| j.o.n.n.y.g |
 j.o.n.n.y.g Derestricted Danger
 Posted: 20:59 - 09 Jul 2007 Post subject: Cagiva Supercity leaking fork seals |
Hi, picked up an eBay bargain Supercity 125, 1994, 6000kms, de restricted, new pistons and rings, runs lovely - small problem..... front fork seals are shot, not a little but a lot! Oh and the MOT is due in under a month!
Having done the usual eBaying and Googling with no success apart from to find 1999/2000 Supercity seals or 1994 Mito seals, can anyone out there suggest a place I can look or advise as to which others would fit please?
Also read somewhere that if the seals are gone chances are the bushings could probably do with replacing - is this true?
Is this something to attempt myself or am I best booking it in to have it done somewhere? ____________________ If it flies, floats or f***s, rent it!
Supercity 125 Lucky Explorer R.I.P. - Jinlun JL 125 11..... next....... |
| veeeffarr |
 veeeffarr Super Spammer
| j.o.n.n.y.g |
| veeeffarr |
| j.o.n.n.y.g |
| veeeffarr |
| abstractduk |
 abstractduk Two Stroke Sniffer
| SoND |
 SoND World Chat Champion
| abstractduk |
| befdelta7 |
 befdelta7 Brolly Dolly
 Posted: 14:38 - 10 Jul 2007 Post subject: |
| veeeffarr |
| cagiva gezzer |
 cagiva gezzer World Chat Champion
 Posted: 16:22 - 10 Jul 2007 Post subject: |
You want OE fork seals from MitoMondo or Threecross motorcyles.
The pattern ones are the wrong size. They're about 0.5mm off.
No need for new bushes. You'll need some new fork oil, best to go up 2.5W to help reduce future leakages.
Jack the front of the bike up, remove wheel, remove caliper, remove mudguard.
Remove bars, remove allen bolt under bars, push up stanchion to pop out collar. Withdraw stanchinon from slider. Drain oil from stanchion. Remove slider from yokes. Remove dust seal. Remove C cilip from inside of slider. Clean area. Press in new seal. Replace C clip. Lube. Replace dust seal. Put slider back in yokes. Fill stanchion with oil up to the hole. Place stanchion in slider. Add a BIT of oil for luck. Replace collars. Replace top bolt.
Repeat with other leg. Only one leg is sprung.
Job sorted. I'm in Aylesbury if you want to pay for assistance.  ____________________ "because one stroke isnt enough and four strokes waste two" |
| befdelta7 |
 Posted: 20:06 - 10 Jul 2007 Post subject: |
shame your to far away from me cagiva geezer id gladly pay you to help me do it
is it really that easy to do??!!
i might give it ago tomorrow after work... er better get the seals first i think LOL then give it ago
cagiva geezer...
any step by step guide  ____________________ Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine. |
| Kickstart |
 Kickstart The Oracle
| abstractduk |
| cagiva gezzer |
| j.o.n.n.y.g |
 Posted: 18:07 - 12 Jul 2007 Post subject: |
Thanks for everyone's help on this one - have sourced seals (as well as throttle cable and brake pads which I have since discovered need replacing! ) from Mito Mondo, not the cheapest but genuine parts.
Going to have a go at the job this weekend with a mate who seems to know what he's doing
Special thanks to K who helped make all this possible!
I'll let you know how I get on. ____________________ If it flies, floats or f***s, rent it!
| kvnsmth |
 kvnsmth L Plate Warrior
| sickpup |
 sickpup Old Timer
| befdelta7 |
The last post was made 19 years, 62 days ago. Instead of replying here, would creating a new thread be more useful? |
