked vacuum pipe.
Grey haired bikers don't get that way from pure luck. Only a biker knows why a dog sticks his head out of the car window.
Bezzer
PostPosted: 22:26 - 27 Aug 2006    Post subject: Reply with quote
err not as much as I'm struggling to understand what you've just typed Mr. Green
meooo
PostPosted: 22:40 - 27 Aug 2006    Post subject: Reply with quote
when does this happen? How high does it rev to?
whilst riding along? under acceleration? coming to a stop/junction?
Sometimes an engine will rev high just prior to running out of fuel for some reason. Does it happen when fuel level is low/cornering hard?
dumpsta
PostPosted: 00:06 - 28 Aug 2006    Post subject: Reply with quote
usually happens in second gear i will be putting the gas on slowly and then it will rev right up to the readline! only stops when i hit the kill switch. this is very intermitant as i said before its happened 5 times in 1000 miles?
extreme3d
PostPosted: 00:25 - 28 Aug 2006    Post subject: Reply with quote
The K series bandits have an exposed throttle position sensor (pretty much positioned where the cable joins the carbs). Give it a check over - no corroded wires etc.
Bezzer
PostPosted: 01:10 - 28 Aug 2006    Post subject: Reply with quote
Nowt to do with the TPS, it makes no discernable difference to running if it's connected or disconnected (I've tried Mr. Green)
Check the two throttle cables properly one may be worn/frayed and sticking occassionaly..
PostPosted: 11:25 - 28 Aug 2006    Post subject: Reply with quote
Is it really reving up, in gear, and accelerating hard? If so (sounds like it as you mention it happening in 2nd gear) then pretty much the only thing it can be is the throttle sticking open.
As mentioned above, check the cables, also check the linkage at the carb. However, at 1000 miles / 2 months old I presume it is under warrenty so take it back to the dealer and get them to sort it.
If the throttle is sticking like that I would be dubious about riding it. Could potentially get very nasty.
If it is just reving up when the clutch is pulled then there are a few other things, such as a cracked carb rubber mount / poorly seated carb. However this is unlikely to have any noticeable affect when in gear with the engine under load.
rpg
PostPosted: 16:42 - 28 Aug 2006    Post subject: Reply with quote
could also be an airleak-check the carb rubbers.
PostPosted: 16:44 - 28 Aug 2006    Post subject: Reply with quote
If it is doing it in neutral then I agree, but if it is doing it in gear then I would doubt it (the extra air passing is tiny, and with no extra fuel it would have next to no effect).
3806danny
PostPosted: 21:23 - 29 Aug 2006    Post subject: Reply with quote
cable sticking
The last post was made 20 years, 60 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 73.16 Kb
