Front sprocket holding on thingy...
KLR600
PostPosted: 16:11 - 28 Nov 2007    Post subject: Front sprocket holding on thingy... Reply with quote
Yesterday I managed to snap the chain on my XJ600 (*slaps self*) and the chain seems to have taken the washer thing that goes on between the nut and front sporcket to stop the sprocket from coming loose with it.
Is it super mega dangerous to ride the bike without this washer in place or will I be ok? Is it possible to make one out of an old washer and bend it over the nut?
I'm off to the bike shop to get a new chain in 5 mins so I'll ask if they have a washer while I'm there but if not I feel I may hve to be a bit creative as I need my bike almost everyday for work but luckily I have a day off today.
(this is the washer I'm talking about (this is not my bike, just a random image from the net), you have to fold it over the nut that holds the sprocket in place)
https://img.photobucket.com/albums/v331/serenaur/oilfeedlg2.jpg
<Take Cool Photos!>
NSR Mick
PostPosted: 16:13 - 28 Nov 2007    Post subject: Reply with quote
The sprocket retaining nut is more likely to come off if you do without creating another problem if it comes off.
KLR600
PostPosted: 16:15 - 28 Nov 2007    Post subject: Reply with quote
The last thing I want to happen is have the sprocket come off!
Right, so don't ride it without one? Will I be ok to make one from an old washer if the bike shop doesn't have one? (I somehow doubt it's the kind of thing people usually stock)
<Take Cool Photos!>
Paddy Blake
PostPosted: 16:19 - 28 Nov 2007    Post subject: Reply with quote
Check the sprocket and see if the washer is stuck to it.
I cant see how the chain could remove the washer.
Paddy.
PostPosted: 16:36 - 28 Nov 2007    Post subject: Reply with quote
As above. Likely the centre of the washer is splined to match the splines on the output shaft of the gearbox. So the washer is locked in place to the shaft and then the edge bent over to lock the nut to the washer.
KLR600
PostPosted: 20:03 - 28 Nov 2007    Post subject: Reply with quote
Crisis/death semi averted!
The bike shop (Woods in Abergele) had one of the washers in stock and it cost me £1.38!
But upon returning home to fit my new chain and washer I noticed a tooth missing from the front sprocket so I'm going to have to go back there tomorrow for some sprockets now Evil or Very Mad Christ knows where the money is going to come from!
<Take Cool Photos!>
PostPosted: 19:02 - 29 Nov 2007    Post subject: Reply with quote
A front sprocket should cost less than a tenner. since they wear much faster than a rear sprocket you should be able to just change the front. Check the condition of the rear sprocket - if the teeth show no signs of wear/hooking then there's no reason to change it.
Finglonga
PostPosted: 21:02 - 29 Nov 2007    Post subject: Reply with quote
Should be fitting new sprockets with a new chain anyway. It would only wear the chain out faster if you didn't.
Andy Sez....
F.Y.Y.F.F.
PostPosted: 21:24 - 29 Nov 2007    Post subject: Reply with quote
It's advisable for best fit but not a necessity, especially if your chain was well inside it's stretch limit when you changed it.
Paddy Blake
PostPosted: 01:33 - 30 Nov 2007    Post subject: Reply with quote
Vincent wrote:
I still want to know how and where the chain took the lock tab washer Very Happy
I can't sleep until I find out how that happened. Smile
Paddy.
PostPosted: 06:23 - 30 Nov 2007    Post subject: Reply with quote
Most likely reason is that the last person didn't realise it was a lock washer and didn't replace it.
Syx
PostPosted: 03:24 - 01 Dec 2007    Post subject: Reply with quote
Agreed - to me it seems impossible for the chain to have removed it.
Paddy Blake
PostPosted: 03:44 - 01 Dec 2007    Post subject: Reply with quote
Paddy.
The last post was made 18 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 84.81 Kb
