ZXR400 sounding very lumpy.
MillaMeter
PostPosted: 15:37 - 13 Dec 2007    Post subject: ZXR400 sounding very lumpy. Reply with quote
It all started when I went down to my garage the other day to start me bike up, only to find the battery was dead. Ok, no biggie... SO i got my bro down to jump it with the leads from his zx6r. Started first time. Then the following day, I went to start her up and it didn't sound right at all. it's now sounding more like a turbo v twin on baked beans. the tone of the exhaust has got a lot deeper and the bike struggles to hold it's rpm. I have to have the choke fully on in order to keep the revs up. I daren't ride her incase I do damage.
I did take the tank off and airbox to give the carbs a clean, I drained each carb from left to right, then I noticed something. #1 carb doesn't seem to want to drain. I took the screw completely out and no fuel came out. Any ideas what this means? #2, 3 and 4 drained fine.
if anyone needs a recording of the engine or exhaust, please let me know.
thanks
Currently Own:
2010 Kawasaki ZX6R RAF Performance Edition / 2008 Kawasaki Ninja 250 K8F
Sparks!
Sir Tart-a-lot
PostPosted: 21:58 - 13 Dec 2007    Post subject: Reply with quote
Solds like its only running on 2 cylinders?? I'm guessing it hasn't been run for a while if the battery was flat... ?
Take the plugs out and check them out... if they look okay then check you have a good spark (take all plugs out the HT leads, then put 1 plug in touch it to the frame and hit the start button, you should see it sparking)
The "sounds like a vtwin" comment makes me think its the plugs...
MillaMeter
PostPosted: 22:15 - 13 Dec 2007    Post subject: Reply with quote
Thanks for your input Sparks, I will have to check them out at the weekend as it was a mission to get that tank off.
I'll keep you posted. Wink
Currently Own:
Sparks!
Sir Tart-a-lot
PostPosted: 22:20 - 13 Dec 2007    Post subject: Reply with quote
Tank should be easy to get off Smile
Just don't go taking the carbs off in a hurry cos they are a BASTID Laughing
oh, by the way, have you taken the tops off the carbs and checked the floats aren't sticking?
MillaMeter
PostPosted: 14:10 - 14 Dec 2007    Post subject: Reply with quote
I started the bike up when I had the airbox off the other day and opened the throttle and all 4 floats seemed to move up.
You are right about the bike not been riden in a while as I haven't passed my test yet to ride her, but I did take her for a quick blast up the road and back and she seemed fine then.
If I remember rightly, she started to play up when I poured a lil redex in the tank. can't really see how that would make the bike only run on 2 or 3 cylinders though.
Thanks again for your reply, much appreciated Smile
Currently Own:
Kwaks
I'm not a fast rider
PostPosted: 16:41 - 15 Dec 2007    Post subject: Reply with quote
Sounds like the sparks to me, how did you get on?
www.cliqueycuntsmcc.co.uk
Barry_M2
PostPosted: 18:55 - 15 Dec 2007    Post subject: Reply with quote
I think you are getting a bit confused. The floats are in the float bowl. What you are looking at down the mouth of the carb are the slides.
When the fuel level is low in the bowl, the float lowers down, allowing more fuel in. If the float (or valve) is stuck, then it might not allow any fuel into the carb bowl, and therefore will not fire on that cylinder.
If you did try and drain fuel from one of the carb float bowls and nothing came out, this would point to a stuck float / valve. You'll need to get the carbs off, turn them upside down, remove the float bowls and clean it all out. But be VERY carefull, there are a few very small parts in there that you dont really want to loose!
edit: You are very close to me according to the map, if you want a hand, just give me a shout. Thumbs Up
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
MillaMeter
PostPosted: 11:24 - 16 Dec 2007    Post subject: Reply with quote
Yeah that's what I meant... my bad. The 4 gray slides which are attached to the needles right?
So it's just a matter of taking the carbs off, draining them all and cleaning them up?
No problem at all. If I ever get stuck Barry, I'll hola at ya Thumbs Up
Gonna start working on the carbs today....that's if my GF lets me Neutral
Many thanks on the replys guys Thumbs Up
Currently Own:
Barry_M2
PostPosted: 11:49 - 16 Dec 2007    Post subject: Reply with quote
Thats the fella.
Yeah, get the carbs off, flip them over, take the bowls off.
To remove the floats, there is a very small pin that holds them in place, once you remove that, it will come off. But, the float valve is attached to it to and may fall off if your not carefull. Have a look at how everything sits when you take the bowl off, move the float up and down and you'll see the valve going in and out of where the fuel comes out. Its probably that thats getting stuck. Use a bit of brake/carb cleaner on it.
Job done!
Where abouts are you out of interest?
MillaMeter
PostPosted: 18:14 - 16 Dec 2007    Post subject: Reply with quote
Right, I took the carbs completely off the bike and took every float bottom off with some problems. The previous owner said to me he took the bike to a local garage to get the bike fixed as it wasn't running right. Well... the previous owner looked too stupid to fix the bike himself anyway. Pretty much all the bloody screws were rounded off (no thanks to the grease monkey mechanic), so I had to take them off with a pair of pliers. Then I found a 1 of 4 screws missing that holds the choke arm together.
Anyway... when I took carb 1 apart (the 1 that wouldn't drain fuel) the float bowl was caked in erm.... I dunno, looked like rust? So I cleaned that up as best as I could and it now drains fuel Very Happy
I thought I'd be on the safe side and check all carbs. #2,3 and 4 all ok Thumbs Up
I'll fit the carbs back to the bike sometime this week coming and let ya'll know how she's running Smile
Currently Own:
Barry_M2
PostPosted: 19:42 - 16 Dec 2007    Post subject: Reply with quote
MillaMeter wrote:
..... Then I found a 1 of 4 screws missing that holds the choke arm together.
Dont put one in there, its supposed to be missing. Wink
The crap in the float bowl if it was a sort of thick brown sludge, thats what happens when the bikes been sitting a while.
A quick test you can do is, put a small piece of pipe on to where the fuel line goes and blow down it, each time raise and lower the floats in turn and make sure when you blow the air flows. With the float at its highest (closest the carb) it will shut off the flow.
I hope that makes sense!? Confused
MillaMeter
PostPosted: 22:09 - 16 Dec 2007    Post subject: Reply with quote
Yeah exactly! it kinda was a dark colour brown and quite soft. Right down the bottom by the drainage screw it was really hard, so hard that I had to stick a pipe cleaner down it to free it up.
Ah well, I've decided to fit the carbs back on tomorrow and hopefully fingers crossed it's solved the problem.
I'll keep ya'll posted
Currently Own:
MillaMeter
PostPosted: 15:34 - 17 Dec 2007    Post subject: Reply with quote
FIXED!! I think Neutral
well... before I cleaned the carbs I really had to stuggle to even fire her up. Having the choke fully on etc... and then she wouldn't hold a simple idle of 1200rpm I would have to have the throttle open a little to hold the revs and if I let go to make the bike idle, she would just die.
I put the cleaned carbs back on just now and she fired up like a couple of seconds later (well the carbs were empty so...) with no choke! she sounded rough at first maybe because the carbs were still filling up? but she holds her idle quite nicely.
Only problem I have now is that when I open her up then drop the throttle, she slows down really really slowly. Sticky throttle cable? choke cable sticking? I don't know but I did check them over.
Well at least she fired up ok. Very Happy
Gonna check the sparkies just to be on the safe side.
i'll Keep y'all posted. Thumbs Up
Currently Own:
ace_tweety
PostPosted: 15:52 - 17 Dec 2007    Post subject: Reply with quote
yeah sounds like a sticking throttle cable or something?
Make sure its not caught on anything then you were putting everything back together.
Suzuki SV 650 (blue of course!) Very Happy
Barry_M2
PostPosted: 17:55 - 17 Dec 2007    Post subject: Reply with quote
It could be a sticking throttle cable, does the twist grip return quickly when you let it go?
Could also be a slight air leak on the inlet side of things.
Make sure the carbs are pressed right in to the rubbers and that the clips on them are done up tight.
MillaMeter
PostPosted: 18:35 - 17 Dec 2007    Post subject: Reply with quote
I checked over the bike again and it all seems to be ok...cable wise that is.
I've added a lil mp3 of the bike what it sounds like. It really does sound ugly. Crying or Very sad
I'd say that was 2 cylinders wouldn't you?
Currently Own:
Barry_M2
PostPosted: 10:20 - 18 Dec 2007    Post subject: Reply with quote
Did you replace the spark plugs? If not, just do it.
Also, you could have a problem with one of the coils if 2 of the cylinders are not firing (1 coil per 2 cylinders). Take the plugs out and push them into the HT cap, rest on the cam cover and hit the starter, make sure all the plugs give a spark.
MillaMeter
PostPosted: 18:50 - 18 Dec 2007    Post subject: Reply with quote
I took 2 spark plugs out today, I only took 2 out because It was getting dark, both from pot 2 and 3.
sparkie #3 is totally black and carbon and sparkie #2 is heading that way too.
If I got time tomorrow I'll check the sparkies in pot 1 and 4 and gonna do what you said Barry, I'll plug them all in and see if they're sparking ok Smile
I'll let ya'll know how it turns out.
Thanks everyone for the replies, very much appreciated Thumbs Up
Currently Own:
Timmeh
PostPosted: 20:10 - 18 Dec 2007    Post subject: Reply with quote
sooty plugs is a sign of over-rich running; you need to fix it else it'll just ruin another set of plugs. Plus if there is differing amounts of soot on each plug it suggests that the carbs aren't balanced either, which would also account for a poor idle and overrun.
MillaMeter
PostPosted: 10:20 - 21 Dec 2007    Post subject: Reply with quote
It's possible, but as the bike has been dynoed and was running beautifully a week ago, I wouldn't be too sure it's that. But now that you mentioned it, I will take a look into it. Only problem is, I have the carb balancing kit, but I can't seem to find anywere to attach the hoses. Any ideas where they could be? Barry?
As the bike is only running on 2 maybe 3 cylinders, I will check today if the ignition coils are working as they should. I would of done this sooner but I just had a minor operation on my hip Sad
Further update soon.
Currently Own:
MillaMeter
PostPosted: 10:48 - 27 Dec 2007    Post subject: Reply with quote
UPDATE!!
Found the problem at last!!!! Very Happy Thumbs Up
Checked all spark plugs in each HT socket and plug #2 and #3 aren't firing, so all along the bike has only been firing on #1 and #4 cylinder. I thought to meself, it must be the ignition coil fooked. So I did a lil test before ripping it out and buying a new 1. I changed the 2 cables from the other ignition coil to the 1 that wasn't working, and hey presto. it started working again!
So I'm now guessing the 2 cables that connect to the coil aren't getting any power at all. Cracked cable maybe? lose connection somewere? or I.C Ignitor Neutral
Any ideas anyone? Only I don't have a clue where to start looking as this is my first 4 cylinder bike.
Thanks
Currently Own:
mr jamez
PostPosted: 12:51 - 27 Dec 2007    Post subject: Reply with quote
If you're going to be doing stuff like this, get yourself a multimeter and make life easy. About £15 from halfords or maplin. Then hunt down a wiring diagram which should make it self explanatory Smile
MillaMeter
PostPosted: 00:14 - 28 Dec 2007    Post subject: Reply with quote
Just ran a meter across the I.C. ignitor only to find 1 maybe 2 pins are not working very well. I followed all the directions on the manual on how to check the ignitor etc...
So this looks like a new I.C. ignitor.... great.
Anyone know any decent places I can get 1 cheap as chips? even if it's second hand? (strap for cash atm)
Many thanks on the replys btw very much appreciated Thumbs Up
Currently Own:
The last post was made 18 years, 193 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.81 - MySQL Queries: 13 - Page Size: 131.14 Kb
