CDI Ignitions and coils
caneswell
PostPosted: 23:48 - 27 Sep 2006    Post subject: CDI Ignitions and coils Reply with quote
Hello all!
I'm in the process of making a very dangerous weapon......I'm fitting a cbr 600 engine to a small off road buggy type thing.
I'm not a fan of wiring! I think i now have the correct CDI unit it's from a 97 bike and I think the engine is 95 so that should work??
Can you use regular 12v coils from any bike with CDI ignition systems, or do you need to use specific CDI spec coils?
Thanks muchly, i'll post some videos of me crashing it as soon as its running!
hmmmnz
PostPosted: 10:27 - 28 Sep 2006    Post subject: Reply with quote
a coil is a coil my friend, it just has a signal wire and common return to the cdi(2 wires from each coil)
the cdi should work, im not sure there was any difference to the ignition system. but you can all but try aye Very Happy
hope that helps ya a bit, i hope you realise you aree obliged to post photos now Very Happy i did a similar thing back in nz a few years ago with a gsx 750 engine very fun
the humans are dead
I kick arse for the lord
caneswell
PostPosted: 10:36 - 28 Sep 2006    Post subject: Reply with quote
Thank you, sorry for being a retard!
hmmmnz
PostPosted: 13:27 - 28 Sep 2006    Post subject: Reply with quote
no worries, no question is a stupid one (unless its a stupid one Very Happy)
good luck, pics of your progress Mr. Green
the humans are dead
caneswell
PostPosted: 19:38 - 28 Sep 2006    Post subject: Reply with quote
Not taken any for a bit. Here are some from a month or so ago:
https://img.photobucket.com/albums/v255/caneswell/Image018-1.jpg
https://img.photobucket.com/albums/v255/caneswell/Image019.jpg
https://img.photobucket.com/albums/v255/caneswell/Image017.jpg
KatOwner
PostPosted: 20:58 - 28 Sep 2006    Post subject: Reply with quote
Somebody is going to be having some very mental fun sometime in the future Very Happy
As far as electrics go, simplicity would suggest you get hold a wiring loom for a CBR600 from a breakers. Then you can just use the bike wiring diagram as a start point.
hmmmnz
PostPosted: 00:30 - 29 Sep 2006    Post subject: Reply with quote
looks like its gunna be a wepon Mr. Green Thumbs Up wicked keep us posted
the humans are dead
caneswell
PostPosted: 00:32 - 29 Sep 2006    Post subject: Reply with quote
Yep that's what I'm thinking. Unfortunately I believe I have an F2 engine (as there is no speedo pickup of the crankcase) and a '97 CDI. So which loom would be easiest to use?
Thanks
hmmmnz
PostPosted: 09:28 - 29 Sep 2006    Post subject: Reply with quote
basically most wiring is the same, im not sure if you have an internal recifier or an external one on your bike(is there 3 wires from the alternator or just 2? if you have 2 then your rectifier is internal)
wiring a carburator engine is easy, i could make you up a wiring diagram if you want, unless you want indicators and guage lights, but again thats all easy,
the only difficult bit in using another bikes loom is the connectors and srorting the side stand switch and what not.
let me know if you wand me to draw something up for you Very Happy
the humans are dead
caneswell
PostPosted: 11:00 - 29 Sep 2006    Post subject: Reply with quote
That would be awesome if you could. It's got an external rectifier, I have a Honda Superdream one, or some form of CBR one to use.
Basically I have no idea what any of the pins in the CDI are for or how to connect to them! If anyone has a connector block with the coloured wires that would help!?
hmmmnz
PostPosted: 11:45 - 29 Sep 2006    Post subject: Reply with quote
ok what do you want in the way of warning lights? oil and neutral? is that enough, do you want the lighting circuits, brake lights ect
or just bare bones (less to wire Very Happy)
the humans are dead
caneswell
PostPosted: 12:32 - 29 Sep 2006    Post subject: Reply with quote
Nope no lights required. Maybe oil and neutral would be a good idea but i could probably survive without it. Just want it to run asap!! Laughing
hmmmnz
PostPosted: 13:14 - 29 Sep 2006    Post subject: Reply with quote
ok sweet next question are you using the original clocks/ rev counter temp guage ect??
the humans are dead
hmmmnz
PostPosted: 16:06 - 29 Sep 2006    Post subject: Reply with quote
ok here is a wiring diagram almost as basic as i could get it, i could simplify the ignition/fan switch a bit more and if i can find out about the throttle sensor i could probly do some thing there as well but id say its probly essential to the timing advance ect
https://i58.photobucket.com/albums/g257/hmmmnz/cbrwiring2.jpg
i hope that helps ya a bit, let me know if you need any thing explained Very Happy if you were near me i could probly give you a hand wiring
the humans are dead
hmmmnz
PostPosted: 16:07 - 29 Sep 2006    Post subject: Reply with quote
hmmm that didn't come out as big as i have done it, send me your email and ill send the original to you Very Happy
the humans are dead
sickpup
Old Timer
PostPosted: 23:21 - 29 Sep 2006    Post subject: Reply with quote
hmmmnz wrote:
a coil is a coil my friend.
And prize for person who officially doesn't know he will blow a CDI with misinformation goes to.........................
Hmmmnz.
Coils have different primary resistances. On an inline four, four stroke its normally either 2.2 ohms or 3.0 ohms. I think on your bike it uses the 3 ohms ones.
caneswell
PostPosted: 20:29 - 30 Sep 2006    Post subject: Reply with quote
So does anyone have a cbr 600 f2/f3, could you look at your CDI and tell me what colour wires go to what pin?? Would be much appreciated Laughing
Paddy Blake
PostPosted: 21:58 - 30 Sep 2006    Post subject: Reply with quote
I think the manual is in the manual section.
https://www.bikechatforums.com/viewtopic.php?t=41567
Paddy.
PostPosted: 22:06 - 30 Sep 2006    Post subject: Reply with quote
I might know where there's loom and CDI (and engine if you ever need a replacement). Have to check the year though.
hmmmnz
PostPosted: 13:31 - 01 Oct 2006    Post subject: Reply with quote
Hmmmnz.
can't be right all of the time Very Happy, glad that some one caught that before some thing bad happened,
the humans are dead
PostPosted: 13:46 - 01 Oct 2006    Post subject: Reply with quote
Using the wrong coils is a common way of frying the ignition systems on FZ750s. Early and late model FZs used different ignition systems and the coils are not compatable with each other.
hmmmnz
PostPosted: 20:34 - 01 Oct 2006    Post subject: Reply with quote
very good, i know now and won't be making that mistake in the future, Very Happy
no harm done this time so thats the main thing
the humans are dead
The last post was made 20 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 118.96 Kb
