| firg |
 firg Spanner Monkey
 Posted: 23:23 - 07 Oct 2006 Post subject: |
If you mean just general maintenance but still getting someone else to do the servicing.
Chain lubing. Oil it regularly. Plenty of spray on chain lubes available. Put the bike on the centre stand and turn the back wheel while spraying the stuff on the chain (onto the rollers and the O rings between the side plates), but keep your fingers well away from the sprockets while doing so.
Chain adjustment. Chain needs adjusting regularly to keep the slack about right (generally about 1 inch of play, varies between models though). You can do it using the tools in the bikes too kit, but pick up better quality tools when you get a chance.
Wash it occasionally.
Check the oil. Bandit has a sight glass so check the oil level is between the min and max marks with the bike upright.
Tyre pressures. Tyres often loose some pressure over time (more than a tiny amount means there is probably a dodgy valve or a puncture though). Check them regularly. Don't trust the gauge at garages.
Check everything works. Like lights. Check for leaks.
| firg |
 firg Spanner Monkey
| firg |
 firg Spanner Monkey
| meenie |
 meenie Borekit Bruiser
| meenie |
 Posted: 13:19 - 09 Oct 2006 Post subject: |
| cabbage wrote: | Firstly, throttle cable adjustment. The bandit uses a 2 cable throttle (one for openeing, one for closing). The manual talks about changing the cable play...... But how do you figure it out on the throttle? says it should have 0.5-1mm. |
I know the Haynes manual for my bike says that the adjustement is on the cables attacthed to the side of the carbs. The decelerator cable should be tight (to snap the throttle shut when you release it). The Accelerator cable should have a tiny bit of slack (about what you said) to make sure it isnt unusable in slow speed traffic and so you dont turn it into an on/off switch, I think alot of this is personal preference though. Most times you can adjust the accelerator cable from under the throttle, little adjuster and a lock nut.
| cabbage wrote: | Secondly, For changing the oil filter, it mentions using a specific oil filter wrench. However looking at it it seems to just have the standard wrench fixing whatsit. Am i missing something here?
thanks,
Loz |
You can buy filter wrenches, but they are all much of a muchness. Remember that on cars they tell you to buy a filter wrench, I've always used a long handled screwdriver and a hammer, messy but works If using that method though, watch how much pressure you put on it when you hit it as you could damage the thread! Filter wrenchs dont cost much anyway. Even amazon do them! ____________________ Owner : ZXR750L3 ('96) My bike @ BikePics.com
Wearer: Alpinestars & Shoei
SafeSpeed |
| firg |
 firg Spanner Monkey
 Posted: 14:32 - 09 Oct 2006 Post subject: |
Thanks meenie
Ill have a stab at the clutch later this afternoon then come crying when i break it.  ____________________ Ex-'96 Bandit 600S -> '99 Bandit 600 -> K7 V-Strom 650 |
| firg |
 firg Spanner Monkey
| firg |
 firg Spanner Monkey
 Posted: 00:50 - 10 Oct 2006 Post subject: |
Like this? ____________________ Ex-'96 Bandit 600S -> '99 Bandit 600 -> K7 V-Strom 650 |
 Posted: 00:53 - 10 Oct 2006 Post subject: |
| Dazbo666 |
 Dazbo666 World Chat Champion
 Posted: 02:38 - 10 Oct 2006 Post subject: |
I found that a tyre tead depth gauge has been useful too.
Plus, when I'm checking the tread depth etc, I'm also closely checking for any punctures, stones or scrapes in the tyre  ____________________ 1st bike (Sept'06 - May'10) : 1991 GPZ500S / Current bike (since Nov 2009) : 2003 Suzuki Bandit 600N
Word of the day : DILLIGAF |
| firg |
 firg Spanner Monkey
 Posted: 12:58 - 10 Oct 2006 Post subject: |
Eh that clutch cable changin thingy was easy as hell. If you follow the instructions, i dont see the big thing
Why dont peeps service theyre own stuff?
meh.
okays, one other question: when the engines cold, the oil window whatsit shows the oil level as right at the full mark. When its hot, its right off the top of the window. Soo, i guess its got too much in there cause the manual says to check when hot, but is this a problem? Also, garage always smells of petrol next morning, this is normal, right?
Loz ____________________ Ex-'96 Bandit 600S -> '99 Bandit 600 -> K7 V-Strom 650 |
| firg |
 firg Spanner Monkey
 Posted: 00:05 - 11 Oct 2006 Post subject: |
Hello, it appears the clutch is not sorted.
As it is, the clutch only provides drive at the very end (when they are as close as possible) of the plate movement. That is to say, adjusting the clutch cable simply makes the lever loose, until the plates start moving (which you can tell from resistance and squekiness :p ), and then drive engages.This is unfortunately giving the clutch a kinda on-offish feel, as you get no change then all of a sudden all drive gone when pulling the lever in.
What could be the cause of this? Worn down plates? Surely they wouldnt wear down enough to remove enough material to have this much of an effect? Someone else i asked suggested the clutch springs. Anyone got an opinion?
thanks,
Loz
P.S. Sorry if the terms im using are silleh and wrong, but i have no idea what you really call this stuff  ____________________ Ex-'96 Bandit 600S -> '99 Bandit 600 -> K7 V-Strom 650 |
| firg |
 firg Spanner Monkey
 Posted: 00:48 - 12 Oct 2006 Post subject: |
Not sure. There are numerous bits in the clutch that can cause problems. Thrust bearing can have some odd effects. Worn clutch basket (the fingers on the basket wear, with marks from where the plates hammer it). Cables get old and start to stick. Plates warp. All can make the clutch unpredictable. Cannot really say which (or something else) from the description.
To be honest take it along to the bike shop and ask. Hopefully they will be honest.
| Nath |
 Nath World Chat Champion
| firg |
 firg Spanner Monkey
| meenie |
| firg |
 firg Spanner Monkey
The last post was made 20 years, 19 days ago. Instead of replying here, would creating a new thread be more useful? |
