How do I hack into my own router?
PostPosted: 22:38 - 20 Dec 2007    Post subject: How do I hack into my own router? Reply with quote
Stupid problem, not of my making but I thought I'd have a go at fixing it again. (got fed up last time)
Out of goodwill I am allowing work to use my computer for their internet access on a single PC in the branch surgery downstairs. If I didn't they'd have to put in another phone line which stupid for the 30 minutes a day it is open.
Trouble is, I'm pretty sure they've* firewalled stuff I need using the routers hardware firewall. In particular it regularly makes gmail and photobucket uploads go tits-up (they say they haven't, I don't believe them). I also want to disable their remote access port so they have to ask me nicely if they want to change anything again (and so there isn't a wide open hole in the security).
They cannae get on my computer mind. I have my own firewall and the guy at the consultants place expressed surprise when I sent him an email as I was on the phone. "Is your PC using that connection now?" "Yes, I just emailed you off it." "What the hell are you running, I can't see it?" "Good.".
Now, easy to fix eh? Nope. They've remotely moved the router off 192.168.1.1 and I don't know where it is. They may have passworded it but I can't even find that out (and their passwords are weak, it'll be one of three).
So, any way of finding out my router address so I can access the setup screen? (NOT the WAN address, I want its LAN address).
I could reset it but then I'll lose the settings that let the work computer talk to the other work computers (and I don't know how to put them back).
It's not a huge problem. I have another router setup how I want it, it just means I'm always having to swap plugs round (and sometimes forget to plug the work one back in which causes chaos). Ideally I would use my router and transfer the settings across to allow the work computer to function. My router is better and faster than their one.
Oh, I'm running Ubuntu linux which comes with all manner of network tools such as: ping, traceroute, netstat, portscan, lookup finger and whois. I know what ping does, the others are a bit of a mystery but I'm sure they are useful.
*They = Computer consultants located hundreds of miles away who are never available when you call for support.
iooi
PostPosted: 22:52 - 20 Dec 2007    Post subject: Reply with quote
Try
Network proprities and then tcp/ip proticol propities, may be listed under default gateway.
PostPosted: 23:16 - 20 Dec 2007    Post subject: Reply with quote
iooi wrote:
Try
No luck there. Thanks for trying though.
Burnside
PostPosted: 23:25 - 20 Dec 2007    Post subject: Reply with quote
type ipconfig /all at the command prompt - the default gateway will be the router's ip address.
to get to the command prompt:
Click Start> Run
type cmd click OK
[EDIT] trying to find a way of hacking the password, will get back to you... Wink
PostPosted: 23:43 - 20 Dec 2007    Post subject: Reply with quote
Click Start> Run
type cmd click OK
Err. No windows on this machine so no 'run' command. I can get a unix terminal up.
TheShaggyDA
Repost Police
PostPosted: 23:47 - 20 Dec 2007    Post subject: Reply with quote
In a unix session, try :-
traceroute www.google.com
You should get the route to Google, your router should be the first hop.
https://linux.about.com/library/cmd/blcmdl8_traceroute.htm
In windows, you'd do it in a command window :-
tracert www.google.com
Burnside
PostPosted: 00:00 - 21 Dec 2007    Post subject: Reply with quote
Bugger, didn't read your post right oopsy daisy
bazza
PostPosted: 00:04 - 21 Dec 2007    Post subject: Reply with quote
On the Ubuntu box
Code:
sudo route -n
will give you something like:
Code:
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
192.168.1.0     0.0.0.0         255.255.255.0   U     0      0        0 eth0
0.0.0.0         192.168.1.1     0.0.0.0         UG    0      0        0 eth0
where 192.168.1.0 will be your network and 192.168.1.1 will be the router (I know it's not but it will be the line with "UG" on it). Once you have the IP and know what type of router it is, you should be able to bring up the login page via a browser and enter one of the three passwords, et voila!
PostPosted: 00:27 - 21 Dec 2007    Post subject: Re: How do I hack into my own router? Reply with quote
Is it a router or an "adsl modem"? Possibly turn the "modem" off on their router, plug your router in as the main one and just have theirs hanging off yours via a network cable. Basically what we have done with a wireless "adsl router / modem" and then with a normal wired router hanging off that for most use.
PostPosted: 00:38 - 21 Dec 2007    Post subject: Reply with quote
Hmm. Think I found it. Doesn't connect to anything when I type the address into firefox though.
I think I also found something interesting while I've been messing on. Their router is assigning the DNS address as their own server. My router sets it as the default ISP DNS server. Reckon this could be screwing things up?
Just to confirm. I read this as my router being on 192.168.8.100 and in theory, if I type that into the browser I should either get onto the router setup or be told to piss off and come back when I know the password?
PostPosted: 00:48 - 21 Dec 2007    Post subject: Reply with quote
Ok, bazzas comes up with a different one.
Code:
Kernel IP routeing table
192.168.8.0     0.0.0.0         255.255.255.0   U     0      0        0 eth0
169.254.0.0     0.0.0.0         255.255.0.0     U     1000   0        0 eth0
0.0.0.0         192.168.8.99    0.0.0.0         UG    0      0        0 eth0
This also draws a blank when typed into the browser. How annoying!
@ Keith. Both proper ADSL 2/2+ routers.
Fast getting fed up with this again. It's like Brick Wall . Why do computer consultants have to be so fecking arsey? It's my bloody computer, it's my internet connection. If I want to fuck about with it then I should be able to, even if this means I screw everything up.
PostPosted: 00:56 - 21 Dec 2007    Post subject: Reply with quote
The security aspect annoys me as well. With my setup, it is fully stealthed when you do a security scan. With theirs, it has reverse DNS lookup and three open ports. (I've closed them locally on my machine, but still, it's a bit shit).
bazza
PostPosted: 01:00 - 21 Dec 2007    Post subject: Reply with quote
Your IP: 192.168.8.100
Router IP: 192.168.8.99
You may have to enter a port number at the end of the URL for the web page, something like:
Code:
http://192.168.8.99:8080
where 8080 is the port number.
Look up the router on google and see what the default port is.
PostPosted: 01:19 - 21 Dec 2007    Post subject: Reply with quote
Ahah! remember those open ports I was whinging about?
It was one of them! (they'd changed the port it was working from too)
Now I just need to guess the password.
Cheers Thumbs Up
CaNsA_old
PostPosted: 11:51 - 21 Dec 2007    Post subject: Reply with quote
Oi oi stinkwheel.
Matey whats the make and model of the router?
Im a network geek for a living. Ive had loads practice getting into "locked down" routers.
also, look on the back of the router. if it has a tiny reset button hold it down, take the power lead out, 5secs, plug it in still holding the reset button for a further 30secs.
that will make it go back to its default settings. the default user name and password vary from make to make. try these combinations though
un - admin / pw - admin
un - admin / no password
if they dont work let me know the make and ill get the info for ya.
Peace out
Everyone is entitled to MY opinion
feef
Energiser Bunny
PostPosted: 12:16 - 21 Dec 2007    Post subject: Reply with quote
CaNsA wrote:
Oi oi stinkwheel.
Peace out
That's assuming it's a 'retail' router like a Linksys or Netgear..
I'd like to see you do that on one of my Cisco jobbies Very Happy
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
swaffs
PostPosted: 12:45 - 21 Dec 2007    Post subject: Reply with quote
and the fact he already said he could reset it , but doesn't want to!
Swaffs Photography |
BCF vinyl stickers
"Look not back in anger, nor forward in fear, but around you in awareness."
GodzGift
PostPosted: 14:23 - 21 Dec 2007    Post subject: Reply with quote
Once your logged into the routers admin interface, you may want to update the routers firmware.
Get the firmware from the manufacturers site.
Bike Level: Amateur | CBT Passed
TheShaggyDA
Repost Police
PostPosted: 18:23 - 21 Dec 2007    Post subject: Reply with quote
Or, if the router's working fine as it is, you may want to leave the firmware alone.
GodzGift
PostPosted: 17:38 - 22 Dec 2007    Post subject: Reply with quote
It may improve performance if you do so.
djr
PostPosted: 13:06 - 23 Dec 2007    Post subject: Reply with quote
feef wrote:
CaNsA wrote:
Oi oi stinkwheel.
Peace out
a
Think he's said in the past it was one of the draytec vigor piles of rubbish... fucking horrible them boxes are :/.
Jamie.
PostPosted: 14:23 - 24 Dec 2007    Post subject: Reply with quote
It may permanently fuck the router if you do so.
I always say with firmware, If it ain't broke don't fix it!
panrider_uk
PostPosted: 17:02 - 26 Dec 2007    Post subject: Reply with quote
Click Start> Run
type cmd click OK
This depends on the router being a dhcp server and the pc being a dhcp client so not always foolproof.
Mark
The last post was made 18 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 131.38 Kb
