Stuck Banjo bolt...
Reppyboyo
PostPosted: 13:40 - 20 Sep 2007    Post subject: Stuck Banjo bolt... Reply with quote
Hi,
Im the process of changing a brake line (thanks for the guide Stinkwheel) however I cant undo the banjo bolt on my caliper.
Its on there damn tight and Im afraid of snapping it.
The one on the master cyliner was also tight but a little force and it was off.
Any ideas on how I could free the bolt on the caliper?
TUG
PostPosted: 14:02 - 20 Sep 2007    Post subject: Reply with quote
keep it attached to its bracket if possible and get a breaker bar and aa socket and give it a right good push. lol if it breaks off inside then i can only suggest taking it to a local mech to be repaired, my caliper was seized so badly they had to heat it up and now have a 2 tone caliper.
Haz ER-5, innit!
tatters
Exxon Valdez
PostPosted: 17:59 - 21 Sep 2007    Post subject: Reply with quote
Try and heat the banjo bolt up with a blow torch while you turn it, its a bit risky as brake fluid is flammable but heat is the best bet for a seized bolt/nut.
(you can get a cheap blow torch from halfords for around £20)
geordiecbrblo...
PostPosted: 18:09 - 21 Sep 2007    Post subject: Reply with quote
Try tightening the bolt a little bit before undoing it Thumbs Up
TUG
PostPosted: 18:20 - 21 Sep 2007    Post subject: Reply with quote
aye, tightening can "crack" it making it easier to undo it, nice one
geordiecbrbloke
Haz ER-5, innit!
konsoli
PostPosted: 18:26 - 21 Sep 2007    Post subject: Reply with quote
It can also damage it.
I reccommend doing it when it's hot or cold (most objects, brick, wood, metals...contract in the cold)...but heat can be good too, it loosens them off.
TUG
PostPosted: 19:14 - 21 Sep 2007    Post subject: Reply with quote
it will only damage it if you go crazy wit it, where talking a 1mm tighter then when u hear the click sound you will be able to undo it way easier than before.
Haz ER-5, innit!
PostPosted: 19:58 - 21 Sep 2007    Post subject: Reply with quote
Get some freeze and release spray. Spray liberally, leave to stand. Spray again and undo.
Big Pete
PostPosted: 21:10 - 21 Sep 2007    Post subject: Reply with quote
heat the caliper around the bolt, hasnt failed me yet.
Trust me, I`m an engineer
GarageOfPower.co.uk
druidsam
PostPosted: 00:02 - 22 Sep 2007    Post subject: Reply with quote
i usually find that a good six sided socket ,T bar and a length of pipe for an extension works.Dont bounce or jerk,just apply decent pressure and it should go.
.......................Sam
trust me! I'm a druid
https://www.bikerforum.co.uk/
The last post was made 18 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 62.14 Kb
