Oil change question
Kris
PostPosted: 18:09 - 01 Oct 2003    Post subject: Oil change question Reply with quote
First 4-stroke oil change coming up Very Happy
Just bought some Silkolene Comp 4 10W-40 for the ZXR, is this okay? By the way - when you put a new filter on - how tight should it be? I heard hand tight is enough.
Question
www.prisonplanet.com
PostPosted: 18:12 - 01 Oct 2003    Post subject: Reply with quote
As long as its not car oil you should be ok. I'd use a filter wrench to tighten it a *bit* past hand tight I would think.
If you've got semi synthetic that should be fine. Fully synthetic possibly maybe might make the clutch slip, but its rare apparently.
Otherwise its a piece of p*ss.
TiN
Pocket Tin
PostPosted: 18:15 - 01 Oct 2003    Post subject: Reply with quote
NOOOOOOO!! You need good old Bertolli oil, it'll make your engine feel younger over time. Razz
10w40 sounds about right though. As for tightening the filter, try to use a grippy cloth or something to add a bit more leverage.
TiN
dotgems.net
Kickstart@Work
PostPosted: 18:23 - 01 Oct 2003    Post subject: Reply with quote
I use car oil in the Bandit. Not had a problem with it.
For the filter, oil the rubber O ring (doesn't the instruction on the package "Oil ring and screw until tight" sound a bit dodgy) and then just do it up hand tight. That is hand tight on a clean filter without oily hands though.
PostPosted: 18:28 - 01 Oct 2003    Post subject: Reply with quote
I topped mine up once with car oil and then waved goodbye to the clutch Confused Rolling Eyes
TiN
Pocket Tin
PostPosted: 18:30 - 01 Oct 2003    Post subject: Reply with quote
I've also read something about actually filling the filter up with oil before screwing it in (as opposed to just lubricating it).
And Ste - I think that a whole combination of factors contribute to your need to change clutches to often. Wink
TiN
dotgems.net
andrew
Mister Road Rage
PostPosted: 18:35 - 01 Oct 2003    Post subject: Reply with quote
hhhmmmm strange, i was running car oil at Elvington and it didnt cause any problems, ive heard mixed things about this. I dont see why it would be any differenent to bike oil if its the same grade??
TiN
Pocket Tin
PostPosted: 18:36 - 01 Oct 2003    Post subject: Reply with quote
Cars don't have wet clutches and so the oil lacks some components to keep the clutch sweet. Or something like that. Smile
TiN
dotgems.net
andrew
Mister Road Rage
PostPosted: 18:37 - 01 Oct 2003    Post subject: Reply with quote
Ahhhhh okie dookey. So car oil would be fine in a Ducati then? Smile
Kickstart@Work
PostPosted: 18:38 - 01 Oct 2003    Post subject: Reply with quote
Probably depends on the actual oil. I am using a BP semi synthetic car oil.
You can fill the filter up first, but it is a bit messy unless the filter mounts vertically, otherwise the oil just tips out again.
PostPosted: 18:39 - 01 Oct 2003    Post subject: Reply with quote
I don't slip the clutch (other than at BDB), I dont clutch wheelies, and rolling burnouts is done by dumping the clutch then using front brake and the throttle, not the clutch.
And the clutch that died was only about 2k miles old Crying or Very sad
Dunno about the Duke and car oil... lets try on Vickys Razz
Kris
PostPosted: 18:40 - 01 Oct 2003    Post subject: Reply with quote
Is this true Keith?
PostPosted: 18:46 - 01 Oct 2003    Post subject: Reply with quote
[edit]
Kickstart@Work
PostPosted: 18:48 - 01 Oct 2003    Post subject: Reply with quote
No it isn't true. Car oils often contain various friction modifiers which wet clutches don't like. Also some modern car oils are not as good as older car oils and bike oils. Various additives that are very good at protecting engines also happen to kill catalytic converters so are now no longer used in car oils.
Doddmaster
PostPosted: 20:12 - 01 Oct 2003    Post subject: Reply with quote
Make sure you use a clean rag to wipe the rubber O-ring on the filter cover before you smear it with oil and put it back on. It has to be more than hand tight, but not much more. I snapped an engine bolt over-tightening the filter cover once
Kickstart@Work
PostPosted: 20:16 - 01 Oct 2003    Post subject: Reply with quote
Most bikes these days have a complete disposable filter that you screw on, rather than a filter that lives under a cover.
Stew
If it's good enough for top race teams...
PostPosted: 21:42 - 01 Oct 2003    Post subject: Reply with quote
Yeah as Keith says the reason car oils are said to be no good for bikes is down to these extra additives (the friction modifiers) which have been known to cause bikes clutches to slip. It obviously doesnt happen to everyone(or every bike) but I would suggest that buying an oil specifically designed for use in bikes makes sense anyway.
Oh, and I use Silkolene Comp 4 10W-40 (is it called 'ride' or something) in my 750 too. Very Happy
"Unlike public school you don't need to have your arse up and your head down to go a long way...."
Doddmaster
PostPosted: 23:34 - 01 Oct 2003    Post subject: Reply with quote
My bike was designed 15 years ago so I think I can be let off Razz
PostPosted: 01:38 - 02 Oct 2003    Post subject: Reply with quote
And the rest Wink
The GPZ500 used to have a filter like yours but the changed it for the later style ones. You cannot even get the original filters anymore. The FZ and Bimota both have set ups like yours. Being honest they are a bit of a pain but at least the filters are cheaper (good job as I have about 20 spare bike oil filters floating round).
The last post was made 23 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.13 - MySQL Queries: 13 - Page Size: 103.67 Kb
