Motorbike PDA mount
quik_d
PostPosted: 21:30 - 06 Nov 2006    Post subject: Motorbike PDA mount Reply with quote
Does anyone use one? I have a PDA so i decided to get tom-tom software for it, now i want to mount it to the bike, but not sure how to. I have seen this
https://cgi.ebay.co.uk/ARKON-QUALITY-SWIVEL-HANDLEBAR-PDA-MOUNT-FOR-BIKES_W0QQitemZ120049519747QQihZ002QQcategoryZ75447QQtcZphotoQQcmdZViewItem
do you think it looks ok? any other suggestions if not?
thanks Thumbs Up[/url]
LOOK AT DAT M8 WELL LUSH A PARROT INT IT
mr.z
PostPosted: 21:37 - 06 Nov 2006    Post subject: Reply with quote
IMO your pda will be absoloutely FARKED in no time at all..
I'd go for a RAM mount, more dampening, more options and well built.. it needs as much dampening as you can give it..
i'm affraid pdas + massive vibration + rain = dead pda Sad
Touratech probably do something that would make it useable but it'd not be cheap!
Actually stupidly a tankbag would be a more practical and safe (for the pda) soloution Confused
map
Mr Calendar
PostPosted: 21:42 - 06 Nov 2006    Post subject: Reply with quote
mr.z wrote:
... go for a RAM mount,....
Agree. Although solid state PDAs should last longer, they're used for GPS after all (FYI Palm LifeDrives are disk based). IMO it's the fact they're not waterproof that tends to do more harm.
An alternative would be to check if Touratech did anything suitable. Will not be cheap but certainly A1 pieces of kit.
HTH Thumbs Up
paddychopchop...
PostPosted: 21:46 - 06 Nov 2006    Post subject: Reply with quote
i agree with the tamkbag option, i used one for mine and it worked a treat, even better if you have the waterproof cover for the bag
Mr. Green
quik_d
PostPosted: 22:05 - 06 Nov 2006    Post subject: Reply with quote
i've got a waterproof bag thing for it (aquapac) but yes i did consider the tank bag but thought i have to actively look down to see where i've gotta go next? Which must be fairly dangerous.
The other cosideration is https://cgi.ebay.co.uk/RIKALINE-DUAL-SUCKER-HOLDER-ARM-VIBRATION-FREE_W0QQitemZ120049733738QQihZ002QQcategoryZ75447QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
which claims to be vibe free and i have a ouring screen which it should be able to fix onto without hitting the clocks as its quite tall
mr.z
PostPosted: 22:31 - 06 Nov 2006    Post subject: Reply with quote
Thats the dissadvantage with it, allthough the audio jack is more usefull than the display ime.. quick glance is all i can seem to get while moveing, usually look while at lights e.t.c.
I did also try one of those plastic bag things, worked sort of, but it as tricky to see through (best i could get wasn't 100% clear)
If you do go for a sucker thing then make sure theres a line to catch it! cause it will fall off at some point Sad
For my garmin i3 i ended up with this..
https://img90.imageshack.us/img90/959/img0330i3nh6.jpg
https://img206.imageshack.us/img206/1667/img0334i3hd8.jpg
its a tupperwear box and a ram mount, 99% waterproof (only the cable feed in could let any in, sillicon sealant would fix that) if you got a bigger sized box similar to the pda, cut it a perspex window, use foam and cut it a pda shaped space, appart from feeing in power (i used a bmw accessory plug cause there waterproof and nice and tidy) thats about it!
syl
PostPosted: 22:46 - 06 Nov 2006    Post subject: Reply with quote
I used a RAM mount too. If you want waterproof, consider an otterbox.
https://w1.bikepics.com/pics/2006/02/27/bikepics-531089-800.jpg
https://w1.bikepics.com/pics/2006/02/27/bikepics-531092-full.jpg
Current bike: Kawasaki Z750S
quik_d
PostPosted: 23:06 - 06 Nov 2006    Post subject: Reply with quote
is this the kind of thing i want then?
https://www.gpsw.co.uk/details/prod2452.html
cheers for all the help with this guys Thumbs Up
NSR Mick
PostPosted: 23:13 - 06 Nov 2006    Post subject: Reply with quote
Agreed 100%
I killed my ipaq in 1 hour riding in the rain. I had even covered it in cling film.
quik_d
PostPosted: 23:16 - 06 Nov 2006    Post subject: Reply with quote
I have the waterproofing covered just fixing it to the bike thats the main thing. I like the tuppaware box idea tho, then fill it so ipaq doesn't move Thumbs Up
quik_d
PostPosted: 00:40 - 07 Nov 2006    Post subject: Reply with quote
so this would be what i need?
mr.z
PostPosted: 01:02 - 07 Nov 2006    Post subject: Reply with quote
https://www.ram-mount.com/ramwebcompthumb/ram101uac1.jpg
https://www.ram-mount.com/products/motorcycles.htm
I'd suggest this one..
(ram101uac1) according to the parts number thing.. then a suitable box if thats the plan.. (certainly the cheeper option, and the foam should cut out any serious vibes however unsightly)
https://www.touratech.de/Shop_uk/en-us/dept_369.html
Allthough looking here you might find something suitable that will help your pda from getting murdered Razz
syl
PostPosted: 23:40 - 07 Nov 2006    Post subject: Reply with quote
No, that won't work unless you have a Harley - the bars on a Japanese bike are slightly thinner. You need the one that is suggested in the post above - together with a PDA mount to match your PDA.
The last post was made 19 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 81.67 Kb
