| ProXimaCore |
 ProXimaCore Dougal
 Posted: 14:10 - 28 Mar 2007 Post subject: Help fitting cigarette lighter to bike battery |
I'm wanting to fit a cigarette lighter to my bike so I can power my GPS equipment. There's a couple of things I'm not sure about. Can any of you point me in the right direction?
I was thinking about buying these two below items.
https://www.maplin.co.uk/module.aspx?ITAG=FAQ&ModuleNo=37962&doy=28m3#faq
If I buy this, will this do what it says and not drain my battery if I leave the gps receiver connected while the bike is off? Will this be an acceptable alternative to wiring everything into the ignition?
https://www.maplin.co.uk/Module.aspx?ModuleNo=1055&criteria=cigarette&doy=28m3
Then I could connect it to this deviceand wire this straight on to the battery. Now, will I have to put this through a fuse before connecting to the battery? I have no idea how to do this.
The GPS device and phone will connect by usb to one of those usb sockets on the end of a cigarette lighter adaptor. I have this part already.
Can anyone see any problems with this?
Cheers. ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| map |
 map Mr Calendar
 Posted: 14:36 - 28 Mar 2007 Post subject: |
Are you going to put all the electrics and connectors out of sight? - under the seat
Otherwise maybe an issue with waterproofing. I know various sites sell the adaptors for fairing mounting. These come with weathproof covers. The standard car adaptor is known for not being too good on a bike. I think BMW have an alternative that's more secure and reliable (but that means you can't use standard car stuff).
If you're going car socket->car adapter->USB cable then I can see maybe connection/vibration problems.
Why would you need the GPS on without bike power? Otherwise it's an easy fix to take a powered lead (fused) through a relay to turn on the accessories. I'd be reluctant to attach anything direct to the battery (although to be honest have done so myself to check if things work).
Don't think this post answers your question. Can you give more info? ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 14:51 - 28 Mar 2007 Post subject: |
Yes I'd be keeping it all under the seat.
As for the vibration, if it's an issue, I can always reinforce it with some kind of masking tape. Good point though.
I don't need the GPS on when the bike is off. What I mean is, I'd like to be able to leave the GPS receiver under my seat and just leave it there permanently fixed. (Or maybe hidden inside the rear seat unit.
There may be easier ways to do this so if you've got any ideas I'd be happy to hear them. What are these websites you mention?
All I really need to do is power my PDA and a GPS receiver (both mini USB power connection). ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| funmonkee |
 funmonkee Super Spammer
 Posted: 15:04 - 28 Mar 2007 Post subject: |
Where are you planning on mounting your GPS? I chatted to Aik'666 about this the other week. You're probably best to wire it into the something like the headlights so it only comes on when the bike is on. Logan wired my heated grips into the headlights (on the GSXR) and that works fine I'm thinking about using an XDA and GPS reciever,,, The DNA headlight I have for the GSXR has plenty of space for things like this... I used it the other day to hold my bottle of sprite  ____________________ **** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b] |
| map |
 map Mr Calendar
| cestrian |
 cestrian World Chat Champion
 Posted: 15:30 - 28 Mar 2007 Post subject: |
Persoanlly I'd get the basic in-line connector and two in-line fuse holders, one for each wire going to the battery (you never know ) It's best to keep things simple IMO |
| Stav |
 Stav Nova Slayer
 Posted: 15:37 - 28 Mar 2007 Post subject: |
Don't forget an inline blade fuse, if you're connecting a TomTom or something I think 5A is the correct level. I know a guy who did similar and promptly melted £300 of GPS.
I recently wired the same cig lighter into the switched live of my Audi TT to power a TomTom One and did this, Maplins do the following part:
https://www.maplin.co.uk/module.aspx?moduleNo=24539&doy=28m3
Ideal for a bike as has a waterproof cover.
Can't help on the battery protector, why not just fit an in -line switch?
Hope that helps.
EDIT: Beaten to it again!  ____________________ Present> 03 Tuono RSV1000 - Past > 02 Honda NSR125RR > 02 Triumph TT600
Cage> 03 Audi TT |
| ProXimaCore |
 ProXimaCore Dougal
| stinkwheel |
 Posted: 15:47 - 28 Mar 2007 Post subject: |
You will need: A standard automotive four pin relay with built in fuse and a simple lighter socket with two flying wires.
Connect as follows:
Pin 30: To Battery positive.
Pin 87: To lighter socket.
Pin 85: Connect to rear brake switch power supply.
Pin 86: to earth or battery negative.
Connect the other wire of the lighter socket to earth or the battery negative.
This will give you a lighter socket that is only live when the ignition is switched on. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| map |
 map Mr Calendar
| ProXimaCore |
 ProXimaCore Dougal
| stinkwheel |
The last post was made 19 years, 111 days ago. Instead of replying here, would creating a new thread be more useful? |
