make my bike go quicker
davidjg
PostPosted: 20:20 - 13 Sep 2006    Post subject: make my bike go quicker Reply with quote
i have been told if i put a smaller front sprocket and a larger rear sprocket it will make my mtx go quicker, Question
is this correct? if not any ideas of how to make it go quicker without mucking about with the engine Exclamation Exclamation Thumbs Up
TheShaggyDA This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
Paddy Blake
PostPosted: 20:26 - 13 Sep 2006    Post subject: Re: make my bike go quicker Reply with quote
If you do this you will lose top end speed but it will take of quicker.
Jebus
PostPosted: 20:36 - 13 Sep 2006    Post subject: Reply with quote
It is to do with the final gear ratio, if you make the ratio "higher" then you will gain top speed and you will cruise at fewer revs, if you lower it you will gain acceleration but loose top speed, normal practice for this is 2 go up or down a few teeth on the back or change them for a set for differnt things e.g. i think that 14/47 is the preferd one for trail riding.
It All depends on what you want the bike to do, and on the bike some will be fine with the change in the gearing others wont be able to pull the higher gearing when in the higher gears or some with end up with a lot of wheel spin on lower gears.
2nd time around Smile CBT: 8/9/11
125 Varadero
kestrel
PostPosted: 20:36 - 13 Sep 2006    Post subject: Re: make my bike go quicker Reply with quote
Other way round mate, by changing sprocket sizes you are effectively changing the final gearing of the bike. Sprocket changes alter both the top speed and the accelleration and it is a compromise between the two.
To increase top speed increase number of teeth on front sprocket or reduce number of teeth on rear sprocket.
Racers often change rear sprockets to alter gearing for particular circuits.
Zimbo
PostPosted: 21:04 - 13 Sep 2006    Post subject: Reply with quote
Smaller front and / or larger rear sprockets increase acceleration a little at the xpense of top speed.
Gearing your bike up (larger front / smaller rear) increases the theoretical top speed, but it only works if you have enough power to drive you forward on the higher gearing. Low powered bikes are likely to just bog down.
hmmmnz
PostPosted: 23:01 - 13 Sep 2006    Post subject: Reply with quote
a mini moto nitrous nitrous kit off ebay Mr. Green Thumbs Up £30
sorted, untill you blow the engine Mr. Green
the humans are dead
I kick arse for the lord
The last post was made 19 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 53.68 Kb
