Neutral switch is stuck or something? Help please?
lugoismad
PostPosted: 16:09 - 05 Oct 2007    Post subject: Neutral switch is stuck or something? Help please? Reply with quote
I just picked up a CB750 yesterday.
The neutral light is always on, however when it goes into neutral, it gets even brighter. Not a whole lot brighter, but just a bit. Not that annoying during day, but at night its obnoxious having a green light shining in your eyes.
Any ideas on what to check?
TUG
PostPosted: 16:21 - 05 Oct 2007    Post subject: Reply with quote
the switch by the gear box that telle the light to come on and go off then your not in neutral? the wires around the area and possibly your fuses i would check, i'm not good on the spark side of bike though, someone will know on here. but i'd check what i've just said anyway.
Haz ER-5, innit!
PostPosted: 16:24 - 05 Oct 2007    Post subject: Reply with quote
The gear selector switch should be next to where the gear selector arm goes into the gearbox.There will be a little round black thing with 2 screws holding it on.There should be 1 wire comeing off it.
Take that out and try checking/changing it for a known good one.
Might have to take the front sprocket cover off to get to it.
It's like that on the bikes i've worked on but dont hold me to it.
hope this helps
DRZ-400sm
PostPosted: 16:25 - 05 Oct 2007    Post subject: Reply with quote
Beat me to it... Embarassed
DRZ-400sm
TUG
PostPosted: 16:26 - 05 Oct 2007    Post subject: Reply with quote
sorry but you win, yours is more detailed anyway Laughing
Haz ER-5, innit!
Barry_M2
PostPosted: 16:32 - 05 Oct 2007    Post subject: Reply with quote
Neutral light is usually an earch switch. Just means that its either a faulty switch or the wiring is screwed going into the back of the clocks.
Quick way to check would be to get a volt meter, stick positive on the battery and negative where the connector pushes onto the neutral switch (location as above).
You should see 12v when in neutral and 0v when in gear. If you get 12v in gear, the switch is borked! If you pull the connector off the neutral switch and the light still stays on, its earthing somewhere else and you need to check your wiring!!!
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
lugoismad
hope this helps
Thanks dude, I'll do that this weekend.
The last post was made 18 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.75 - MySQL Queries: 13 - Page Size: 51.22 Kb
