| hmmmnz |
 hmmmnz Super Spammer
 Posted: 16:30 - 11 Sep 2007 Post subject: single phase reg/rect replacement |
does any one know where i can get a reg/rect as a replacement for my seperate bridge rectifier and zenar diode regulator,
its for a cb250g5
the wattage output of the alternator is 130w @ 5000rpm
or does any one know of any bikes that run a single phase alternator with a single unit reg/rect that i can look out for on ebay
cheers ____________________ the humans are dead
I kick arse for the lord
 Posted: 16:45 - 11 Sep 2007 Post subject: |
Just use a 3-phase one and only connect one of the yellows.
A superdream one would seem to fit the bill.
Or try www.davidsilverspares.co.uk they sometimes have old bits like that in stock and are sometimes pretty cheap.
I for one am shocked to hear there is still a G5 out there in something approaching running order. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| hmmmnz |
 Posted: 17:37 - 11 Sep 2007 Post subject: |
Well a superdream one has a red wire which you connect to the battery positive, a green one you connect to earth and a white on black one you connect to somewhere in the loom carrying battery voltage when the ignition is on (eg back brakelight switch) or if you're feeling lazy, loop it back to the red wire (not as good but still functional).
There are three yellows. If you have a single phase, connect it to one of them and blank off the other two. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| david1959 |
 david1959 Derestricted Danger
| hmmmnz |
 Posted: 01:45 - 20 Sep 2007 Post subject: |
Aye. Having looked at your wiring diagram on your other post, it actually has a bridge rectifier anyway, should be pretty robust.
If it's the same as the one off my old CB125 was (same year as the 250G5, 15mph faster ), it's just a cluster of diodes right? You'd be able to replace all four for a couple of quid if it went tits-up. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| hmmmnz |
 Posted: 01:55 - 20 Sep 2007 Post subject: |
| stinkwheel wrote: | Aye. Having looked at your wiring diagram on your other post, it actually has a bridge rectifier anyway, should be pretty robust.
If it's the same as the one off my old CB125 was (same year as the 250G5, 15mph faster  ), it's just a cluster of diodes right? You'd be able to replace all four for a couple of quid if it went tits-up. |
its a solid unit, but inside it, its just 4 diodes, if push came to shove then you could just use individual diodes, but bridge rectifiers are really easy to get hold of from any electronics store,
yeah the g5 ain't too fast, happily cruises at about 75 with un balanced carbs, but takes a while to get there
was the 125 a twin as well, or just half a 250  ____________________ the humans are dead
 Posted: 11:46 - 20 Sep 2007 Post subject: |
The 125 was a twin. They were well regarded wee bikes. I ran mine for a year before both carbs and most of thewiring system dissolved into a pile of white powdery terminal obsolescence. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| hmmmnz |
 Posted: 13:37 - 20 Sep 2007 Post subject: |
The last post was made 18 years, 360 days ago. Instead of replying here, would creating a new thread be more useful? |
