nsr deristriction
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2
kenny
PostPosted: 01:25 - 15 Sep 2005    Post subject: Reply with quote
alains wrote:
hey , kenny can you reach 12000 RPM in 4th gear , if not , you have some other restriction . "the best animal on earth is the hen , because she only cackle when she has lay her egg"
i can reach all the way round to the stop in every gear on mine
but it gears out at 80
but that nowt to do with hens?
KeNNy 100cc peugot speedfight 125cc Honda NSR125R 650cc suzuki SV650R 125cc suzuki GZ125 600cc yamaha YZF-R6
alains
PostPosted: 02:52 - 15 Sep 2005    Post subject: Reply with quote
at 12000 rpm in 6th you should reach 120 mph with 14x36 , so i do not trust you
kenny
PostPosted: 14:12 - 16 Sep 2005    Post subject: Reply with quote
mine must be a magic bike then lol coz im telling you it wont go past 80mph but redlines in every gear
alains
PostPosted: 18:40 - 16 Sep 2005    Post subject: Reply with quote
so change your sprockets !
Marci
PostPosted: 19:56 - 16 Sep 2005    Post subject: Reply with quote
Could be down on compression - may be worth checking piston rings...
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
kenny
PostPosted: 14:51 - 28 Sep 2005    Post subject: Reply with quote
eh say that first wot i was going to do Confused
kenny
PostPosted: 14:52 - 28 Sep 2005    Post subject: Reply with quote
no its got loads of compresion its only done 6k from new
John C
PostPosted: 17:27 - 28 Sep 2005    Post subject: Reply with quote
What!... mine redlines at 11000 rpm in 6th. This is about 104mph
You can go a bit faster, but this means operating the engine in the red...I'm not partial to trying this.
alains
PostPosted: 17:34 - 28 Sep 2005    Post subject: Reply with quote
do you know that the crankshaft has been tested at 15000 rpm during 36 Hours with less than 0.5% of break down . the only tip at these speed is to run a bit more rich and oily .
John C
PostPosted: 18:09 - 28 Sep 2005    Post subject: Reply with quote
Yep, and that's why you have to change your piston rings every five minutes.
For you average person (like me), all you need to do is this.
Arrow Take the intake plate out (between the carb & engine)
Arrow Take the exhaust restrictor pipe out
Arrow Clean the air filter (see you bike manual)
Arrow Make sure you have 14 & 36 sprockets
Arrow Fit a BR9IEX (Iridium spark plug from NGK)
Arrow Clean Carb
Exclamation Unless you bought a non UK bike - In that case good luck Exclamation
Don't even bother with all this rejetting, fitting a fancy exhaust or fucking about with the carb, you'll only serve to make the motor seize before it's time.
Yes these measures will add a tiny bit more power and speed, but unless you are using it in competition, or you have the want / need to change your piston rings every 7500 miles and rebuild your top end every 22500miles don't even bother.
Just save your money for a bigger bike.
Besides, in the UK, being able to put your bike back to the restricted state, and putting the L-Plates back on will increase the resale value when you come to sell.
Who wants to buy a time bomb (about to seize) two stroke from a young lad with a fancy exhaust whos been racing around. Exactly, what people want is a perfect condition bike that's never been passed 8000rpm, and been used for a couple of thousand miles by a learner.
alains
PostPosted: 19:08 - 28 Sep 2005    Post subject: Reply with quote
you certainly had not caught everything . except the mechanical restrictions (exhaust, intake plate) the UK specs bike are not restricted . the (or import from) french , swiss , german NSR125R are restricted (electronics and barrel design) and in germany they have a box restriction for limiting at 80km/h for youth and beginers(the insurance is reduced by half) . the only thing that uk ridders do not know is precisely these restrictions , otherwise they would have bought uk specs .(and i think this is thieving from sellers who surely know) . buyers if you see a letter B after JC22 it's french !
John C
PostPosted: 19:13 - 28 Sep 2005    Post subject: Reply with quote
Good point - Cheers alains - Post Editied ^^^
maxpower125
PostPosted: 16:31 - 06 Oct 2005    Post subject: Reply with quote
make sure theres no wind get your head actually on the top yoke, and hold the gas back, mine did 92 indicated in 5th at 10500rpm, not 6th, people went on about the great power, in reality it aint that mental , only a little un
There is a gap of 1 year, 335 days between these two posts...
mike.nsr125
PostPosted: 02:05 - 07 Sep 2007    Post subject: NSR FRENCH S%*T!!! Reply with quote
Hi there, i got two NSR`s a j reg gold Alcast Italian import which is so hard to buy parts for ! (so just for any1 considering buying 1 don`t !) Any ways the newest is a y reg (01 bike) and i just read that if theirs a b after the jc22 well then its French which i was really p.o`d about but then i remembered i bought a UK spec cdi so i fitted it and WOW !!! The difference was amazing i`m going to buy a RC controller as well but i was just wondering what exactly am i meant to buy ? let me know Very Happy
MIKE.NSR125
konsoli
PostPosted: 02:24 - 07 Sep 2007    Post subject: Reply with quote
restrictions on NSR125: front sprocket, carb, exhaust
after fixing all that, you can usually get 0-60 in 6 seconds and a top speed of approx 110mph.
sorted Thumbs Up
alains
PostPosted: 09:25 - 07 Sep 2007    Post subject: Reply with quote
apparently you know a little about restrictions . we keep working on it since 5 years on our forum and it's not as simple as you think !
ncrn
PostPosted: 11:21 - 07 Sep 2007    Post subject: Reply with quote
sorted Thumbs Up
If its a UK model it is that clear cut, apart from the necessary up jetting and modifications to the air box.
However if you are running an import model, well its a lot more complicated than that Wink
Nixon
PostPosted: 14:39 - 08 Sep 2007    Post subject: Reply with quote
i know its a rly old topic but if its here its here lol
my rear sprocket has 38 teeth is that wayyyy to big or not?
is it worth getting it changed when i do my chain?
and what is this sprocket likely to be doing to my bike? ie better acceleration, nothing ect
not sure on the front! how can i check?
cheers
alains
PostPosted: 15:07 - 08 Sep 2007    Post subject: Reply with quote
the 1999-2001 bikes have been equiped with 14 in front and 38 in rear . when changing it ask for 14x36 you will gain about 4 mph and the loss in acceleration will be insignificant
The last post was made 19 years, 31 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 104.15 Kb
