| davidjg |
 davidjg L Plate Warrior
 Posted: 20:20 - 13 Sep 2006 Post subject: make my bike go quicker |
i have been told if i put a smaller front sprocket and a larger rear sprocket it will make my mtx go quicker,
is this correct? if not any ideas of how to make it go quicker without mucking about with the engine  |
| TheShaggyDA |
This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
 TheShaggyDA Repost Police
| Paddy Blake |
 Posted: 20:26 - 13 Sep 2006 Post subject: Re: make my bike go quicker |
If you do this you will lose top end speed but it will take of quicker. |
| Jebus |
 Jebus Brolly Dolly
 Posted: 20:36 - 13 Sep 2006 Post subject: |
It is to do with the final gear ratio, if you make the ratio "higher" then you will gain top speed and you will cruise at fewer revs, if you lower it you will gain acceleration but loose top speed, normal practice for this is 2 go up or down a few teeth on the back or change them for a set for differnt things e.g. i think that 14/47 is the preferd one for trail riding.
It All depends on what you want the bike to do, and on the bike some will be fine with the change in the gearing others wont be able to pull the higher gearing when in the higher gears or some with end up with a lot of wheel spin on lower gears. ____________________ 2nd time around CBT: 8/9/11
125 Varadero |
| kestrel |
 kestrel Nearly there...
 Posted: 20:36 - 13 Sep 2006 Post subject: Re: make my bike go quicker |
Other way round mate, by changing sprocket sizes you are effectively changing the final gearing of the bike. Sprocket changes alter both the top speed and the accelleration and it is a compromise between the two.
To increase top speed increase number of teeth on front sprocket or reduce number of teeth on rear sprocket.
Racers often change rear sprockets to alter gearing for particular circuits. |
| Zimbo |
 Zimbo World Chat Champion
| hmmmnz |
 hmmmnz Super Spammer
The last post was made 19 years, 349 days ago. Instead of replying here, would creating a new thread be more useful? |
