| MillaMeter |
 MillaMeter Nova Slayer
| Sparks! |
 Sparks! Sir Tart-a-lot
 Posted: 21:58 - 13 Dec 2007 Post subject: |
Solds like its only running on 2 cylinders?? I'm guessing it hasn't been run for a while if the battery was flat... ?
Take the plugs out and check them out... if they look okay then check you have a good spark (take all plugs out the HT leads, then put 1 plug in touch it to the frame and hit the start button, you should see it sparking)
The "sounds like a vtwin" comment makes me think its the plugs... ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
| MillaMeter |
 Posted: 22:15 - 13 Dec 2007 Post subject: |
Thanks for your input Sparks, I will have to check them out at the weekend as it was a mission to get that tank off.
I'll keep you posted.  ____________________ Currently Own:
2010 Kawasaki ZX6R RAF Performance Edition / 2008 Kawasaki Ninja 250 K8F |
| Sparks! |
| MillaMeter |
| Kwaks |
 Kwaks I'm not a fast rider
 Posted: 16:41 - 15 Dec 2007 Post subject: |
Sounds like the sparks to me, how did you get on? ____________________ Fallen Angel "Nae sniffing my seat now!!!!! "
www.cliqueycuntsmcc.co.uk
I AM NOT A FAST RIDER!!!!!!!!! |
| Barry_M2 |
 Barry_M2 World Chat Champion
 Posted: 18:55 - 15 Dec 2007 Post subject: |
| MillaMeter wrote: | I started the bike up when I had the airbox off the other day and opened the throttle and all 4 floats seemed to move up. |
I think you are getting a bit confused. The floats are in the float bowl. What you are looking at down the mouth of the carb are the slides.
When the fuel level is low in the bowl, the float lowers down, allowing more fuel in. If the float (or valve) is stuck, then it might not allow any fuel into the carb bowl, and therefore will not fire on that cylinder.
If you did try and drain fuel from one of the carb float bowls and nothing came out, this would point to a stuck float / valve. You'll need to get the carbs off, turn them upside down, remove the float bowls and clean it all out. But be VERY carefull, there are a few very small parts in there that you dont really want to loose!
edit: You are very close to me according to the map, if you want a hand, just give me a shout.  ____________________ ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
https://www.bikechatforums.com/profile.php?mode=viewprofile&u=4332 |
| MillaMeter |
 Posted: 11:24 - 16 Dec 2007 Post subject: |
| Barry_M2 |
 Posted: 11:49 - 16 Dec 2007 Post subject: |
Thats the fella.
Yeah, get the carbs off, flip them over, take the bowls off.
To remove the floats, there is a very small pin that holds them in place, once you remove that, it will come off. But, the float valve is attached to it to and may fall off if your not carefull. Have a look at how everything sits when you take the bowl off, move the float up and down and you'll see the valve going in and out of where the fuel comes out. Its probably that thats getting stuck. Use a bit of brake/carb cleaner on it.
Job done!
Where abouts are you out of interest? ____________________ ZXR750R (M2) - For the road.
| MillaMeter |
 Posted: 18:14 - 16 Dec 2007 Post subject: |
Right, I took the carbs completely off the bike and took every float bottom off with some problems. The previous owner said to me he took the bike to a local garage to get the bike fixed as it wasn't running right. Well... the previous owner looked too stupid to fix the bike himself anyway. Pretty much all the bloody screws were rounded off (no thanks to the grease monkey mechanic), so I had to take them off with a pair of pliers. Then I found a 1 of 4 screws missing that holds the choke arm together.
Anyway... when I took carb 1 apart (the 1 that wouldn't drain fuel) the float bowl was caked in erm.... I dunno, looked like rust? So I cleaned that up as best as I could and it now drains fuel
I thought I'd be on the safe side and check all carbs. #2,3 and 4 all ok
I'll fit the carbs back to the bike sometime this week coming and let ya'll know how she's running  ____________________ Currently Own:
| Barry_M2 |
 Posted: 19:42 - 16 Dec 2007 Post subject: |
| MillaMeter |
| MillaMeter |
 Posted: 15:34 - 17 Dec 2007 Post subject: |
FIXED!! I think
well... before I cleaned the carbs I really had to stuggle to even fire her up. Having the choke fully on etc... and then she wouldn't hold a simple idle of 1200rpm I would have to have the throttle open a little to hold the revs and if I let go to make the bike idle, she would just die.
I put the cleaned carbs back on just now and she fired up like a couple of seconds later (well the carbs were empty so...) with no choke! she sounded rough at first maybe because the carbs were still filling up? but she holds her idle quite nicely.
Only problem I have now is that when I open her up then drop the throttle, she slows down really really slowly. Sticky throttle cable? choke cable sticking? I don't know but I did check them over.
Well at least she fired up ok.
Gonna check the sparkies just to be on the safe side.
i'll Keep y'all posted.  ____________________ Currently Own:
| ace_tweety |
 ace_tweety Could Be A Chat Bot
 Posted: 15:52 - 17 Dec 2007 Post subject: |
yeah sounds like a sticking throttle cable or something?
Make sure its not caught on anything then you were putting everything back together. ____________________ Suzuki SV 650 (blue of course!)  |
| Barry_M2 |
 Posted: 17:55 - 17 Dec 2007 Post subject: |
It could be a sticking throttle cable, does the twist grip return quickly when you let it go?
Could also be a slight air leak on the inlet side of things.
Make sure the carbs are pressed right in to the rubbers and that the clips on them are done up tight.
| MillaMeter |
 Posted: 18:35 - 17 Dec 2007 Post subject: |
I checked over the bike again and it all seems to be ok...cable wise that is.
I've added a lil mp3 of the bike what it sounds like. It really does sound ugly.
I'd say that was 2 cylinders wouldn't you? ____________________ Currently Own:
| Barry_M2 |
 Posted: 10:20 - 18 Dec 2007 Post subject: |
Did you replace the spark plugs? If not, just do it.
Also, you could have a problem with one of the coils if 2 of the cylinders are not firing (1 coil per 2 cylinders). Take the plugs out and push them into the HT cap, rest on the cam cover and hit the starter, make sure all the plugs give a spark.
| MillaMeter |
 Posted: 18:50 - 18 Dec 2007 Post subject: |
I took 2 spark plugs out today, I only took 2 out because It was getting dark, both from pot 2 and 3.
sparkie #3 is totally black and carbon and sparkie #2 is heading that way too.
If I got time tomorrow I'll check the sparkies in pot 1 and 4 and gonna do what you said Barry, I'll plug them all in and see if they're sparking ok
I'll let ya'll know how it turns out.
Thanks everyone for the replies, very much appreciated  ____________________ Currently Own:
| Timmeh |
 Timmeh World Chat Champion
 Posted: 20:10 - 18 Dec 2007 Post subject: |
sooty plugs is a sign of over-rich running; you need to fix it else it'll just ruin another set of plugs. Plus if there is differing amounts of soot on each plug it suggests that the carbs aren't balanced either, which would also account for a poor idle and overrun.
 ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
| MillaMeter |
 Posted: 10:20 - 21 Dec 2007 Post subject: |
| MillaMeter |
 Posted: 10:48 - 27 Dec 2007 Post subject: |
UPDATE!!
Found the problem at last!!!!
Checked all spark plugs in each HT socket and plug #2 and #3 aren't firing, so all along the bike has only been firing on #1 and #4 cylinder. I thought to meself, it must be the ignition coil fooked. So I did a lil test before ripping it out and buying a new 1. I changed the 2 cables from the other ignition coil to the 1 that wasn't working, and hey presto. it started working again!
So I'm now guessing the 2 cables that connect to the coil aren't getting any power at all. Cracked cable maybe? lose connection somewere? or I.C Ignitor
Any ideas anyone? Only I don't have a clue where to start looking as this is my first 4 cylinder bike.
Thanks ____________________ Currently Own:
| mr jamez |
 mr jamez World Chat Champion
 Posted: 12:51 - 27 Dec 2007 Post subject: |
If you're going to be doing stuff like this, get yourself a multimeter and make life easy. About £15 from halfords or maplin. Then hunt down a wiring diagram which should make it self explanatory  ____________________ NSR 125F > BROS 400 > NC30 > BROS 400 > Trumpet S4 > '97 VFR 750 |
| MillaMeter |
 Posted: 00:14 - 28 Dec 2007 Post subject: |
Just ran a meter across the I.C. ignitor only to find 1 maybe 2 pins are not working very well. I followed all the directions on the manual on how to check the ignitor etc...
So this looks like a new I.C. ignitor.... great.
Anyone know any decent places I can get 1 cheap as chips? even if it's second hand? (strap for cash atm)
Many thanks on the replys btw very much appreciated  ____________________ Currently Own:
The last post was made 18 years, 198 days ago. Instead of replying here, would creating a new thread be more useful? |
