single phase reg/rect replacement
hmmmnz
PostPosted: 16:30 - 11 Sep 2007    Post subject: single phase reg/rect replacement Reply with quote
does any one know where i can get a reg/rect as a replacement for my seperate bridge rectifier and zenar diode regulator,
its for a cb250g5
the wattage output of the alternator is 130w @ 5000rpm
or does any one know of any bikes that run a single phase alternator with a single unit reg/rect that i can look out for on ebay Very Happy
cheers
the humans are dead
I kick arse for the lord
PostPosted: 16:45 - 11 Sep 2007    Post subject: Reply with quote
Just use a 3-phase one and only connect one of the yellows.
A superdream one would seem to fit the bill.
Or try www.davidsilverspares.co.uk they sometimes have old bits like that in stock and are sometimes pretty cheap.
I for one am shocked to hear there is still a G5 out there in something approaching running order.
hmmmnz
PostPosted: 16:57 - 11 Sep 2007    Post subject: Reply with quote
its not in just running order, its near perfect Very Happy except for the stupid rectfier Very Happy
a 3 phase one you say, hmmm so connect up both phase and neutral to 2 or the 3 phase wires and just tape up the spare??
sounds like it could be a good idea Thumbs Up
your a gent and a scholar stinkwheel, Thumbs Up
the humans are dead
PostPosted: 17:37 - 11 Sep 2007    Post subject: Reply with quote
Well a superdream one has a red wire which you connect to the battery positive, a green one you connect to earth and a white on black one you connect to somewhere in the loom carrying battery voltage when the ignition is on (eg back brakelight switch) or if you're feeling lazy, loop it back to the red wire (not as good but still functional).
There are three yellows. If you have a single phase, connect it to one of them and blank off the other two.
david1959
PostPosted: 22:25 - 19 Sep 2007    Post subject: rectifier Reply with quote
you may be able to replace it with a bridge rectifer from maplin or farnell
it will be a lot cheaper too
look for a 15A one giving you a good safety margin on the wattage
david
xs500c owner from 1978
hmmmnz
PostPosted: 22:29 - 19 Sep 2007    Post subject: Re: rectifier Reply with quote
david
i got a 35a one, a 15a would be right on the edge, and probly would go over in high revs,
turns out i didnt need it any way, as there was a couple of broken wires on one of the plugs
the humans are dead
PostPosted: 01:45 - 20 Sep 2007    Post subject: Reply with quote
Aye. Having looked at your wiring diagram on your other post, it actually has a bridge rectifier anyway, should be pretty robust.
If it's the same as the one off my old CB125 was (same year as the 250G5, 15mph faster Razz ), it's just a cluster of diodes right? You'd be able to replace all four for a couple of quid if it went tits-up.
hmmmnz
PostPosted: 01:55 - 20 Sep 2007    Post subject: Reply with quote
its a solid unit, but inside it, its just 4 diodes, if push came to shove then you could just use individual diodes, but bridge rectifiers are really easy to get hold of from any electronics store,
yeah the g5 ain't too fast, happily cruises at about 75 with un balanced carbs, but takes a while to get there Very Happy
was the 125 a twin as well, or just half a 250 Very Happy
the humans are dead
PostPosted: 11:46 - 20 Sep 2007    Post subject: Reply with quote
The 125 was a twin. They were well regarded wee bikes. I ran mine for a year before both carbs and most of thewiring system dissolved into a pile of white powdery terminal obsolescence.
hmmmnz
PostPosted: 13:37 - 20 Sep 2007    Post subject: Reply with quote
lol, damn, i blame it on the salted roads Very Happy
the humans are dead
PostPosted: 22:13 - 20 Sep 2007    Post subject: Reply with quote
I blame it on the Japanese wanting you to buy lots of new motorcycles instead of keeping your old ones.
The last post was made 18 years, 361 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 74.48 Kb
