oil light CHECK is coming on???
saints
PostPosted: 14:08 - 15 Sep 2006    Post subject: oil light CHECK is coming on??? Reply with quote
this has just come on when i turned on my ignition,its a 98 gsxr 750,checked the sight glass and gave it a quick shake and it seems ok there anyone help me on this.
Davo
Davo To The Rescue!
PostPosted: 14:19 - 15 Sep 2006    Post subject: Reply with quote
Does the light go back out again after a little while?
saints
PostPosted: 14:21 - 15 Sep 2006    Post subject: .... Reply with quote
yes when i put it in gear to ride off it goes out
saints
PostPosted: 15:03 - 15 Sep 2006    Post subject: .... Reply with quote
what do you think davo
NSR Mick
PostPosted: 15:06 - 15 Sep 2006    Post subject: Reply with quote
I take it it's only just started?
Have you changed the oil recently?
EuropeanNC30R...
Gay Hairdresser
PostPosted: 15:08 - 15 Sep 2006    Post subject: Reply with quote
When you say 'turn the ignition on', have you actually started the bikes engine?
saints
PostPosted: 15:09 - 15 Sep 2006    Post subject: ... Reply with quote
turned the ignition on the digital CHECK OIL sign came on then when i rode off it went off no i havent just got the bike and to be honest the oil looks like its just been changed its crystal clear if you know what i mean
saints
PostPosted: 15:14 - 15 Sep 2006    Post subject: Reply with quote
when i have just turned on the ignition(but not started it)the oil indicator flashes
firefox
PostPosted: 15:46 - 15 Sep 2006    Post subject: Reply with quote
mine does this thinks its normal ?
bye bye gti <^>( ' . ' )<^>
*officer* what caused the crash ? *firefox* you see that wall up there sir ?
*officer* yes what about it *firefox* i tooted my horn but it refused to move i had to teach it a lesson.
saints
PostPosted: 15:53 - 15 Sep 2006    Post subject: .... Reply with quote
i have never noticed it before????
Barry_M2
PostPosted: 15:56 - 15 Sep 2006    Post subject: Reply with quote
On a 4-stroke, when you turn the ignition on, the oil light will come on as there is no oil pressure.
When you start the engine the light will go out, as the running engine will now be (should be) producing a good high oil pressure.
If the oil light comes on when the engine is running, thats when you need to worry, as that means the oil 'pressure' is low and therefore not lubricating as it should be. If this happens, switch the engine off straight away.
Causes for low pressure could be either a low amount of oil in the engine, or a blockage somewhere.
On a 2-stroke bike, the oil light will also be on when the ignition is on, and go out when the engine is started. BUT, when it comes on when the engine is running, it just mean's you need to fill up the 2-stroke oil tank, NOT gearbox.
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
saints
PostPosted: 16:01 - 15 Sep 2006    Post subject: .... Reply with quote
just tried it oil light flashes ,then when i fire it up it stops(as you are probably aware i am pretty new to biking) Embarassed
firefox
PostPosted: 16:05 - 15 Sep 2006    Post subject: Re: .... Reply with quote
got to learn some time Wink
Barry_M2
PostPosted: 16:08 - 15 Sep 2006    Post subject: Re: .... Reply with quote
Sounds completely normal to me mate. Just like being in a car, the oil light is also on until you start it up.
But remember, its and oil 'pressure' light, not level. The level can be checked by looking at the right side of the engine, you'll see a small clear round window about the size of a 50p peice. Get the bike upright (ie: not on the side stand) and you should see the oil level somewhere inbetween the upper and lower markers. Thumbs Up
Best thing I could suggest is to get a Haynes manual for your bike, it will teach you all the basic maintainance things.
saints
PostPosted: 16:10 - 15 Sep 2006    Post subject: .... Reply with quote
yes checked that and thanks a lot barry,much appreciated
saints
PostPosted: 16:14 - 15 Sep 2006    Post subject: Re: .... Reply with quote
you should see me ride the bloody thing Embarassed
ColdInsomnia
PostPosted: 21:44 - 15 Sep 2006    Post subject: Reply with quote
The reason it lights up when you turn the ignition on is so that you, the driver, can check that the oil light is working.
If you turn the ignition on and the oil light doesn't seem to work, there's either a problem with the LED, or something more sinister.
Yamaha YB100 | Yamaha TZR125 | Yamaha XJ600S | Suzuki GSF600
"Our society is run by insane people for insane objectives. I think we're being run by maniacs for maniacal ends and I think I'm liable to be put away as insane for expressing that. That's what's insane about it."
John Lennon
Barry_M2
PostPosted: 16:52 - 16 Sep 2006    Post subject: Reply with quote
On a 2-stroke, yes. On a 4-stroke it is on beacuse there is no oil pressure.
The last post was made 20 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 95.52 Kb
