Manifold / Exhaust fun
Ade
PostPosted: 18:47 - 15 Feb 2007    Post subject: Manifold / Exhaust fun Reply with quote
Take one winter bitten manifold
https://www.adrian-gurney.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=735&g2_serialNumber=2
https://www.adrian-gurney.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=741&g2_serialNumber=2
Give it a good clean (this was the hardest part).
I decided to take it right down to the metal, should last a bit longer this way, and will be easier to do next time around.
I used one of the metal "spinny brush things" (sorry dont know what they are called) to take it down. I started with sand paper, but that was far too much effort.
Shockingly, the spinning wire brush was also a lot less corse than the sand paper (I needed a fairly high grit to get it off Sad )
The different colours on the metal isnt parts ive missed, but where it was sanded in different directions - its just the way the light is reflecting it. Its actually very smooth Smile
https://www.adrian-gurney.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=723&g2_serialNumber=2
https://www.adrian-gurney.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=726&g2_serialNumber=1
Paint with heat resistant paint
https://www.adrian-gurney.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=729&g2_serialNumber=2
https://www.adrian-gurney.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=732&g2_serialNumber=1
Hurrah!
What a difference Smile
The paint hides all marks from the sanding. It was already quite smooth, but if I had of known how much a good job of hiding it the paint was going to do, I wouldnt have wasted so much time on it.
element
PostPosted: 18:55 - 15 Feb 2007    Post subject: Reply with quote
what paint was that? I tried paint that was good for 500 celcius i think but it has still flaked off at the hottest part of the exhaust on both my DT and my Speedfight 100 Shocked How hot do exhausts get?
04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME...
hmmmnz
PostPosted: 19:02 - 15 Feb 2007    Post subject: Reply with quote
nice job Thumbs Up
the humans are dead
I kick arse for the lord
Finglonga
PostPosted: 19:58 - 15 Feb 2007    Post subject: Reply with quote
It should stay on off you clean it as above. preperation is everything.
Looks smart. Thumbs Up
Andy Sez....
F.Y.Y.F.F.
PostPosted: 23:29 - 15 Feb 2007    Post subject: Reply with quote
Exhaust gas temperature are 900 degrees-plus on a 4-stroke sportsbike.
goatrider
PostPosted: 04:59 - 16 Feb 2007    Post subject: Reply with quote
Looks good as new - top job Thumbs Up
Goat.
Honda NS125R 1987, Suzuki GS500EW 1998, Honda CB750F2N RC42 1992
"I dont give a shit who your dad is......quit walking on the water while I'm fishing......."
iooi
PostPosted: 08:08 - 16 Feb 2007    Post subject: Reply with quote
What paint did you use there ? Not seen HRP that is brushable.
Used to use sprayable stuff many moons ago on my 2 stroke's worked well, as has been said you need to spend a good amount of time preping and not just spraying over the old rust...
PostPosted: 08:24 - 16 Feb 2007    Post subject: Reply with quote
I have a tin of brushable heat-resistant paint.
Louise
PostPosted: 08:29 - 16 Feb 2007    Post subject: Reply with quote
Very nice job! How long all in all did it take?
cestrian
PostPosted: 08:44 - 16 Feb 2007    Post subject: Reply with quote
I used 1200f paint on my GS exhaust and it was fine.
Daddy G
PostPosted: 05:48 - 19 Feb 2007    Post subject: Reply with quote
I've repainted my gpz's pipe too, what I did is to remove all the old paint using stripsol and emove some more that sticks on the pipe with a wire brush and sandpaper.
After that cleaning and prepping I brushed it with a Rust Converter solution then spray it with a 1500F flat black hi temp paint.
loply
PostPosted: 19:30 - 19 Feb 2007    Post subject: Reply with quote
I think the problem many people have with exhaust paint is that they don't sufficiently cleanse the surface beforehand.
Any minor particles or residues will inhibit the rather crucial bond between paint and metal, and in a high-temperature high-corrosion area like an exhaust the most minute inhibition will lead to flaking.
I may be wrong but I believe a sandblasting and a chemical bath of some kind is the best way, and anything short is not ideal.
Yamaha SZR660 Caution to the wind, the throttle pinned!
The last post was made 19 years, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 75.73 Kb
