Gilera Dna 50 = No spark :'(
Tt 101
PostPosted: 21:45 - 17 May 2007    Post subject: Gilera Dna 50 = No spark :'( Reply with quote
Hey There
I bought this Gilera Dna 50 (2003, 2500miles on clock) about 2 months ago and after the first month there was a problem. Its seems theres no spark in the plug (tried earthing it, nothing) and when I go to start it (does turn over), the petrol light and oil light both come on (theres full tank of petrol and oils full) I tried changing the spark plug, cap, hd leads, cdi unit but nothing :S Im quickly running out of ideas, already costing me enough trying to run it with insurance nevermind the parts! coming up to my exams and i have no transport Sad. Any Ideas or Suggestions will be greatly thank'd!
Thanks Kris Thumbs Up
5v3d3b0
PostPosted: 22:56 - 17 May 2007    Post subject: Reply with quote
Check the circuits for the lights... Did you actually change sparkplug? And nothing happens?
Tt 101
PostPosted: 11:26 - 18 May 2007    Post subject: Reply with quote
Hey, yes I changed the spark plug with a new one, the lights all electrics work, its wierd :S
Speedy3
PostPosted: 13:44 - 18 May 2007    Post subject: Reply with quote
Take the airbox off, you'll see the carb. Right on the bottom of the Carb, you will see a screw. Unscrew this and petrol thats been in the carb will drain out onto the floor, wait until it doesnt come out anymore then tighten it back up, but not too much as you'll crack the float bowl.
Then take the sparkplug out, replace it with a brand new one.
Then put keys in ignition switch to on position and start kicking the kickstart lever down. Keep kicking it down, and after a few minutes it should start.
Hope that helps, Had same problem with a scooter before.
Cigaro
PostPosted: 15:02 - 18 May 2007    Post subject: Reply with quote
Is there power going into the CDI unit? Get a cheap multimeter (£5 from Maplins) and start poking and prodding - I think you've got a bad connection somewhere.
If you're located anywhere near Blackburn I could come and take a look - I generally know electrical stuff...
cheekythomas
PostPosted: 08:07 - 19 May 2007    Post subject: Reply with quote
Chances are its stator failure... as its very common on all the piaggio 50cc models.
Its what makes the electricity needed to create the spark, the battery is only there for accessory devices ie starter, indicators etc... The starter provides main power for ignition and headlights, thats why your lights get brighter when the bikes rpm increases Wink
RH side of the engine, youll see the plastic cover with FAKE nuts on it, its behind there, and its multiplug is just in front if it near the waterpump pipe.
The only other thing which can cause spark issues on a DNA is water in the speedo unit, as the speedo is supplied with a direct feed from the CDI unit, if the speedo gets wet and shorts out, it grounds the CDI to earth and no spark... its simple to check, just unplug the speedo and see it it starts! Wink
But my moneys on stator! Cool
Tt 101
PostPosted: 16:29 - 19 May 2007    Post subject: Reply with quote
Thanks Everyone, It's the clocks which seem to have short circuited, everytime i try and connect the clocks it dies, or doesnt start, fuel light still comes on tho, ill have to buy a new set of clocks off ebay i guess.
cheekythomas
PostPosted: 10:48 - 20 May 2007    Post subject: Reply with quote
Yeah looks like it... you can try taking the clocks apart, and leaving the electrical board in a warm place (airing cupboard etc) for a couple of days, then refit it and see how it goes. Wink
DrJustice
PostPosted: 23:43 - 23 May 2007    Post subject: Reply with quote
Yeah they have a bad reputation for not being water tight ,condensation under the glass ect .best to keep them under cover and if you must ride it in the rain take an umbrella Smile
Non Omnis Moriar
cheekythomas
PostPosted: 20:56 - 24 May 2007    Post subject: Reply with quote
A little drop of silicone under the buttons and a packet of silica gel under the circuit board and they never play up again.... Wink
There is a gap of 8 years, 261 days between these two posts...
calum1003
PostPosted: 22:19 - 07 Feb 2016    Post subject: HELP Reply with quote
Did anyone else have this problem?
I have a Gilera dna 50 which has had mods and it is playing up. It has just had a new stator and ignition coil put onto it as well as a new HT lead and spark plugs. The bike run fine for a few hours and then just stopped and then there was no spark. I was riding it in the rain when it happened. The bike would just loose all power and the rev counter would be all over the place when the engine would run... It was like a ghost rev counter
The last post was made 10 years, 65 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 68.78 Kb
