Fitting an end can to your bike??
Andy C
Tree Seeking Missile
PostPosted: 12:59 - 15 May 2007    Post subject: Fitting an end can to your bike?? Reply with quote
Hi,
When im back from uni i will be fitting my new end can.
My question, do i need any sealing agent when the exhaust goes on to help there be a proper seal or just bolting it on fine?
Its a 3 bolt end can if this helps Thumbs Up
PostPosted: 13:02 - 15 May 2007    Post subject: Re: Fitting an end can to your bike?? Reply with quote
Shouldn't do, I've never had a problem just bolting them straight on.
Andy C
PostPosted: 13:31 - 15 May 2007    Post subject: Reply with quote
thanks g Thumbs Up
I just thought since you were bolting to hard materials together the seal isnt going to be as good as if there is a seal in there.
Thanks Thumbs Up
numpty
PostPosted: 13:33 - 15 May 2007    Post subject: Reply with quote
They sometimes have a gasket built onto the end of the pipe, but its not important as even if it does leak it wont be much.
Current bike: CBR600F-Y
-Savage-
PostPosted: 13:36 - 15 May 2007    Post subject: Reply with quote
I still cant get my old can of the end of the pipes Laughing
seriously though, ive tried everything. i dont want to banjax the can, but it might come to it Crying or Very sad
numpty
PostPosted: 13:45 - 15 May 2007    Post subject: Reply with quote
Is it a slip on mate?
Andy C
PostPosted: 13:47 - 15 May 2007    Post subject: Reply with quote
Was there any sort of sealant on it when you fitted it?
Maybe try some gental heat might free it up?
PostPosted: 13:50 - 15 May 2007    Post subject: Reply with quote
There may be a gasket in the stock can when you take it off, so make sure you put that into the new can, that's about it really.
-Savage-
PostPosted: 14:20 - 15 May 2007    Post subject: Reply with quote
mines just the standard sip on style cbr exhaust. but it wont slip off lol. ive honesly tried everything. but the cand got a big dent in is, so it might come to breaing the bugger off, as its the downpipes im more concerned with keeping intact. bit ghey though. lol
Bendy
Mrs Sensible
PostPosted: 14:24 - 15 May 2007    Post subject: Reply with quote
Standard can should just slip off, undo the two bolts on the clip and then smack the can with a rubber hammer (in the relevant direction, obviously!). It's a tank of a thing.
Cos the join's near the ground, it might be pretty cruddy, but should respond well to violence.
Don't worry too much about the downpipes, you can be pretty rough with monstering them about.
numpty
PostPosted: 14:39 - 15 May 2007    Post subject: Reply with quote
big set of mole grips/pliers etc round the bottom of the can and wrench it off. Once you've got it off stubby it and use it as a spare can in case the newun gets any scratches or dents.
-Savage-
PostPosted: 15:08 - 15 May 2007    Post subject: Reply with quote
sounds like a plan numpty. last tome i tried to pull it off i went on my hole due to all the wd40 id used to try and loosen it lol but molegrips sound like an idea. need to get some sockets soon too, so il have a look next weekend. Thumbs Up
binge
Emo Kiddy
PostPosted: 23:19 - 15 May 2007    Post subject: Reply with quote
I have now got a Viper can on my bike which came from a 600. It is a slip on, but the pipe leading into the can was proper whacked in.
No amount of whacking got it back off. So i just cut the pipe off really close to the end can, Then went in with the Gas welder (Cutting nozzle) and cut the "Inner pipe" in half down each side. Then got the 2 half's out with pliers.
Obviously you cant be cutting your main exhaust pipe though. The one I had was cut off about 12" from the end can.
I'm with bendy. Just whack the thing off with a rubber mallet.
<|Ben|>
The last post was made 19 years, 61 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 2.12 - MySQL Queries: 13 - Page Size: 80.09 Kb
