| dumpsta |
 dumpsta Two Stroke Sniffer
| Jebus |
 Jebus Brolly Dolly
 Posted: 20:18 - 27 Aug 2006 Post subject: |
you got a idle problem, try giving the carbs a flush! ____________________ 2nd time around CBT: 8/9/11
125 Varadero |
| Gradog |
 Gradog Nitrous Nuisance
| Bezzer |
 Bezzer World Chat Champion
| meooo |
 meooo Nova Slayer
| dumpsta |
| extreme3d |
 extreme3d World Chat Champion
| Bezzer |
 Posted: 01:10 - 28 Aug 2006 Post subject: |
Nowt to do with the TPS, it makes no discernable difference to running if it's connected or disconnected (I've tried )
Check the two throttle cables properly one may be worn/frayed and sticking occassionaly.. ____________________ I used to be indecisive but now I'm not quite so sure. |
| Kickstart |
 Kickstart The Oracle
 Posted: 11:25 - 28 Aug 2006 Post subject: |
Is it really reving up, in gear, and accelerating hard? If so (sounds like it as you mention it happening in 2nd gear) then pretty much the only thing it can be is the throttle sticking open.
As mentioned above, check the cables, also check the linkage at the carb. However, at 1000 miles / 2 months old I presume it is under warrenty so take it back to the dealer and get them to sort it.
If the throttle is sticking like that I would be dubious about riding it. Could potentially get very nasty.
If it is just reving up when the clutch is pulled then there are a few other things, such as a cracked carb rubber mount / poorly seated carb. However this is unlikely to have any noticeable affect when in gear with the engine under load.
| rpg |
 rpg Scooby Slapper
| Kickstart |
| 3806danny |
 3806danny Spanner Monkey
The last post was made 20 years, 61 days ago. Instead of replying here, would creating a new thread be more useful? |
