Help!
phantomtek
Lil Joe Tek
PostPosted: 21:52 - 04 Sep 2007    Post subject: Help! Reply with quote
Hi guys,
Got my GSXR600Y on saturday, and been riding it about. I noticed that it was jumping forward abit under normal acceleration, lurching forward slightly, sometimes not so bad but sometimes alot, what could this be? Does it alot, not just once.
To remedy it, I decided to take the bike apart and have a look around, the air filter was filthy so I cleaned and oiled it with K&N stuff (It's a BMC filter), the amount of shit that came out of it was unreal! I noticed upon putting the airbox back on that it doesn't sit flush on the ram air ducts on the frame, would this be a major problem?
Anyway, got the airbox off and checked the cables for play and they were fine, changed 3 of the plugs (All that halfrauds had in, one was semi ok so I left that one) and put it back together and started it up, also turned the idle up as it was warming so that it wouldn't die, but I think the choke might be stuck or something as as I rev it, it takes longer than usual for the revs to drop. Is this what would be causing it?
Gonna pull it apart again tomorrow anyway, how much would a mechanic charge to clean and balance my carbs (I think it needs doing?) if they charge £30 an hour?
Cheers.
Im-a-Ridah
PostPosted: 22:03 - 04 Sep 2007    Post subject: Re: Help! Reply with quote
phantomtek wrote:
Hi guys,
Cheers.
Well if it was me I'd run some carb cleaner through it before taking it to a mechanic Smile
hmmmnz
PostPosted: 07:01 - 05 Sep 2007    Post subject: Reply with quote
generally when the revs take longer to drop, it indicates that you have an air leak, since you took the air box off. i will assume that its you havn't made a good seal over 1 or more of the carbs.
it would be cheaper for you to buy a set of balancers, and do it your self than take it to a mechanic Thumbs Up
have fun
the humans are dead
I kick arse for the lord
Marah
PostPosted: 09:42 - 05 Sep 2007    Post subject: Reply with quote
I got a Carbtune direct from the company arrived next day took about an hour to do it first time next time it will be half that as I know what I am doing now, its fairly straight forward. It will cost about the same as taking it to a garage next time though you'll be doing it for free Thumbs Up
Someone complimented me on my driving. They left a note on my windscreen, it said "Parking Fine" Very Happy
Old Bikes -1990 Yamaha DT50MX > 1988 Kawasaki KMX125 > 1991 Kawasaki KMX125 > 1981 Yamaha XS250SE > 2000 Suzuki Bandit 600 > 1999 Kawasaki ZX7R Ninja
Bike - 1999 Suzuki Bandit 1200
phantomtek
Lil Joe Tek
PostPosted: 12:44 - 05 Sep 2007    Post subject: Reply with quote
Cheers guys, I'm going to go see if it does indeed have a leak shortly!
And Marah, I think I will invest in one of those sets, seen as you are right, though I still don't know how to clean the carbs! That looks really easy to do aswell, cheers for that!
What materials do I need to clean a set of carbs, or if anyone has a walkthrough that would be great! Very Happy
hmmmnz
PostPosted: 14:57 - 05 Sep 2007    Post subject: Reply with quote
heres a good walk through
https://oldmanhonda.com/MC/Rcarbs.html or here https://www.dansmc.com/carbs.htm
you could take pics when you do yours, so others can see how easy it is Very Happy
the humans are dead
phantomtek
Lil Joe Tek
PostPosted: 15:30 - 05 Sep 2007    Post subject: Reply with quote
I discovered the carbs weren't seated on the engine properly, so I've sorted that, and now I'm off out for a test Very Happy
And I will do, cheers Very Happy
phantomtek
Lil Joe Tek
PostPosted: 18:00 - 05 Sep 2007    Post subject: Reply with quote
It's still fockin doing it! Just the juddering thing though, not the rest, I think its definitely the carbs though so I'll give em a good clean and see how it goes, going to order the carb balancer thingy too as I could charge my mates a fiver a pop to balance their carbs Laughing
If anyone can tell me for definite what the jumpiness is, I will be forever in your debt. Very Happy
finpos
PostPosted: 23:04 - 07 Sep 2007    Post subject: Reply with quote
Revs not dropping was prob. the air leak.
Sudden power surges, I would say, are usually caused by one of the pistons suddenly kicking back IN, i.e. it runs on 3 pots most of the time with the fourth banging in and out as it sees fit which causes the jerkiness. That's normally an electrical problem, and that's normally the HT leads. Would have thought the new plugs may have made it a bit better if that was the case.
f.
yambabe
PostPosted: 00:45 - 08 Sep 2007    Post subject: Reply with quote
I think I had a similar thing with my Intruder last month. Does it kind of feel like it's surging forward and then dropping back all by itself even though the revs are constant? Does it feel like it might be going to drop a cylinder when you are going slowly (sub-30 mph) and particularly on slow turns? Feels a bit gutless in 1st and 2nd gears, or at least more gutless than you were expecting? Any popping or backfiring from the exhaust?
Mine turned out to be the air mixture not set properly. Got it adjusted when the bike went in for its first service and it's been absolutely fine ever since. It might be worth you checking?
phantomtek
Lil Joe Tek
PostPosted: 09:40 - 08 Sep 2007    Post subject: Reply with quote
Cheers for that, will sort the mixture when I clean the carbs (I don't know how but I'll get there Laughing
My carbtune arrived this morning, along with braided lines and bungs! Was setting myself for a nice full day tinkering, when my boss calls and said someone has called in sick and I will get extra if I go in today! So I can't really refuse, get myself some nice bike money Very Happy
But cheers for the advice guys, I will check both those things Thumbs Up Smile
TUG
PostPosted: 11:14 - 08 Sep 2007    Post subject: Reply with quote
possible that your clutch is going? but i'd say its the mixture on your bike, mine is doing same at 4000rpm new zhaurst and not chanced mixture, make sure they're in sync too. Very Happy Thumbs Up
Karma
Haz ER-5, innit!
phantomtek
Lil Joe Tek
PostPosted: 12:28 - 08 Sep 2007    Post subject: Reply with quote
Has anyone got any tips on sorting out the mixture?
I was going to use a Colortune but I don't think it would be easy on a bike, as the spark plugs are sunk into the engine head!
TUG
PostPosted: 16:56 - 08 Sep 2007    Post subject: Reply with quote
if its ticking, its too lean, if it gets hot quick then its again too lean, if it takes ages for it to heat up its running too rich, and if it back fires when u slow down then its running too lean agin or could be rich too. Thumbs Up
Karma
Haz ER-5, innit!
The last post was made 19 years, 31 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 85.99 Kb
