| quik_d |
 quik_d Could Be A Chat Bot
| mr.z |
 mr.z World Chat Champion
 Posted: 21:37 - 06 Nov 2006 Post subject: |
IMO your pda will be absoloutely FARKED in no time at all..
I'd go for a RAM mount, more dampening, more options and well built.. it needs as much dampening as you can give it..
i'm affraid pdas + massive vibration + rain = dead pda
Touratech probably do something that would make it useable but it'd not be cheap!
Actually stupidly a tankbag would be a more practical and safe (for the pda) soloution  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| map |
 map Mr Calendar
| paddychopchop... |
 paddychopchop... Two Stroke Sniffer
 Posted: 21:46 - 06 Nov 2006 Post subject: |
i agree with the tamkbag option, i used one for mine and it worked a treat, even better if you have the waterproof cover for the bag
| quik_d |
| mr.z |
 Posted: 22:31 - 06 Nov 2006 Post subject: |
Thats the dissadvantage with it, allthough the audio jack is more usefull than the display ime.. quick glance is all i can seem to get while moveing, usually look while at lights e.t.c.
I did also try one of those plastic bag things, worked sort of, but it as tricky to see through (best i could get wasn't 100% clear)
If you do go for a sucker thing then make sure theres a line to catch it! cause it will fall off at some point
For my garmin i3 i ended up with this..
https://img90.imageshack.us/img90/959/img0330i3nh6.jpg
https://img206.imageshack.us/img206/1667/img0334i3hd8.jpg
its a tupperwear box and a ram mount, 99% waterproof (only the cable feed in could let any in, sillicon sealant would fix that) if you got a bigger sized box similar to the pda, cut it a perspex window, use foam and cut it a pda shaped space, appart from feeing in power (i used a bmw accessory plug cause there waterproof and nice and tidy) thats about it! ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| syl |
 syl World Chat Champion
 Posted: 22:46 - 06 Nov 2006 Post subject: |
| quik_d |
 Posted: 23:06 - 06 Nov 2006 Post subject: |
is this the kind of thing i want then?
https://www.gpsw.co.uk/details/prod2452.html
cheers for all the help with this guys  ____________________ LOOK AT DAT M8 WELL LUSH A PARROT INT IT |
| NSR Mick |
 NSR Mick World Chat Champion
 Posted: 23:13 - 06 Nov 2006 Post subject: |
| mr.z wrote: | IMO your pda will be absoloutely FARKED in no time at all..
Actually stupidly a tankbag would be a more practical and safe (for the pda) soloution  |
Agreed 100%
I killed my ipaq in 1 hour riding in the rain. I had even covered it in cling film. ____________________ If you dont like the way that I ride.......Stop trying to keep up!!! |
| quik_d |
 Posted: 23:16 - 06 Nov 2006 Post subject: |
I have the waterproofing covered just fixing it to the bike thats the main thing. I like the tuppaware box idea tho, then fill it so ipaq doesn't move  ____________________ LOOK AT DAT M8 WELL LUSH A PARROT INT IT |
| quik_d |
| mr.z |
| syl |
 Posted: 23:40 - 07 Nov 2006 Post subject: |
No, that won't work unless you have a Harley - the bars on a Japanese bike are slightly thinner. You need the one that is suggested in the post above - together with a PDA mount to match your PDA. ____________________ Current bike: Kawasaki Z750S |
The last post was made 19 years, 287 days ago. Instead of replying here, would creating a new thread be more useful? |
