Jack Up Kits
Louise
PostPosted: 10:22 - 06 Mar 2007    Post subject: Jack Up Kits Reply with quote
Looking into getting a Jack up kit for the Bandit to make it look a bit better.
But what are the Pros/cons?
The only con I can find is if im short in the leg it could pose as a problem but im not, im 5'11.
So before I buy, are there any other cons anyone can think off?
How easy is it to fit?! States 30 mins - which possibly means 2 hours for me Rolling Eyes
This is for the Bandit 600
Tankoooooo Thumbs Up
Shaun
Likes 'em bent
PostPosted: 10:40 - 06 Mar 2007    Post subject: Reply with quote
If you want to fit them your self then make sure you have a way of raising the rear end of the bike off the ground, this means without a paddock stand. Ideally you want to be able to hang it from the garage ceiling or something, failing that just lie the bike down. They shouldn't be too hard to fit and it does look quite good if you compliment the raised rear with a small plate. Wink
I've considered doing it to the FZR, sadly I don't think there's a garage roof built that could support the weight of the bike. Crying or Very sad
edd
PostPosted: 13:08 - 06 Mar 2007    Post subject: Reply with quote
It shouldnt take too much doing at all. You will need some way of lifting the bike without using the swingarm. There are loads of ways to do this. the easiest being using the centre stand (if the bike has one). If not you can use axle stands on the frame, hoist it from a girder in a roof, lift it with an engine hoist, use a swingarm spindle stand, or a hydraulic bike lift. Alternatively you could loosen off the bolts and get a strong mate (or couple of strong mates) to hold it up. Obviously it depends how rusted in the bolts are, but if you get on with it its a 5 minute job, never mind 30.
Bluespark Automotive - Diesel Tuning for Performance and Economy
Ork12
PostPosted: 13:28 - 06 Mar 2007    Post subject: Reply with quote
We had them on my bandit 600 K3 but I didn't like it due to being short and making the sidestand fairly hard to use. I've still got the bits if you want the kit you can have it for a tenner + postage?
Overall my opinion is if you really like the look of it then do it, but if it doesn't appeal lots then don't bother
Alex
Johnny GSX-R
PostPosted: 14:30 - 06 Mar 2007    Post subject: Reply with quote
It will be more unsteady at speed, I lifted the rear on my Blackbird, it turned into the corners quicker but didn't feel as steady when the pace picked up.
Kara
PostPosted: 14:35 - 06 Mar 2007    Post subject: Reply with quote
When I changed the rear shock I just put a jack underneath where the centre stand used to be attached. Seemed stable enough to me! I also had my paddock stand where it should have been just not touching the swing arm. Worked fine for meeee
NC30 + Bandit 6
www.eabikers.co.uk
craigs23
Mr Muscle
PostPosted: 14:46 - 06 Mar 2007    Post subject: Reply with quote
I wouldn't have thought they'd look 'better'.
Grubby
PostPosted: 14:52 - 06 Mar 2007    Post subject: Reply with quote
Jacked up back ends are soooo 1990's darling. Very Happy
I am me & you are he & we are all together. See how they run like pigs from a gun!
Louise
PostPosted: 23:06 - 06 Mar 2007    Post subject: Reply with quote
Are they lol?
My bike seems level 0 just flat, but the photos ive seen, to me make the bike look 10 times better Confused
Kara
PostPosted: 23:11 - 06 Mar 2007    Post subject: Reply with quote
My back shock was so knackered it looked really low and bounced like a trampoline.
NC30 + Bandit 6
www.eabikers.co.uk
Whosthedaddy
PostPosted: 23:14 - 06 Mar 2007    Post subject: Reply with quote
The steel frame does make it a little on the hefty side of things.
Without a paddock stand, I just used 2 axles stands, changing out the dog bones took all of 30 minutes and that included me doing it wrong at first.
PostPosted: 19:23 - 07 Mar 2007    Post subject: Reply with quote
If you have axle-stands you can pull the pins from the footpegs and turn the pegs over then put the stands under them. Makes it very stable.
steveh
PostPosted: 19:55 - 07 Mar 2007    Post subject: Reply with quote
i did this to the thundercat, was a piece of piss.
some swing arms work in different ways, i.e longer dog bones jack it up on mine, but longer dogbones lower it on the bandit..
Put the bike on the paddock stand, get a bottle/trolley jack, and pump it up till it takes the wieght of the rear wheel and paddock.
Stand also acts as a saftey measure if it does go down.
if you have crash bungs, do what i do, get a couple of axel stands and place them under each one ( may need a little bit of wood underneath to get the hight)
remove, and replace the dog bones.
Its a 15 min job, if that.
LUXY DJ
PostPosted: 02:52 - 08 Mar 2007    Post subject: Reply with quote
louise get a abba stand(which no 1 seems to have said about) & you can do all & more on the bike then any paddock stand & then when u change bikes u just change/buy new adaptors
abba stands lift the bike up from the frame area & although they go into the swing arm pivots you just get the other adaptors that attach to the rearsets bolt holes so swingarm can be taken out/off if you wanna do even more Wink
GSXR750
Louise
PostPosted: 14:56 - 11 Apr 2007    Post subject: Reply with quote
Been looking again
There are 35, 40 and 50 mm Jacks. What would be best?
Im not a speed freak but tend to stick around 80-90
Im 5'11 - Dont want the bike to look stupidly high that it looks weird.
Also, Main stand plus a jack is all I have Thumbs Up
Annabella
Like a person, only smaller
PostPosted: 15:04 - 11 Apr 2007    Post subject: Reply with quote
A little hefty!? I pulled a muscle in my shoulder trying to move that tank-bike thing!
I'm not a great fan of the looks myself - they are a bit 1990 Streetfighter-magazine style.
The only other con I can think of other than the handling would be how it would feel to sit on. At the moment you'll be upright, with the rear jacked up further there will be more weight through your arms and wrists which could be quite tiring to start with and on longer journeys...
Avast! Pirates ahoy!
I did Cadwell! Very Happy
beast rider
PostPosted: 15:20 - 11 Apr 2007    Post subject: Reply with quote
If you look on Ebay you should find some that are only 19mm jack up so it will give the arse end a higher look without changing the handling to much.
Plus the higher you lift the arse end the further it leans when on the side stand.
So 19mm is probably the most comfortable and after that it would just get a bit extreme, you have to think that if you go for the 50mm then thats 5cm higher or off the top of my head about 2.5 inches.
With that height you wouldn't be able to use ur center stand anymore.
feef
Energiser Bunny
PostPosted: 15:36 - 11 Apr 2007    Post subject: Reply with quote
what are the reasons for wanting the jack-up kit?
it will affect handling and stability.
by steepening the head angle, it will turn in quicker, but with a higher center of gravity, it'll also feel less stable.
A similar turn-in effect can be gained by dropping the forks thru the yokes slightly.
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
McGee
O RLY?
PostPosted: 15:40 - 11 Apr 2007    Post subject: Reply with quote
Cause its a bandit Wink
Its pronounced Jixxer!
feef
Energiser Bunny
PostPosted: 15:41 - 11 Apr 2007    Post subject: Reply with quote
ah.. for tart and pose value, and nothing practical then Wink
a
pwntifex
PostPosted: 15:52 - 11 Apr 2007    Post subject: Reply with quote
No, no. A bandit.
joneze
PostPosted: 16:34 - 11 Apr 2007    Post subject: Reply with quote
Cause its a bandit Wink[/quote]
a[/quote]
Not always no, what is wrong with customizing your own bike? Doesnt mean i want to pose its just how i want my bike to look and she obviously wants to customize hers slightly. We all own/ride bikes for our own reasons some people speed some people looks of bike or people that just want to be a bit. different
feef
Energiser Bunny
PostPosted: 16:39 - 11 Apr 2007    Post subject: Reply with quote
nothing.. nothing at all..
as long as one is aware of potential handling and stability differences that the customisation can intriduce.
a
joneze
PostPosted: 16:49 - 11 Apr 2007    Post subject: Reply with quote
a
My apiologies i thought you was having ago as you thought it was wrong to customize your bike.
LUXY DJ
PostPosted: 16:55 - 11 Apr 2007    Post subject: Reply with quote
yep will deffo effect handling as feef said
iv dropped forks thro on mine & when swingarm goes back on its having an adjustable shock mount put on Very Happy
so will point into corners NICE but this is what im after tho, hence why so much downgeared aswell cause straights are boring,twisites is where its at!
so loadsa accel & point for me please Thumbs Up Mr. Green
still get an abba @ some point tho louise, u wont regret it Wink
GSXR750
The last post was made 19 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 135.58 Kb
