Cagiva Supercity leaking fork seals
j.o.n.n.y.g
PostPosted: 20:59 - 09 Jul 2007    Post subject: Cagiva Supercity leaking fork seals Reply with quote
Hi, picked up an eBay bargain Supercity 125, 1994, 6000kms, de restricted, new pistons and rings, runs lovely - small problem..... front fork seals are shot, not a little but a lot! Oh and the MOT is due in under a month!
Having done the usual eBaying and Googling with no success apart from to find 1999/2000 Supercity seals or 1994 Mito seals, can anyone out there suggest a place I can look or advise as to which others would fit please?
Also read somewhere that if the seals are gone chances are the bushings could probably do with replacing - is this true?
Is this something to attempt myself or am I best booking it in to have it done somewhere?
If it flies, floats or f***s, rent it!
Supercity 125 Lucky Explorer R.I.P. - Jinlun JL 125 11..... next.......
veeeffarr
PostPosted: 21:10 - 09 Jul 2007    Post subject: Reply with quote
Bushes are usually advisable to do with the new seals
Basically the seals are more likely to last longer, the little dears
Also make sure you clean the stantcions before installing the seals, etc
To be honest with you, you are probably best off taking the forks off and taking them to a garage and let them worry about it, it can be a right ballache.
T
j.o.n.n.y.g
PostPosted: 21:44 - 09 Jul 2007    Post subject: Reply with quote
Thanks for that, will get it down to a local workshop asap.
As this is my main commuting machine (apart from pedal power!) how safe would it be to ride as is? And what risk am I taking by riding it? (Should it be alright to take down to the garage?)
veeeffarr
PostPosted: 22:16 - 09 Jul 2007    Post subject: Reply with quote
I rode mine with leaking seals for 9 months
j.o.n.n.y.g
PostPosted: 22:18 - 09 Jul 2007    Post subject: Reply with quote
So apart from the fact it will fail the MOT in a month, it's not really serious? Great, bring on the sunshine and dry roads!!
veeeffarr
PostPosted: 22:29 - 09 Jul 2007    Post subject: Reply with quote
When you're doing your MOT lift the dust caps off of the fork seals and push cotton wool/tissue paper down and then replace the dust caps
But get it fixed properly as soon as you can
T
abstractduk
PostPosted: 23:20 - 09 Jul 2007    Post subject: Reply with quote
hey do you have a spare
expansion chamber you might want to sell?
londoncourierrat
SoND
PostPosted: 23:22 - 09 Jul 2007    Post subject: Reply with quote
It'll make the front end bouncy and affect the handling. You can ride like that but it's a lot better when they're fixed. Keep an eye on the oil getting on the brakes and the tyre.
abstractduk
PostPosted: 00:04 - 10 Jul 2007    Post subject: Reply with quote
yoour bike will wheelie really easy with no oil in the forks, you can get seals from mme in london e1 there about 13 pounds..is easy to do yourself and i had a shop try before and they bodged it completely...i had to show them how to put oil down the stanchion before you refit it. i changed my seals 3 times and really if there leaking you can guarantee you have scores down the stanchions which youll need to fill with some very liquid chemical metal the wet and dry it til its level with the chrome...feel around the stanchion with your finger nail for grooves before you take them apart. get them rechromed ir do the chemical metal thing.
londoncourierrat
befdelta7
PostPosted: 14:38 - 10 Jul 2007    Post subject: Reply with quote
its fine to ride with leaking for seals, iv been riding my supercity with leaking fork seals for about 5months!
i even got pulled by the traffic police, all they said was leaking fork seals are an MOT failer but "i can not do you for them" and advised me to get them changed asap then i was allowed to go on my way.
ask the bloke who is selling these fork seals for a set for your 1994 supercity...
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&sspagename=ADME%3AL%3ARTQ%3AUK%3A1&viewitem=&item=270130078412&rd=1
he does have them, i have asked him for a set for my 1992 supercity and heres his reply:
Hi James,
Yes we will stock them, do you know the diameter of your forks? you can purchase them through this listing and just mention in your paypal/payment that you need them for your 1992 Supercity and we will put the correct ones in.
Kind regards,
Nik
just got to order a set now Thumbs Up Thumbs Up Thumbs Up Thumbs Up
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
veeeffarr
PostPosted: 15:55 - 10 Jul 2007    Post subject: Reply with quote
If you can buy genuine seals and bushes, but I'm an advocate of genuine parts anyway.
T
cagiva gezzer
PostPosted: 16:22 - 10 Jul 2007    Post subject: Reply with quote
You want OE fork seals from MitoMondo or Threecross motorcyles.
The pattern ones are the wrong size. They're about 0.5mm off.
No need for new bushes. You'll need some new fork oil, best to go up 2.5W to help reduce future leakages.
Jack the front of the bike up, remove wheel, remove caliper, remove mudguard.
Remove bars, remove allen bolt under bars, push up stanchion to pop out collar. Withdraw stanchinon from slider. Drain oil from stanchion. Remove slider from yokes. Remove dust seal. Remove C cilip from inside of slider. Clean area. Press in new seal. Replace C clip. Lube. Replace dust seal. Put slider back in yokes. Fill stanchion with oil up to the hole. Place stanchion in slider. Add a BIT of oil for luck. Replace collars. Replace top bolt.
Repeat with other leg. Only one leg is sprung.
Job sorted. I'm in Aylesbury if you want to pay for assistance. Thumbs Up
befdelta7
PostPosted: 20:06 - 10 Jul 2007    Post subject: Reply with quote
shame your to far away from me cagiva geezer id gladly pay you to help me do it Neutral
is it really that easy to do??!!
i might give it ago tomorrow after work... er better get the seals first i think LOL then give it ago Wink
cagiva geezer...
any step by step guide Wink Thumbs Up Question
PostPosted: 20:49 - 10 Jul 2007    Post subject: Reply with quote
I would not advise riding with blown fork seals. Handling will become unstable at times. Possibly most dangerous is the oil covering the brake disk and destroying most of the braking power. Also running with blown seals for a while will eventually result in no oil, and soon afterwards trashed fork bushes.
Suspect they could do you for various things, just chose not to.
abstractduk
PostPosted: 21:27 - 10 Jul 2007    Post subject: Reply with quote
i even had a prohibiton put on my bike before because the seals had blown...
londoncourierrat
cagiva gezzer
PostPosted: 21:29 - 10 Jul 2007    Post subject: Reply with quote
OE part number is CA800037977 @~£12/ea.
Use 10W fork oil, instead of OE spec 7.5W.
It's an easy job on the grand scale of things. Hardest part is removing the C clip that holds the seals in. You need a scribe or fine punch to hook it out.
Even if you can't split the forks, getting the legs out and dropping them off at a local place will save you ££.
Just don't scrimp on the seals. As said. pattern ones are too small and leak within weeks.
j.o.n.n.y.g
PostPosted: 18:07 - 12 Jul 2007    Post subject: Reply with quote
Thanks for everyone's help on this one - have sourced seals Very Happy (as well as throttle cable and brake pads which I have since discovered need replacing! Crying or Very sad ) from Mito Mondo, not the cheapest but genuine parts. Wink
Going to have a go at the job this weekend with a mate who seems to know what he's doing Rolling Eyes
Special thanks to K who helped make all this possible!
I'll let you know how I get on.
kvnsmth
PostPosted: 09:36 - 01 Sep 2007    Post subject: Reply with quote
just read this, and done my forks, cheers for the iinfo cagiva geezer, was a doddle after reading through this post, and the one about the exhuast leak, your full of good info m8
sickpup
Old Timer
PostPosted: 14:15 - 01 Sep 2007    Post subject: Reply with quote
It's not fine to ride with defective fork seals.
It's 3 points and a £60 fine for each blown seal just as it is for blown shock absorbers on a car. Also if the fork oil has reached the front brakes you can also be charged with defective brakes not to mention the danger of oil on the bakes and the front tyre.
Generally in London a prohibition notice will be put on a bike for defective seals, it really is that serious.
Absolute rubbish.
Considering there are many pattern seal suppliers who supply seals of different qualities and seals come in many different sizes you are talking crap.
No need for new bushes. You'll need some new fork oil, best to go up 2.5W to help reduce future leakages. No need for new bushes. You'll need some new fork oil, best to go up 2.5W to help reduce future leakages.
How can you decide without even looking at the fork legs that they don't need bushes?
Why add thicker fork oil and alter the damping rate when you can just service the forks properly?
befdelta7
PostPosted: 16:20 - 01 Sep 2007    Post subject: Reply with quote
mine are done now, so much smoother to ride now!
The last post was made 19 years, 60 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 111.57 Kb
