Datatool alarm problems...
Sparks!
Sir Tart-a-lot
PostPosted: 14:17 - 28 Nov 2007    Post subject: Datatool alarm problems... Reply with quote
I fukin hate alarms!!!
Got a datatool alarm on my project CBR, think its a System 21 or possibly a 3.. but I think 21 ....
The bike has been set for about 2 years or so, obviously the battery went flat.. I have now just put a new battery in it....
the alarm won't disengage from the transmitter no matter what I do! tried 2 transmitters and both lights flash up so im sure they both have enough battery etc....
With the alarms inline fuse OUT the alarm doesn't sound, but won't disengage, if you turn ignition on then it will sound the alarm, if you then turn ignition off the alarm goes off.
With the alarms inline fuse IN the alarm sounds constantly for about 30 seconds then stops, then starts again!!!!
I read that if battery condition goes too low then it goes into sleep mode but I can't seem to wake the fuckin thing up so either I'm not doing it right or this aint the problem!
The switch under the seat (which is meant to sound alarm if take seat off..) has the metal tag broken off, but I've pushed the button in and it doesn't make any difference, altho from my last alarm I'm sure you can still disengage the alarm with that switch in the open position anyways.
I'm lost now, anyone got any clue whats up?? I don't know the 4 digit pin, the alarm doesnt seem to be set anyways, you can move the bike and alarm wont sound.... not sure whats going on really
MarkJ
PostPosted: 14:27 - 28 Nov 2007    Post subject: Reply with quote
From reading this, I assume it doesn't have an immobiliser, and it's just an alarm?
Edit: Actually looks like it's a System 3. Have you read this guide?
Sparks!
Sir Tart-a-lot
PostPosted: 14:32 - 28 Nov 2007    Post subject: Reply with quote
I presume so.. haven't tried to start the bike yet, but the fuel pump primes even with the alarm going off, so I guess it's not immobilised?
Just done a bit of reading and the alarm may have "spiked" just trying to find some clear de-spiking instructions for the sys 21... but struggling... seems you have to cut the underseat switch off and connect it to the +ive of battery at one point... seems a bit weird.. don't think the switch just unplugs so needs to be cut out?? I want to cut that switch out and just through crimp the cables anyway, Im guessing that will work fine?
MarkJ
PostPosted: 14:37 - 28 Nov 2007    Post subject: Reply with quote
Actually, the alarm might not have had a PIN set, check out page 6 on here --> https://www.datatool.co.uk/pdfs/system3_ug.pdf
MarkJ
PostPosted: 14:38 - 28 Nov 2007    Post subject: Reply with quote
De-spiking guide: https://www.datatool.co.uk/pdfs/system3_ds.pdf
Sparks!
Sir Tart-a-lot
PostPosted: 14:39 - 28 Nov 2007    Post subject: Reply with quote
Key fob don't work though Rolling Eyes Laughing
I think it needs de-spiking, its the only thing left on the datatool instrcutions etc that I haven't tried.. so going to go and try it now.
MarkJ
PostPosted: 14:40 - 28 Nov 2007    Post subject: Reply with quote
good luck Thumbs Up
Sparks!
Sir Tart-a-lot
PostPosted: 15:19 - 28 Nov 2007    Post subject: Reply with quote
Right, it IS a system 3 alarm.
I have followed the despiking instructions which is to remove battery link and unplug the PCB and leave for 6 hours... so gotta wait till later tonight to plug it all back in and see if that has fixed it.
If not then I'll try the coding instructions where you have to link the seat switch to the +ive of the battery.
What a nightmare, theres me thinking this bike would be finished today!
MarkJ
PostPosted: 16:52 - 28 Nov 2007    Post subject: Reply with quote
You could always just buy a new loom and have no alarm Laughing
Sparks!
Sir Tart-a-lot
PostPosted: 16:59 - 28 Nov 2007    Post subject: Reply with quote
Well, would just cut it out......... thats the simplest option, but they are £300 odd to get fitted and its a selling point really so I'd like to have it working, might make it easier/quicker to sell the bike and may be worth a bit more with it on.
The last post was made 18 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 66.67 Kb
